www.marcelvanduijn.com
Flex two-phase preloader - problem preloading AIR
Jul 24, 2010 10:35 AM
Hi all,
I ran into a problem preloading a Flex AIR project. I guess a lot of you are familiar with the 2-phase preloading prinicple of Flex. You defer dispatching FlexEvent.INIT_COMPLETE and Event.COMPLETE to a moment thats suits you. I can get this to work fine with regular Flex projects, but when using this preloading technique with a Flex AIR project I get the following error:
TypeError: Error #1009: Cannot access a property or method of a null object reference. at mx.core::WindowedApplication/enterFrameHandler()[C:\autobuild\3.5.0\f rameworks\projects\airframework\src\mx\core\WindowedApplication.as:252 6]
This happens because WindowedApplication.creationCompleteHandler adds an enterFrameHandler:
    private function creationCompleteHandler(event:Event):void
        addEventListener(Event.ENTER_FRAME, enterFrameHandler);
        _nativeWindow = systemManager.stage.nativeWindow;
and WindowedApplication.ennterFrameHandler tries to access the stage:
      private function enterFrameHandler(e:Event):void
        removeEventListener(Event.ENTER_FRAME, enterFrameHandler);
        // If nativeApplication.nativeApplication.exit() has been called,
        // the window will already be closed.
        if (stage.nativeWindow.closed)
            return;
The red line of code throws the error mentioned above (its line 2526 of WindowedApplication) Because the preloader defers dispatching FlexEvent.INIT_COMPLETE and Event.COMPLETE the main application is not yet on the stage!
The only way I can get the 2-phase Flex preloading working for preloading a Flex AIR application is not to defer the dispatching of the events. But I need to defer them to apply some animation to the preloader (fade-out).
Are there any known solutions for this problem? Any help is greatly appreciated!
Marcel
    Jul 25, 2010 12:05 AM   in reply to www.marcelvanduijn.com
    That bug will be fixed in 3.6.  I think you can add your own high priority
    handler and stopImmediatePropagation on the event.
    Jul 25, 2010 9:40 PM   in reply to www.marcelvanduijn.com
    Here's the bug: https://bugs.adobe.com/jira/browse/SDK-25373
    I wouldn't catch CREATION_COMPLETE, I would catch the ENTER_FRAME going to
    the app, test if stage == null and call stopImmediatePropagation if it is.
    Jul 26, 2010 10:00 AM   in reply to www.marcelvanduijn.com
    Thanks for the points.  I think you could have skipped the added to stage
    handler and simply tested if stage != null in the enterFrame handler and
    removed the enterframe listener if true.
    Jun 14, 2013 10:31 AM   in reply to www.marcelvanduijn.com
    Brilliant thanks a lot man works like a charm!
