Terri9
CANNOT OPEN FLASHPLAYER ON MY PC EVEN THOUGH IT'S INSTALLED
Jul 22, 2010 6:18 AM
Good Morning...I have installed Adobe Flash Player 10 Active X, but it doesn't show up in my Programs under the Start tab.  However, it
it does show up when I go under Settings/Control Panel/Uninstall.  So, under Uninstall, I am able to unstall it but it just doesn't show up as an actual program and will not open up to use it on my pc.  Can you help?
    Jul 22, 2010 11:14 AM   in reply to Terri9
    It could be that it needs an update or on the other hand it could be that your application is not recogniozing the adobe flashplayer. Try to uninstall both and install again. Hope it works coz thats what I did last time.
    Jul 22, 2010 11:17 AM   in reply to Terri9
    I also think that this flashplayer doesnt really need to be shown there coz the purpose of it is to be able to view flash files on internet...like the ones which are .flv format. You must have been asked to download it when u visited a website. I'm sure you are able to use that website now. That's all this flashplayer is for.
    Jul 22, 2010 12:50 PM   in reply to Terri9
    Hi Terri9, Do you have Flash Player working now? Just a bit of info. Flash Player is listed in Add/Remove or Programs and Features via Control Panel as you found out. There is an ActiveX Control in the IE browser under manage add ons that works with your Installed Flash Player files. It is Shockwave Flash Object and must be there and Enabled. If you are using  Firefox or other non-IE browsers, then there is a SWF plug-in with the Flash Player version number with it and it must be Enabled also.
    You can test your Flash Player version here and if you are able to see the animation then Flash Player is Installed. This site will also show you the version number.
    http://www.adobe.com/software/flash/about/
    Hope this gives you a little more understanding on Flash Player.
    eidnolb
    Message was edited by: eidnolb
    Jul 22, 2010 7:30 PM   in reply to Terri9
    Hi Terri9, Thanks for replying back. They say knowledge is power, so now you have a little more power
    Glad Flash Player is working nicely for you!!!
    eidnolb
