I posted this question on my distro-specific forum as well as linuxquestions.org, however it appears to be a unique problem, so here it is:
When viewing videos on youtube.com, most other websites, and when trying to run certain flash games, the flash applet will not display (though the audio will play). Instead of displaying the flash applet, there will be a grey box where the flash video or applet would normally be.
This problem occurs on Firefox and Chromium, but not on Opera.
My Specs are as follows:
Distro: PCLinuxOS 2010 (32-bit)
flash-player-plugin: 10.1-2pclos2010
firefox: 3.6.6-1pclos2010
swfdec has never been installed (to my knowledge)
I did a lot of investigating about the problem but have turned up no solutions thus far. Here are my results.
I'm thinking that there might be somewhere else that flash stores configurations for my user, and that maybe the settings there are corrupted and would need to be purged. However frantic googling has turned up nothing useful so far.
Does anyone have any suggestions for me?
I have narrowed the problem down to it being a KDE issue, not a flash-player-plugin issue since the problem only occurs in KDE.
In a unique twist, the problem was not due to KDE, but was actually caused by faulty QTCurve (theme) settings from WITHIN KDE. KDE apps weren't affected, however GTK ones were (QT and GTK apps were both being themed by QTCurve, although only the GTK apps were acting up).
The problem was resolved by loading one of the presets from the QTCurve configurator, and then customizing it to taste.
I don't think this is a KDE related issue or QTCurve. At least for me. I'm on XFCE4 and don't have QT on my system.
The videos work if they are linked to or embedded from another page.
If that is the case, then your grey box issue is different than my grey box issue -- since mine has already been solved.
The problem, at least in my case, was QtCurve's opacity. If I have opacity set to less than 100%, flash would not display for sites like Youtube and Vimeo, but worked elsewhere.
The solution for me was to go into qtcurve's settings, and put npviewer.bin in the application exceptions section for window and menu opacity. Doing that, I was able to keep my transparent menus, and also use flash everywhere.
You can find out what the application name is by launching your browser of choice in a terminal with qtcurve debug turned on, like so:
QTCURVE_DEBUG=1 firefox
If you watch through the lines that start with "QtCurve" you'll see "Application name". Look for the one that shows up when you try to load a video. In my case it was npviewer.bin. In yours, it might be nspluginviewer or something else. If you add an exception for that specific application, you'll fix your problem without having to compromise on your theme.
That may exactly be the case. Have to investigate further.
Maybe I do have QTCurve on my machine. The odd thing is, some pages play on Youtube, while others do not. If the video is embedded on a site, it plays. Directly on Youtube it doesn't.
Yep, same thing here. Also, if you go to a user's channel the video will play there, even if it didn't on the main page.
To be more specific, the method I used to solve it was to simply load one of QTCurve's default presets. This did away with the broken setting(s) which caused the problem. Then if one wants, the rest is to simply re-impement the changes one at a time until it breaks again, at which point you either (1) undo the change(s) or (2) add the program to an exception list (especially in the case of transparancy, which can be buggy on QTCurve 1.5.1)
