Webkinzhodder
Repoussé on Photoshop CS5 Extended Won't Work
Aug 1, 2010 6:12 PM
I'm trying to make text on my project 3D, but when I go to the 3D menu, Repoussé is gray and I can't click it. Other people are saying to enable OpenGL Drawing, but I have no idea what that is or how to get it. Please help!!!
    Aug 1, 2010 11:54 PM   in reply to Webkinzhodder
    Photoshop – Preferences – Performance
    There is a field titled GPU Settings, therein check Enable OpenGL Drawing.
    Aug 2, 2010 8:22 AM   in reply to Webkinzhodder
    That, I’m afraid, might indicate that your graphic card does not support OpenGL.
    Check for your card on this list:
    http://kb2.adobe.com/cps/831/cpsid_83117.html
    Aug 2, 2010 8:44 AM   in reply to Webkinzhodder
    You should still be able to use some of the 3D-features, like 3D – New Shape From Layer, to create simpler forms like cubes and cones or Place 3D-models, but to use Repoussé you might have to invest in a new video card.
    Nov 17, 2010 12:18 PM   in reply to c.pfaffenbichler
    I have enabled OpenGL Drawing, but still the same, repousse is grey!
    Is there any trick to use it?
    Regards
    Alex
    Nov 18, 2010 10:44 PM   in reply to Alex_Reds
    Hi Alex,
    Have you tried creating a Shape layer or Text layer first, then seeing if Repoussé is active?
    regards,
    steve
    Dec 10, 2011 6:55 PM   in reply to Webkinzhodder
    It may have nothing to do with open GL at all.  I was jsut having the same problem and I solved it by switching form CMYK back to RGB.
    Problem solved - 3D works perfectly again
    Jan 28, 2012 3:02 AM   in reply to SG...
    Hi Steve,
    Thanks for the reply, and sorry for the delay in one year with the answer )
    Now it seems sorted, I created a shape, rasterized it and Repousse seems is active. I can see all 3D modeliing tools.
    Rehards
    Alex
    Jan 5, 2013 4:38 PM   in reply to c.pfaffenbichler
    I need a quick help over here ..i have Adobe Photoshop CS5.1 Extended,,and i have 3D tab at top ..but when i (ex.) type something with Type tool...and i do all steps that i want to create 3D text..and when i click on 3D tab..and all options are GRAY ..and i canno't use response ...or any other options..and in prefrences OpenGL is enabled .and everything is Ok..and my video card is ATI Radeon HD 4300/4500 ..and when i go to upgrade my card it says that video card is up to-date ...if someone know maybe to help me or something..i will be very happy .THANKS FORWARD!!
    Apr 1, 2013 12:09 AM   in reply to c.pfaffenbichler
    Where can i found the preferences?
