Table rows same height -Urgent
Jul 8, 2010 5:17 AM
Good day,
I want two tables when they grow to be the same height, The tables are next to each other.
I have this code under the add new row button :
var
subformIndex = this.parent.parent.parent.index;
OutputReviewMainTable.OutputMainTable.Row1.instanceManager.addInstance (1);
var
rows = xfa.resolveNodes("Scorecard.Page1.flowedHorzontal.OutputReviewMainTab le.OutputMainTable.Row1[*]");
var
tableH = 0;
for
(var i = 0; i < rows.length; i++){
tableH
= tableH + xfa.layout.h(OutputReviewMainTable.OutputMainTable.Row1, "mm");
xfa.resolveNode("Scorecard.Page1.flowedHorzontal["
+ subformIndex + "].OutputReviewTables.OutputSPOTable.Row1.Output_Rev_Objective").h = tableH + "mm";
this code works perfectly under the AddNewRow button, it helps the two tables grow equally, that is they have the same height. I tried putting the same code under the initialize event, so that when the xml populates the two table rows,they have the same height, but its like I didnt do anything.
Is there a way for me to solve this problem, please help me, I've now run out of ideas.
Ace
    Jul 8, 2010 5:26 AM   in reply to SirAce
    When you add that code to the Initialize you will probably have to force a lyout to occur (this layout happens automatically when you add a row). So try adding the command xfa.layout.relayout() to the end of your initialization script.
    Paul
    Jul 8, 2010 6:25 AM   in reply to SirAce
    If you send your form to LiveCycle8@gmail.com I will have a look and see if I can figure out why itis not behaving.
    Paul
