eybs
Photoshop CS5 won't open .psd files
Aug 4, 2010 3:42 AM
Bascially I click on a psd file to open with photoshop, photoshops opens then shows this error message
These are my specs:
Model: iMac, 4 processors, Intel Core i7, 2.8 GHz, 4 GB
Graphics: ATI Radeon HD 4850, ATI Radeon HD 4850, PCIe, 512 MB
These are the details of the problem report:
Process:         Adobe Photoshop CS5 [482]
Path:            /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/MacOS/Adobe Photoshop CS5
Identifier:      com.adobe.Photoshop
Version:         12.0.1 (12.0.1)
Code Type:       X86-64 (Native)
Parent Process:  launchd [111]
Date/Time:       2010-08-04 10:50:24.215 +0100
OS Version:      Mac OS X 10.6.4 (10F569)
Report Version:  6
Interval Since Last Report:          91551 sec
Crashes Since Last Report:           12
Per-App Interval Since Last Report:  8870 sec
Per-App Crashes Since Last Report:   12
Exception Type:  EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Application Specific Information:
*** error for object 0x107419e00: incorrect checksum for freed object - object was probably modified after being freed.
Model: iMac11,1, BootROM IM111.0034.B02, 4 processors, Intel Core i7, 2.8 GHz, 4 GB, SMC 1.54f36
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 2.1.9.8.1
Bluetooth: Version 2.3.3f8, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: WDC WD1001FALS-40U9B0, 931.51 GB
Serial ATA Device: OPTIARC DVD RW AD-5680H
USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfd100000
USB Device: Ext HDD 1021, 0x1058  (Western Digital Technologies, Inc.), 0x1021, 0xfd130000
USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0xfd120000
USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0xfd110000
USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfa100000
USB Device: Composite Device, 0x0471  (Philips Consumer Electronics), 0x083f, 0xfa130000
USB Device: Internal Memory Card Reader, 0x05ac  (Apple Inc.), 0x8403, 0xfa120000
USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000
USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8215, 0xfa111000
    Aug 4, 2010 5:07 AM   in reply to eybs
    Which trouble-shooting steps have you taken thus far (trashing prefs, repairing permissions, checking fonts etc.)?
    Aug 4, 2010 5:47 AM   in reply to eybs
    Repairing permissions is System maintenance and can be performed with Disc Utility or free programs like Onyx, which can also be used o run Cron Scripts, delete caches etc.
    http://www.apple.com/downloads/macosx/system_disk_utilities/onyx.html
    Yes I've check all though preferences
    What do you mean by »checking«?
    Aug 4, 2010 6:18 AM   in reply to eybs
    Have the files been saved locally or on a server?
    If the files have been corrupted this won’t help, but once again: What do you mean by »checking« with regard to the preferences?
    Have you deleted them a restart or not?
    Aug 4, 2010 6:34 AM   in reply to eybs
    As with all unexplainable Photoshop-problems You might try trashing the prefs (after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved and making a note of the Preferences You’ve changed) by pressing command-alt-shift on starting the program or starting from a new user-account.
    Aug 4, 2010 7:11 AM   in reply to eybs
    That seems doubtful; at least in case the files have been corrupted it
    wouldn’t make a difference.
    Are the files still their expected size in MB in the Finder?
    Could you try duplicating the file in Finder and see if the duplicate
    can be opened?
    Aug 4, 2010 7:44 AM   in reply to eybs
    Are the files you are opening contain text layers?
    Aug 4, 2010 8:38 AM   in reply to eybs
    It's possible you have a bad font:
    http://kb2.adobe.com/cps/843/cpsid_84363.html
