I have a potential job working on a large book layout that includes a tremendous amount of Hebrew and Greek. The client has already started the book in his Indesign CS4 ME and says that I would need to also have ME so that I can work on the book as well. This appears to be a deal breaker because I can't afford the $1000 it would take for me to buy ME, nor am I likely to use it for any other job. If I have the regular CS4 suite, can I work on his book, if he does the Hebrew on his ME copy? Will my Indesign properly work with the Hebrew text if it was typeset in the ME version? He sent me a sample of the book, and I've opened it in CS4 with no problem, but I've never worked with Middle Eastern languages, so I don't know what to look for to see if it's messing up.
Advice from someone who works with these languages would be very much appreciated. I seem to recall a discussion thread long ago having to do with language plugins for the standard InDesign. Was something ever done with that? I need to know if I can take this job or not.
I've downloaded a demo of World Tools and it seems to be working (as far as I can tell). I quite honestly don't know what I'm doing with the Hebrew, but my client can read it and correct things (he has ME). I'm just curious . . . can I create hanging indents in RTL? In some of the tables that the client has already done in ME, he has manually spaced out hanging indents from the right, and I cringe when I see such things.
It's possible that the download link was never updated to the newest version.
Try this version: http://in-tools.com/indesign/plugins/worldtoolscs4.zip
The option appears under World Tools > Paragraph > First Line Indent...
Harbs
Innovations in Automation
Harb, my client says he doesn't use the hanging indent because neither the plugin or ME break the Hebrew words in the correct places. I've sent him an email explaining the benefits of using a hanging indent and "no break" and forced line breaks rather than the paragraph breaks and spaces. I hope he was just ignorant of those extra tools in ID. However, I'm wondering if you can explain why ID doesn't break the Hebrew correctly. Is it because it's not using the proper dictionary? It would seem to me that ME should have all the proper dictionaries for word breaking, but I don't know much about it, myself.
By "breaking Hebrew words", do mean hyphenation?
I don't know what kind of layout you are doing, but the concept of hyphenation in Hebrew is simply WRONG.
The Israelis have decided that it's possible to break words that have no vowels, but the fact of the matter is that it's impossible to read hyphenated Hebrew without first reading the next line.
The only place I've ever seen Hebrew hyphenated is in newspapers with very narrow columns. My personal opinion is that it's wrong even there, but no-one asked me... ![]()
Harbs
There's a bug in the World Ready Composer (both in the Roman and ME versions) and it does not doesn't work correctly with certain text encoding sequences. If these encodings are used, it is not recognized as the part of a Hebrew word. The text can therefore break in mid-word. The problematic encoding range is FB20 - FB4F. Do not use this range of encoding when using Hebrew. This range contains all "combination glyphs" and "alternate glyphs".
Here's a bit more explanation:
There are combination letters in Hebrew that can be encoded in more than one way. Your example shows a "shin". A "shin" is composed of two glyphs -- a shin and a shin-dot (as opposed to a "sin" which is composed of a shin and a sin dot). When a shin is encoded as <05E9><05C1> (shin-shin dot), it is composed correctly. When it is encoded as <FB2A> (combination shin - shin dot), the text can break in mid word. The workaround is to replace all combination encoded characters to the two-glyph equivalents.
HTH,
Harbs
Hi Harbs,
did you make tests with different fonts (e.g. fonts of MasterFont)?
Some months ago I have run into trouble with some combinations of characters with vowel diacritics.
At least we have found out that this has been caused by the used font and not by features of InDesign and the World Ready Composer.
Could you send an example text to me so that I could do a test with my fonts?
Did you report this to Adobe or WinSoft?
Best
Martin
Hi Martin,
Yes. I have observed these problems using different fonts (including Masterfont's fonts).
There are no vowel combining glyphs. Problems with vowels are usually due to non-OpenType or poor quality fonts.
FWIW, for quality Hebrew fonts, I recommend Masterfont (http://masterfont.co.il/) Fontbit (http://fontbit.co.il/) and Fontype (http://fontype.co.il).
Fontype in particular, has created some pretty incredible Hebrew OpenType fonts.
Harbs
Yes. You can use Search & Replace.
Search for "<FB2A>" and replace with "<05E9><05C1>".
You will have to repeat this search & replace with all the composite glyphs used.
These are the shin related ones:
<FB2A> --> <05E9><05C1>
<FB2B> --> <05E9><05C2>
<FB2C> --> <05E9><05C1><05BC>
<FB2D> --> <05E9><05C2><05BC>
Harbs
Here is a script that does all the find/changes. You should probably do it on a copy and send the copy to your client to make sure the font he is using supports both types of glyphs.
myDoc =app.activeDocument
findGrep ("\\x{FB31}", "\\x{05D1}\\x{05BC}")
findGrep ("\\x{FB32}", "\\x{05D2}\\x{05BC}")
findGrep ("\\x{FB33}", "\\x{05D3}\\x{05BC}")
findGrep ("\\x{FB34}", "\\x{05D4}\\x{05BC}")
findGrep ("\\x{FB35}", "\\x{05D5}\\x{05BC}")
findGrep ("\\x{FB36}", "\\x{05D6}\\x{05BC}")
findGrep ("\\x{FB38}", "\\x{05D8}\\x{05BC}")
findGrep ("\\x{FB39}", "\\x{05D9}\\x{05BC}")
findGrep ("\\x{FB3A}", "\\x{05DA}\\x{05BC}")
findGrep ("\\x{FB3B}", "\\x{05DB}\\x{05BC}")
findGrep ("\\x{FB3C}", "\\x{05DC}\\x{05BC}")
findGrep ("\\x{FB3E}", "\\x{05DE}\\x{05BC}")
findGrep ("\\x{FB40}", "\\x{05E0}\\x{05BC}")
findGrep ("\\x{FB41}", "\\x{05E1}\\x{05BC}")
findGrep ("\\x{FB43}", "\\x{05E3}\\x{05BC}")
findGrep ("\\x{FB44}", "\\x{05E4}\\x{05BC}")
findGrep ("\\x{FB46}", "\\x{05E6}\\x{05BC}")
findGrep ("\\x{FB47}", "\\x{05E7}\\x{05BC}")
findGrep ("\\x{FB48}", "\\x{05E8}\\x{05BC}")
findGrep ("\\x{FB49}","\\x{05E9}\\x{05BC}")
findGrep ("\\x{FB4A}","\\x{05EA}\\x{05BC}")
findGrep ("\\x{FB4B}", "\\x{05D5}\\x{05B9}")
findGrep ("\\x{FB2A}","\\x{05EA}\\x{05C1}")
findGrep ("\\x{FB2B}","\\x{05EA}\\x{05C2}")
findGrep ("\\x{FB2C}","\\x{05EA}\\x{05C1}\\x{05BC}")
findGrep ("\\x{FB2D}","\\x{05EA}\\x{05C2}\\x{05BC}")
function findGrep(find, change){
app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.nothing;
app.findGrepPreferences.findWhat = find;
app.changeGrepPreferences.changeTo = change;
myDoc.changeGrep();
I just saw your post here with this sample. Im working on a hebrew book and im trying to set up the text with a style exactly as you have shown here. I have worked out how to do it manually, but i need to know how to set a style for it so it can be used throughout the book. Do you know how to do it?
If anyone has this issue some time in the future, the fact is that these combo glyphs LOOK better. I have a workaround which I've used to keep the combos and drop the breaks in middle of words - set the paragraph style to nobreak, and run a grep style for all spaces to "yes break." This keeps all words together, no matter what characters are in them.
North America
Asia Pacific
