ekulis
Pixelated Text.
Aug 15, 2010 6:28 PM
PSE8 Mac OS X Snow Leopard
My text in PSE has always looked horrible.  Toggling the anti alias setting changes it from very, very, very horrible to very, very horrible.
I go to another tool like Mac Pages.  Create text there and then PDF or screen shot for another layer in PSE.
What's up?
-ed
    Aug 15, 2010 7:56 PM   in reply to ekulis
    The zoom% could cause the text to appear pixelated.
    The best is 100%, but 50% or 25% will due also.
    Try a different font, some just are bad regardless.
    The first screenshot is 100% view (actual pixels) and the second is 66.7% view.
    Click on the images below  to enlarge.
    MTSTUNER
    Aug 16, 2010 7:31 AM   in reply to ekulis
    Resizing text after simplifying it will make it look dreadful, too.
    Aug 16, 2010 7:19 PM   in reply to ekulis
    If your using the type tool in photoshop elements to make your text, then
    the resolution of the document won't matter for just viewing on a computer
    monitor (maybe a little). If you can't get any fonts to look good viewing the
    document at 100% (actual pixels) viewing in photoshop elements, using text
    you made with the type tool, then perhaps a global setting on your computer
    is causing this. Also try resetting the type tool in photoshop elements by
    going to left of the tool options bar and choosing reset tool.
    If you intention is to print, then it does matter. If your making a document
    that you want to print, start out with a document with a resolution of 300
    before adding text etc.( resolutions of 240-300 or so will probably be okay)
    File>New.
    Also, doing any resizing (except resolution), up or down, by adding or subtacting
    pixels (image size dialog with resample checked), will tend to make your pictures
    or documents not as good as the originals.
    That's not to say you should never resize, cause there times you have to, for example
    images for display on the web or emailing.
    I used a Arial Rounded MT Bold font for the test images. The first e below is a 640x480
    at 72 resolution and the second e is a 640x480 at 300 resolution.
    MTSTUNER
