Note on compatibility
Jul 5, 2010 4:55 PM
Hello,
We hope you are able to successfully install and use these new Add-ons for Workbench
The Archive file is intended for Workbench ES2 (version 9.0.0 GM). Some folks have reported problems applying the Add-ons to a Workbench environment that is already updated with earlier distributions of these Add-ons, or when using a preview release of Workbench ES2.5. In both instances you may see an error "no new features found" when you apply the Archive file. Currently the Add-ons are targeted at LiveCycle Workbench ES2 only, not on top of any other Workbench preview distributions you might have obtained since we released ES2.
A few people have also reported problems after applying the Add-ons to an ES2Service Pack 1 (version 9.0.0.1) version of Workbench. This is indeed supported for the Add-ons. But there is a known bug on Windows 7 and Windows 2003 Server where some Views do not display properly. You will need to launch Workbench as the Windows "Administrator" user (right click in the Start Menu -> select Run As.. Administrator). This was caused by a recent move in Service Pack 1 to use JDK 1.6. We are working on a fix for that.
So in summary, if you are just using Workbench ES2 GM you should be fine. If you are using Workbench ES2 Service Pack 1 on Windows 7 or Windows Server, you may need to launch as Administrator while we work out a bug.
