jmituzas
Exporting individual pages to PDF / Indesign
Jul 26, 2010 12:49 PM
Have downloaded some sample scripts from
http://www.adobe.com/products/indesign/scripting/index.html
This is all well and all but it creates a document and prints it as individual pdf files. Yes this is what I wanted but how can I change the script to either let me browse for or call to my own already created .indd file?
Please help.
Thanks in advance,
regards,
jmituzas
    Jul 26, 2010 10:30 PM   in reply to jmituzas
    Find below code, now this will run on open indesing file.
    //ExportEachPageAsPDF.jsx
    //An InDesign CS4 JavaScript
    //Exports each page of an InDesign CS document as a separate PDF to
    //a selected folder using the current PDF export settings.
    //Display a "choose folder" dialog box.
    main();
    function main(){
        mySnippet();
    function mySnippet(){
         //<fragment>
         var myPageName, myFilePath, myFile;
         var myDocument = app.activeDocument;
         var myBaseName = myDocument.name.replace(/\.indd/, "");
         var myPDFExportPreset = app.pdfExportPresets.item("[Press Quality]");
         for(var myCounter = 0; myCounter < myDocument.pages.length; myCounter++){
              myPageName = myDocument.pages.item(myCounter).name;
              app.pdfExportPreferences.pageRange = myPageName;
              //The name of the exported files will be the base name + the
              //page name + ".pdf". If the page name contains a colon (as it will
              //if the document contains sections), then remove the colon.
              var myRegExp = /:/gi;
              myPageName = myPageName.replace(myRegExp, "_");
              myFilePath = Folder.desktop + "/" + myBaseName + "_" + myPageName + ".pdf";
              myFile = new File(myFilePath);
              myDocument.exportFile(ExportFormat.pdfType, myFile, false, myPDFExportPreset);
    Shonky
    Aug 5, 2010 11:03 PM   in reply to jmituzas
    You can select InDesign file with below code:
    var myINDDfile = File.openDialog( 'Select InDesign file','*.indd',false);
    Shonky
    Jan 23, 2011 12:42 PM   in reply to Shonkyin
    Shonky (or anyone!!)...
    How can I open a dialogue to choose a path to where I would like the output PDF files to be saved??
    Jan 23, 2011 1:28 PM   in reply to mrdior
    Scratch that. I found the solution here... after coming up empty-handed in the ID Scripting Tutorial...
    var myPath= Folder.selectDialog ("Choose a Folder");
    myPath = myPath + "/";
