View the baseline grid
Aug 12, 2010 7:28 AM
The keyboard shortcut for viewing the baseline grid does not work in the CS5 Mac version. I can see the baseline grid by going through the menus but it would be so convenient just to press some keys as I am supposed to be able to. This must be a bug. I can view the document grid easily enought, either by going through menus or by using the keyboard shortcut (command + ').
    Aug 12, 2010 7:30 AM   in reply to krhewkjr
    When you type an apostrophe in InDesign does it come up as an apostrophe or another symbol?
    Try changing your keyboard regional language?
    Aug 12, 2010 8:21 AM   in reply to krhewkjr
    Have you checked to be sure you are using the default shorcut set?
    Aug 12, 2010 9:35 AM   in reply to krhewkjr
    Very odd - but in CS3 the shortcut for Show Invisibles never worked and I had to create a new one. I don't know why it happens or if it's related to your issue?
    Aug 13, 2010 9:54 AM   in reply to krhewkjr
    I was getting the same problem (CS5). Fixed it by going to OS X System Preferences > Keyboard > Keyboard Shortcuts > Keyboard & Text Input > uncheck 'Move focus to the window drawer' which uses the same shortcut.
    Jan 11, 2011 8:47 PM   in reply to ja3754
    Just wanted to say, "thanks". This was bothering me too, and your fix did the trick!
    Oct 28, 2011 8:06 AM   in reply to rcbmoose
    thanks was looking for the answer too!
    Apr 26, 2012 9:35 PM   in reply to ja3754
    CORRECT ANSWER. Thank you!
    May 30, 2012 12:27 AM   in reply to ja3754
    Still a good answer.  Thanks.
    Jul 4, 2013 10:45 AM   in reply to ja3754
    Perfect - thats solved it for me - thanks!
