Move Tool does not move layer when dragging with Wacom tablet
Jan 14, 2013 5:01 PM
  Latest reply: Harpua42, Dec 13, 2013 10:25 AM
Replies 1 2 3 4 Previous Next
    Mar 10, 2011 3:17 PM   in reply to billyokcom
    Thanks for that info. For those of you on this forum who have noticed that the problem happens even after unplugging your tablet, are you running iCopy (or any other apps that may contribute to the problem)?
    Please let me know what you find out.
    Mar 10, 2011 3:19 PM   in reply to Jeanne Rubbo
    I do not have or run iCopy...  It seems to be irrelevant if I have background applications running or not.
    Mar 10, 2011 3:23 PM   in reply to TheFlash12345
    Same here no other apps
    Apr 6, 2011 10:10 AM   in reply to billyokcom
    thank you! i recently installed icopy and this started happening. been driving myself crazy trying to figure it out. so glad i came across this thread and your post.
    Apr 6, 2011 10:11 AM   in reply to Jeanne Rubbo
    yes, i just quit icopy and it resolved the issue.
    Apr 6, 2011 10:16 AM   in reply to Jeanne Rubbo
    there's a preference in icopy called "capture mouse drags" that appears to be causing this. when checked, it tries to copy any item you click and drag, system-wide. with this disabled, and icopy running, i am able to drag layers again.
    Apr 9, 2011 4:34 PM   in reply to hirshmon
    Just solved this problem! It's because of the wacom pen tablet driver i closed it in the activity monitor and the stupid snapback disapeared. down side is that the tablet won't work for obvious reasons i sugest we demand a solution from wacom on their forums.
    Apr 17, 2011 7:52 AM   in reply to hirshmon
    Same issue with me. I am on Mac OS with photoshop CS5 . The issue is due to iCopy app and disabling the drag mouse checkbox stopped this problem. Its big confusion.
    Apr 27, 2011 8:41 AM   in reply to hirshmon
    I echo this sentiment
    Apr 27, 2011 8:47 AM   in reply to TheFlash12345
    Hirshmon and The Flash, your issue is not related to iCopy? Do you have any other system utilities/drivers installed?
    Apr 27, 2011 8:56 AM   in reply to hirshmon
    We don't know of any specifics (other than we've seen iCopy cause this issue, and FinderPop cause others), but we do know this problem is system specific (i.e. not all customers are having this issue).
    Can you do a screen shot of your "System Preferences" dialog? Usually, they show up under "Other" in the bottom column.
    Apr 27, 2011 9:08 AM   in reply to hirshmon
    What is Candelair? It may be conflict between the Wacom driver and another driver or utility.
    Apr 27, 2011 9:28 AM   in reply to hirshmon
    I am also having the same issue but do nothave InCopy installed. For me the issue is that I have a Wacom tablet installed in my office. When I unplug and leave the office without rebooting I encounter this error. If I reboot without the Wacom plugged in, it does not occur.
    Attached is my system prefs screenshot also:
    Apr 27, 2011 10:40 AM   in reply to hirshmon
    Wouldn't hurt to try. Eliminating all possible culprits is a good approach.
    Apr 27, 2011 11:03 AM   in reply to Jeffrey Tranberry
    I do not have icopy installed or any other of the referenced programs that others are discussing, and I still have the problem.  Not to mention the only program that is affected is photoshop... my machine shouldn't be in the influencing factor if the only program affected is photoshop, regardless if some conflict exists somewhere in my machine.  If only photoshop is having troubles with a conflict, then it's my opinion that photoshop should resolve this conflict.
    Apr 27, 2011 11:45 AM   in reply to TheFlash12345
    No, that is bad logic.
    Bugs in the OS or other applications can cause problems that only seem to happen in a single application (it depends on the details of the bug). And they sometimes are such that the affected application cannot work around the original bug.  If we can work around external bugs, we do.
    Jun 10, 2011 12:21 AM   in reply to hirshmon
    I've been using CS5 with a Wacom Intuos 3 for a while with none of these issues, however today got a Cintiq and it started happening right away. A full reboot made it go away momentarily, but not for long. I'm getting the snapping issue as well as the brush not being able to draw with the trackpad.
    It's been almost a year since this problem came up, please fix this!
    Moving an object WILL work when you hit cmd+t and it's under Transform. It will also move an object when in a Mask.
    Jun 10, 2011 3:15 AM   in reply to hirshmon
    I use CS4, works perfectly
    Jun 10, 2011 11:46 PM   in reply to hirshmon
    I also have the problem. No iCopy or Candelair. But I do use an Intuos 4.
    Move tool snaps back and brush tools (brush, clone, eraser, etc) can only make dots, not paint continuous. I guess because the tool is also unable to move or is snapping back to place.
    I work with an external keboard, external monitor and the tablet, not using the trackpad.
    MacBook Pro
    10.6.7
    PS 12.04
    Latest Wacom Driver
    Topaz Detail
    Topaz Denoise
    Lightroom
    Firefox
    Safari
    Entourage
    Restarting PS gets a temporary fix.
    Jun 16, 2011 7:02 AM   in reply to hirshmon
    Exact same problem again here. Latest everything installed and no extras/plugins. I have an Intuos tablet though.
    The tablet and my magic mouse work fine - it's just the trackpad.
    This has to be a PS bug surely? Command-T transform works fine, as does dragging out a selection marque.
    Jul 29, 2011 3:31 PM   in reply to hirshmon
    I think the best option is moving by "Ctrl+t"
    Oct 4, 2011 9:46 AM   in reply to hirshmon
    I am still seeing this issue using Photoshop CS5 v12.0.4 x64 with the latest Wacom Bamboo driver v.5.2.5-3.
    Mar 9, 2012 2:19 PM   in reply to gmanacsa
    are u running Lion?  Wacom drivers not compatable with Lion.
    G
    [Moderator] Recent Wacom drivers (since Driver 6.1.6-4 from 22 Nov 2010) are compatable with Lion (10.7), Snow Leopard (10.6), and Leopard (10.5).
    Oct 5, 2011 5:57 AM   in reply to Grant H
    No, I'm running on Snow Leopard 10.6.8 on a 2010 Macbook Pro.
    Oct 25, 2011 1:27 PM   in reply to hirshmon
    Hi Thanks for bringing this issue. I am having same issue when I plugged in my Intuos4 with Photoshop. If Intuos is unplugged everything is working normal but when I plug it in, I can't move stuff with my trackpad (still able to move with pen and arrow keys) along with other issues people are reporting here.
    Please fix this issue ASAP.
    Thanks, Harjinder
    Nov 24, 2011 9:25 AM   in reply to hirshmon
    Hi everyone,
    I'm experiencing the same problem with the snapping using Photoshop CS5 with the Wacom Intuos 4. Objects will not move properly after a while of usage, resulting to having to shut down the program and start again (problems starts again shortly after).
    Has there been a solid solution to this problem yet?
    Specs:
    - Latest Wacom driver installed
    - Lion latest version
    - Photoshop CS5 (latest installment)
    - No additional apps besides internet browsing
    Jan 2, 2012 1:45 PM   in reply to hirshmon
    Same here......   disconnect the cintiq and restart photoshop and the move tool & trackpad line works.  PLEASE FIX THIS!
    Feb 3, 2012 10:10 AM   in reply to hirshmon
    Has there been any fix for this?
    I'm experiencing the same issues of layers snapping back, and pen lines not appearing that @hirshmon described.
    My specs:
    • Wacom Cintiq 21UX (as well as 12 UX at home)
    • 15" MBP running Snow Leopard
    • CS5
    An update from Adobe staff would be reassuring!
  • Pierre Courtejoie
    Jan 11, 2006
    Feb 3, 2012 10:18 AM   in reply to craightonberman
    Did you contact Wacom about the issue, as well?
    Feb 3, 2012 10:29 AM   in reply to Pierre Courtejoie
    I have not, as it seems to only be an issue in Photoshop CS5—no other programs are affected. If an Adobe representative replies to the thread and confirms this is still an outstanding issue, I'll try out Wacom's help forum next for sure.
    Feb 3, 2012 11:09 AM   in reply to hirshmon
    I too have this problem, and it's very annoying. I'm using a Wacom Intuos 4 tablet and an Apple magic trackpad with Photoshop CS5.1 on a mac running Lion Server 10.7.3.
Actions
Bookmarked By (2)
