The web site you are accessing has experienced an unexpected error.
Please contact the website administrator.
The following information is meant for the website developer for debugging purposes. | ||||||||||||||||||||
Error Occurred While Processing Request | ||||||||||||||||||||
ColdFusion Server Enterprise | 8,0,0,176276 |
Template | /PTE/DWA/index.cfm |
Time Stamp | 26-Jul-10 02:35 PM |
Locale | English (US) |
User Agent | Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.2; Win64; x64; SV1; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729) |
Remote IP | 127.0.0.1 |
Host Name | 127.0.0.1 |
14:35:19.019 - coldfusion.runtime.TemplateNotFoundException - in : line -1
File not found: /PTE/DWA/index.cfm
CGI Variables:
AUTH_PASSWORD=
AUTH_TYPE=
AUTH_USER=
CERT_COOKIE=
CERT_FLAGS=
CERT_ISSUER=
CERT_KEYSIZE=
CERT_SECRETKEYSIZE=
CERT_SERIALNUMBER=
CERT_SERVER_ISSUER=
CERT_SERVER_SUBJECT=
CERT_SUBJECT=
CF_TEMPLATE_PATH=\\hyfs001\tetools\ttc_old\PTE\DWA\index.cfm
CONTENT_LENGTH=0
CONTENT_TYPE=
CONTEXT_PATH=
GATEWAY_INTERFACE=CGI/1.1
HTTPS=off
HTTPS_KEYSIZE=
HTTPS_SECRETKEYSIZE=
HTTPS_SERVER_ISSUER=
HTTPS_SERVER_SUBJECT=
HTTP_ACCEPT=image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/x-ms-application, application/vnd.ms-xpsdocument, application/xaml+xml, application/x-ms-xbap, */*
HTTP_ACCEPT_ENCODING=gzip, deflate
HTTP_ACCEPT_LANGUAGE=en-us
HTTP_CONNECTION=Keep-Alive
HTTP_COOKIE=CFADMIN_LASTPAGE_ADMIN=%2FCFIDE%2Fadministrator%2Fsettings%2Fmappings%2Ecfm
HTTP_HOST=localhost
HTTP_REFERER=
HTTP_USER_AGENT=Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.2; Win64; x64; SV1; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
PATH_INFO=/PTE/DWA/index.cfm
PATH_TRANSLATED=\\hyfs001\tetools\ttc_old\PTE\DWA\index.cfm
QUERY_STRING=
REMOTE_ADDR=127.0.0.1
REMOTE_HOST=127.0.0.1
REMOTE_USER=
REQUEST_METHOD=GET
SCRIPT_NAME=/PTE/DWA/index.cfm
SERVER_NAME=localhost
SERVER_PORT=80
SERVER_PORT_SECURE=0
SERVER_PROTOCOL=HTTP/1.1
SERVER_SOFTWARE=Microsoft-IIS/6.0
WEB_SERVER_API=
Cookie Variables:
CFADMIN_LASTPAGE_ADMIN=/CFIDE/administrator/settings/mappings.cfm
1) Installed CF-8. I am able to access CF Admin page.
2) Created required DSN's successfully.
3) Installed IIS and working fine.
4) Copied the config file from production machine (Which is working fine) and created the a new web site on a new machine which is failing with below stack trace error message when tried to access the web site.
What else need to to be done ? Am I missing anything ?
Regards,
Srikanth Temkar
See what / maps to on your admin page. Then make sure the directories and file are in the right spot.
by default these are two mappings
/CFIDE | C:\Inetpub\wwwroot\CFIDE | |
/gateway | C:\ColdFusion8\gateway\cfc |
i am actually browsing the cfm page from another server.
can you tell me how to do mapping for another server. i have given the default name and .directory path as \\servername\somedirectory.
but its not working.
Is the home directory of your site setup in IIS to be \\hyfs001\tetools\ttc_old\ ?
Does the ColdFusion Application Server service have sufficient rights to access \\hyfs001\tetools\ttc_old\ ?
Can you access non-ColdFusion content such as static HTML pages on the site? Knowing this could tell us if this is a CF issue or an IIS issue.
i am able to browse the html pages but not the cfm pages
