Change artboard order/numbers
Aug 4, 2010 5:12 AM
I'm currently working on a project which involves over 16 artboards in the same document, though when i want to change the order of the artboards [for saving as a PDF] i have to move all my artboards content to new artboard, etc.etc.
This is really annoying, especially when i want to insert a new artboard between some excisting ones.
So is it possible to somehow change the order of the artboards, or they numbers [basically the same]?
Please let me know ASAP!
    Aug 4, 2010 6:55 AM   in reply to kas8
    If you are in CS5, the Artboard panel will help you do what you want.
    Otherwise, you might find it easiest to simply make your pdf and reorder the pages in Acrobat. It's quite easy, just open the page navigation panel and drag the pages to the order you want.
    Aug 4, 2010 7:06 AM   in reply to kas8
    Yes you can create or modify security settings in Acrobat. it's really an Acrobat thing, anyway. Illustrator can do it from the save as PDF dialogue, but it's really calling on Acrobat's features to do that.
    If you open the pdf in Acrobat and right click anywhere on the page you can access document properties. One of the tabs of this pop up menu is for security. it should look familiar and be manageable.
    good luck.
    Aug 4, 2010 7:10 AM   in reply to kas8
    Maybe not what you want to hear, but this sounds like a job for InDesign. InDesign would do all of these things easily. I would keep all the art in AI and them place them in InDesign pages.
    Mar 1, 2011 12:22 AM   in reply to kas8
    I realize that this is an old thread, but there is a "poor man's trick"
    to reorder the artboards in Illustrator CS4 without the use of Acrobat or other software.
    You will have to delete your artboards in artboard tool (edit) mode,
    but be sure to DEselect the "Move/Copy Artwork With Artboard" button.
    When this button is deselected, you can easily delete the artboards,
    but leave the content intact.
    Delete all artboards, but leave the artboard that you want to have
    as artboard #1 as the undeleted artboard.
    (AI CS4 requires that you keep at least one artboard active.)
    Following this, draw each successive artboard in turn over your content
    (which should all be intact). You can use the New Artboard button on the
    toolbar to insert a new artboard at the dimensions you specify.
    Make sure that you draw the artboards in the exact order that you
    wish the artboards to be ordered in your PDF or resulting output.
    I realize it's a little troublesome, but I just did the same thing with
    a 12-page document, and it took less than 10-15 minutes.
    Now that I've reordered the artboards, I can output to PDF or
    other image files, and the order remains intact.
    Hope this helps!
    Jeff
    Mar 27, 2011 4:51 PM   in reply to kas8
    If you are on a mac open the PDF in preview, open the sidebar with the page thumbnails, and drag them in the order you wish. Save.
    Mar 27, 2011 5:22 PM   in reply to kas8
    InDesign is hard compared to Illustrator, like graphite is hard compared to diamonds.
    Mar 30, 2011 11:29 AM   in reply to kas8
    If the 'reviving' post adds something new, what is the problem?
    If was not allowed to contribute, then why it is not auto locked after 30~60days or vanish it from Search?
    The post that explained about the CS4 trick about deleting all and re-doing helped me a lot since i'm in CS4, not 5.
    Mar 30, 2011 3:45 PM   in reply to DarkDragonLord
    I agree completely.
    Some people get uptight when others contribute to
    "old" threads, but if the conversation is helping someone,
    what's the big deal?
    The only issue with old threads is that replies are not
    as likely to be spotted so easily.
    It's funny how everybody is treating CS4 as "old software"
    now, where the deficiencies in artboard functionality
    were magically solved with CS5. True, CS5's Artboard
    panel is convenient, but why must we always have to
    throw money at the problem? (I know, some people
    will tell me, "you don't have to upgrade, you know"...
    but that's missing the point.) It would be oh-so-delightful
    if we could enjoy added functionality (such as with the
    Mac App Store) without having to "repurchase" the software.
    Jeff
    Mar 31, 2011 1:26 AM   in reply to japchap
    for those still using "old software" I wrote a script based on Jeff's "poor man's trick" to reorder CS4 artboards. For best results, click on the Artboard tool before running, happy reordering.
    #target illustrator
    // var script.name = reArrangeArtboardsCS4only.jsx;
    // var script.description = reArranges the Artboards indexes;
    // var script.required = an open document with at least 2 artboards, CS4 only, not tested in CS5;
    // var script.tip = click on the Artboard tool, before running, to see the AB Indexes
    // var script.parent = CarlosCanto; // 3/31/11
    // var script.elegant = false;
    var idoc = app.activeDocument;
    var abs = idoc.artboards;
    var abcount = abs.length; // save the artboard count
    j=1; // new AB order number, used for buttons labels
    var btn = []; // left buttons to show AB count
    var btn2 = []; // right buttons to set the new order
    var win = new Window("dialog","ReArrange Artboards ");
    var panelOgOrder = win.add("panel");
    var panelNewOrder = win.add("panel");
    win.orientation = "row"; // default is column, change to row
    win.onClose = onCloseFunction;
    for (i = 1 ; i<=abcount; i++) // add as many buttons as ABs
              btn[i] = panelOgOrder.add("button",undefined,"AB " + i, {name: i}); // named to know wich button was pressed
              btn2[i] = panelNewOrder.add("button",undefined, "Set Order", {name: i-1}); // -1, to use on 0 based Artboards
              btn[i].helpTip = "click for help";
              btn2[i].onClick = onClickButton; // add event listener
              btn[i].onClick = onClickButton1test;
    win.show();
    function onClickButton() // add AB and set button label from 1 to AB count
              this.text = j; // change button label from "Set Order" to 1,2, to AB count
              this.enabled = false; // disable to prevent clicking twice
              idoc.artboards.add(abs[this.properties.name].artboardRect); // duplicate AB, which one? 3rd button pressed, 3rd AB
              app.redraw();
              j = j+1; // add to the counter
              if (j>abcount) // after duplicating the AB, delete the originals
                   win.close();
                   for (k=abcount-1; k>=0; k--)  // loop thru original ABs
                             idoc.artboards.remove(k); // and delete
                             //app.redraw();
    function onClickButton1test()
              //alert(this.properties.name);
              var msg = "Click the buttons on the right in the order \r";
              msg = msg + "you want the Artboards to be Re-Arranged. \r";
              msg = msg + "You are required to click all the buttons";
              alert(msg);
    function onCloseFunction()
              if (j>1 && j<=abcount)
                   var msg2 = "You shouldn't close the window. \r";
                   msg2 = msg2 + "You should finish clicking all the buttons, \r";
                   msg2 = msg2 + "other wise you'll end up with extra Artboards. \r";
                   msg2 = msg2 + "If you must close, undo to get rid of extra Artboards. \r \r";
                   msg2 = msg2 + "Are you sure you want to close this window?";
                   close = confirm(msg2);
                   if (close == false)
                        return false;
    Mar 31, 2011 5:07 AM   in reply to CarlosCanto
    Fascinating, and an interesting solution, Carlos.
    I'm very impressed with your scripting skills!
    Although your script is certainly useful as-is with a small number
    of artboards, I noticed a few things that perhaps you might like
    to look at, to make the script even better.
    - While running the script and clicking on the artboard numbers in the order you want,
       the artboard numbers on the actual artboard seem to be changed to numbers
       in reverse order, which is confusing. So basically, you have two things
       going on: the renumbered script order on the JavaScript dialog, and
       the actual artboard script numbers, which appear to change dynamically
       even before the script is finished running.
       It would be less confusing if the actual artboard numbers didn't change until
       you pressed an "Execute" button or something. Maybe you could store the
       new artboard sequence in a temporary array, and then actually commit the changes
       when clicking "Execute" or "Save".
    - A "Cancel" button might be nice, in case the user messes up :-)
    - Clicking the buttons in order is interesting; but it might be even easier to understand
      if these were all text boxes, and the user typed in the new numbers to allocate to the
      old numbers...
    Makes me wish I knew more about JavaScript, so I could collaborate on this with you ;-)
    Anyway, it is really cool to see that someone like yourself is interested in providing
    solutions for people who don't want to - or can't - make the switch to CS5!
    Jeff
    Mar 31, 2011 11:58 AM   in reply to japchap
    Hi Jeff, thanks for the feed back, I appreciate all your comments.
    - point 1 - let me explain how it was intended to work to avoid confusion. The interface has nothing to do with the physical placement of the artboards and the buttons on the left with the labels "AB 1" etc.. are irrelevant, they're just a visual to know what button on the right you're clicking.
    In the screen shot I provided, I have 4 artboards and the indexes go 4, 3, 2, 1 from left to right. I had already reversed the order that originally was 1, 2, 3, 4 from left to right.
    So this is the mechanics to switch AB 4 with AB 3 in my screen shot to have the order 3, 4, 2, 1 from left to right. Looking at the indexes,
    - is AB 1 in the right order? yes, click on the button next to it
    - is AB 2 in the right order? yes, click on the button next to it
    - is AB 3 in the right order? NO, I want AB 4 to become 3rd, click on the button next to AB 4
    and so on, confusing?
    - to avoid the AB numbers to change as you click (just visually), comment out line 42
         //app.redraw();
         yeah, if the user changes its mind half way thru, not making the actual changes would help. I thought of that, but I figured since it is easy to reArrange...well...just do it again as punishment
    - point 2 - even if I said one's required to click all the buttons, I kind of lied , you can still close the window by clicking on the X at top. I realize that after I made a test with a ridiculous amount of artboards and the buttons couldn't fit on the dialog. If the user messes up, no problem, undo is our friend. It could be incorporated into the dialog.
    - point 3 - text boxes is a very interesting suggestion...version 2 perhaps?
    hope it helps to clarify the Usage of the script, also clicking on the buttons on the left brings up "help". Thanks again for the feedback.
    Mar 22, 2012 4:31 PM   in reply to japchap
    Excellent. Your solution works best for me. Four pages done lickedy split!!
    Apr 26, 2012 3:02 PM   in reply to kas8
    You know, this issue is EXACTLY what is wrong with Adobe! Of course, I have to use their products, but it seems like they have nothing over there but engineers.... WHY ON EARTH WOULD YOU NEVER CONSIDER THE POSSIBILITY THAT PEOPLE MIGHT WANT TO CHANGE THE PRINT ORDER OF THEIR ARTBOARDS!
    I was not looking forward to joining the "Upgrade of the Week Club", yet you guys seem to hold back fixes like this until the next version is out so we all have to pay for what should have been there in the first place!
    Freehand is years old and I STILL prefer its drawing paradign to the clunky, multi-tool,modal approach you have foisted upon all us designers.
    I almost messed up a print job because of this studip idiosyncrasy in your software!
    Booo! And shame on you guys! Get some practicing designers in some focus groups, or discussions, or SOMETHING! What is most efficient for coding and development is NOT most efficient for the users!
    This makes me so mad, I want to spill Jolt Cola all over every one of the keyboards in the application design department! (Which of course, I would never do, but it is sure fun to think about!)
    Apr 26, 2012 4:03 PM   in reply to yoboxe
    You, of course, realize that you are just yelling at other users and not any from the company, right?
    Jun 13, 2012 4:00 AM   in reply to yoboxe
    I'm so in agreement with you!
    Jun 13, 2012 4:04 AM   in reply to Michael Riordan
    I've recently switched from CS4 to CS6 but I'm still unable to re-organise the page sequence in Illustrator... Can someone please advise me on what to do? Many thanks.
    Jun 13, 2012 4:15 AM   in reply to Rick@RedNovaLabs
    I don't agree in the least. Although InDesign and Illustrator share a common denominator in terms of fuctions, I choose one of the other depending on the content of my project: if a project is very graphic-based, I will definitely opt for Illustrator, no matter whether it consists of one artboard or 20. It would be bad practice and very time consuming to create certain elements in Illustrator and then having to import them in InDesign.
    I know this is getting a bit off-topic, but Freehand (RIP) was one of the most advanced, user-friendly and complete programs of its time, it had power of an illustrator tool and the capabilities of a layout program. A true designer's tool!
    Come on Adobe, learn something from that, after all you bought Macromedia all those years ago.
    Jun 13, 2012 4:57 AM   in reply to suttonwinson
    I can try to help you with the artboards.
    Using the artboard panel
    you drag the artboards to the relative position you want them to be. that is if you want artboard 2 to be where artboard 1 is yiu just drag it above artboard 1 or drag artboard 1 below artboard 2 and then do the same to the other artboards you wish to reorder.
    From the flyout menu of the artboard panel select Rearrange Artboards all the artoards and their content will be moved and renumbered to flow in a 1,2,3…sequence.
    Jun 13, 2012 7:00 AM   in reply to Wade_Zimmerman
    Excellent! Thank you very much!
    Sep 14, 2012 4:30 PM   in reply to CarlosCanto
    where would you put this script? Thanks much.
    Sep 15, 2012 8:22 PM   in reply to karenf1
    - copy the script from here
    - open the ESTK, it should be in the same folder where the other CS apps live
    - ESTK should open with a blank document
    - paste the script there
    - save it, and place it in your default illustrator scripts folder
    - restart Illustrator
    to run the script
    - go to File->Scripts
    Sep 16, 2012 6:44 AM   in reply to CarlosCanto
    Many thanks for your generosity with your time & reply!
    Sep 16, 2012 6:55 AM   in reply to karenf1
    Here is a link to a fabulous 3 minute video that shows how to set up the artboards in CS5 - columns etc - and move them around:
    http://www.youtube.com/watch?v=SVH3FQjnsiQ
    Sep 16, 2012 7:23 AM   in reply to karenf1
    One more question! These new artboards in CS5 are pretty terrific with so much added funtionality! But how would you set up that classic structure you'd use in InDesign: two side-by-side 8.5 x 11 pages, with bleed on all sides EXCEPT the gutter? So far all I can find is the ability to assign bleed separately to the four sides - which is great - but NOT the ability to assign a different bleed to the gutter - which would be different / opposite sides depending on whether it was a left or right page. BTW/FYI: I set the docment up as 8.5 x 11 and 2 columns. Many thanks for the wonderful help here in this forum!
    Sep 16, 2012 10:24 AM   in reply to karenf1
    of course, if you have CS5, there's no need for the script, it was made specifically for CS4
    Sep 16, 2012 10:27 AM   in reply to karenf1
    karenf1 wrote:
    One more question! ...
    you should start a new thread with your question, you'll get helped better
    Sep 16, 2012 12:04 PM   in reply to CarlosCanto
    carlos - when I asked you the question about the script - I wasn't aware that my husband had CS5 on his mac. I found that out this morning- so I got to see the CS5 changes to the artboard. But thank you so much I did try your method out. It was just a bit over my head.
    Nov 14, 2012 10:40 PM   in reply to japchap
    Thanks JapChap... this really helped out. I don't think I'll be switching to CS5 anytime soon. I got CS4 at home, CS2 at work!
    Oh, and those folks lamenting about our good ol' FreeHand program? Man I sure do miss using it. Can't anymore now that I'm using Lion. Multi-page layout Functionality, Find & Replace, Paste Inside - those were my go-to functions that are not done very well (or at all) in AI. In FH this prob is easily solved by dragging the page over in a side menu display window...
    Clipping Masks blow...
    AI - dig in that FreeHand magic box and put the Paste Inside in AI! So many good functions that would make AI so much more design friendly... I wonder if the AI developers actually have "working-career-type" designers on their team?
    Anyways, sorry for the rant if it doesn't relate... If it does, yeah man, that's right...
    Peace & Command Z!
    JP
    Nov 14, 2012 11:15 PM   in reply to kas8
    Just to let know everyone here that CS6 has this new page administrator which does exactly that.
    Dec 24, 2012 12:57 AM   in reply to jaypzl
    Jan 17, 2014 6:59 AM   in reply to kas8
    Open the artboards panel, drag the artboards in the order you want them to be. They will keep the same artboard # but will export in the order you place them and won't move or rearrange the artboards in your file.
    Mar 28, 2014 8:04 AM   in reply to kas8
    Hey! This is how I did it in CS6.
    1. Menu>Window>Artboards
    2. Select Artboard
    3. Click UP or DOWN arrow
    I hope this works in all the previouse versions of Illustrator!
    Blessings,
    Cosmosion
    Mar 28, 2014 10:01 PM   in reply to Cosmosion
    it will work as far as CS5, the CS4 version does not have this feature, and  CS3 and older do not have artboards.
