Hi everyone,
I have two tables, each has one row, table A cannot exist without table B, meaning if Table A has one objective, then there must at least be one KPI (KPI is contained within Table B).
Now I need to create an xsd that complies to this structure, to have a Row within a row. These tables should grow according to the data that is in the xml.
Below is what I've written, but I want the outputType to belong in objective and be a table/row.
xsd:complexType name="objective">
<xsd:sequence>
<xsd:element minOccurs="0" maxOccurs="unbounded" name="objectives">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="O1" type="xsd:string" />
<xsd:element name="O1Weight1" type="xsd:integer" />
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
xsd:complexType name="outputType">
<xsd:sequence>
<xsd:element minOccurs="0" maxOccurs="unbounded" name="kpi">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="O1K1Weight1" type="xsd:string" />
<xsd:element name="K1" type="xsd:string" />
<xsd:element name="O1K1Target1" type="xsd:string" />
<xsd:element name="O1K1Source1" type="xsd:string" />
<xsd:element name="O1K1ActualScore" type="xsd:string" />
<xsd:element name="O1K1Notes" type="xsd:string" />
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:complexType>
</xsd:complexType>
</xsd:complexType>
Views
Total Likes
I didn't think ComplexType nodes have a name attribute. Normally you do:
To make things easier, why not just make 2 tables? then have table A grow normally and then for each tableA.row, create however many KPIs you need in tableB.row.
Views
Total Likes
Yes I have two tables already, the challenge is to have Table B belong to Table A in an XSD & both tables should grow automatically depending on the xml data
Views
Total Likes
here's how I am understanding your issue:
Now I kind of doubt that would work, but you'd need to specify the tables individidually (so not nested):
I omitted types and namespaces, but hopefully that gives you an idea.
Views
Total Likes
Let me try and see if that will work, thanks.
Views
Total Likes
Views
Likes
