Changing p0 to inches
Aug 17, 2010 6:37 AM
How do I change the p0 in the document set up to inches? I already tried changing in the preferences, but it reverts back to the p0 which I don't even know what that is.
    Aug 17, 2010 6:43 AM   in reply to djliefer
    Welcome to the world of graphic design. First time visitor, are you? "p0" is nothing -- it's "0p0", and that stands for zero pica's and zero pica points.
    The online help for "measurement units" answers your question: http://indesignsecrets.com/change-measurement-systems-on-the-fly.php
    Aug 17, 2010 6:57 AM   in reply to djliefer
    p is picas and points. 2p would be 2 picas. 2p6 is 2 picas, 6 points. There are 12 pts in a pica.
    Open a new ID doc, click in the ruler at the top and right click. Convert to inches. Click in the ruler along the left side, right click and convert to inches. This should now be your new default setting.
    Aug 17, 2010 7:09 AM   in reply to Mr. Met
    Just righ click in the upper left corner of the rulers. You'll get 'em both.
    Bob
    Aug 17, 2010 8:12 AM   in reply to djliefer
    To change your default unts:
    Close all open documents.
    Open InDesign Preferences
    Go to Units & Increments
    Set Horizontal and Vertical Ruler Units to desired option (such as Inches)
    Click OK
    That will set your units for all future documents.
    Existing documents will have to be changed when opened.
    Personally, I use Points, set to 72 pts per inch. I feel I have more control over object size and placement.
    Aug 17, 2010 8:55 AM   in reply to djliefer
    I do not use picas, so I cannot comment on how useful they would be. 6p0 would be equivalent to 1 inch, or 72 points.
    I use points beacuse:
    • It is the same unit of measure for the text (font size in points)
    • At 72 points per inch, it is roughly equivalent to the pixel resolution on images (72 pixels per inch).
    • I can adjust things by points, where each point equals 0.01389 inches. It is easier to adjust by adding 1 or more points than by large decimals of inches, even though the dialog boxed can do the math for you.
      • If you need to set something as a scale in inches, you can still enter that number into any field, and the field will convert it for you,
      • Enter 1.25 in, and you get 90 points.
    Still, it is my personal preference. It is not the only way to do things.
    -mt
    PS: When you set the preference using the rules, you are setting the document preference. Though, each ruler can be different.  For instance you can have inches vertical and picas horizontal.
    Aug 17, 2010 10:57 AM   in reply to djliefer
    You can leave your document as Pica for the measurement.
    When you create a new documeent simply type in
    8.5 inches
    10 inches
    and it will convert to the pica equivalent.
    That's fine. You can then use Picas as the ruler.
    I used to do all my measurements in picas but I found that others couldn't use them so I reverted to millimeters.
    Aug 17, 2010 11:01 AM   in reply to Eugene Tyson
    In fact - you can type in any measurement anywhere
    Say if you are using inches as you're ruler and you want to move the X Co-ord a fraction of an inch.
    You can simply type into the X Cords in the top right which will read say 4 in - after this type in "+1p"
    Which will move the selected item 0.166 of an inch, your new coord will be 4.166
    And you can do that with loads of things in indesign, simply add, substract, divide using "+", "-", "*", "/" anywhere where a numerical meaurement is used, and use any measurement available.
    Sep 21, 2010 3:40 PM   in reply to MT.Freelance
    a thousand thanks, that's been bugging me for forever.
    Apr 29, 2012 8:11 PM   in reply to MT.Freelance
    awesome...thanks, MT.Freelance -- you're the only one who ACTUALLY answered the question. All the rest of you art-**** talkin' about picas where missing the point.
    After closing all docs, I was finally able to change the preference -- (BTW: that seems like a bug)
    Apr 29, 2012 8:56 PM   in reply to cakeholio
    It is not a bug, though at first glance it may seem to be.
    With no documents open, changing the preference sets the new preference for
    future documents without altering any existing documents without your
    direct intervention..
    With a document open, changing the preference affects ONLY the open
    document without chancing your workspace.
    So, if you prefer to work in Pica's and have a one-off project that demands
    the file be delivered in mm, you can change the document without impacting
    your personal workspace.
    It may seem like a hassle to work the preferences this way, but I believe
    it gives more control to the designer.
    -mt
    Apr 30, 2012 1:26 AM   in reply to MT.Freelance
    It's not a bug, it's by design.
    I love this behaviour. I set up everything to my taste long ago; now when I create a new document, I have sensible defaults assigned to virtually every fuction. Much better than creating a template or something and having to open that every time!
    Jun 4, 2012 12:57 PM   in reply to djliefer
    I hope Adobe gets a clue that designers are not using PICA rulers and setting type anymore! This has got to be one of THE most frustrating things they've ever done to designers.
    Jun 4, 2012 1:51 PM   in reply to Carol Nix
    You'd be surprised.
    It's a default and is easily changed. In fact, you could have done it faster than posting here.
    Bob
    Nov 23, 2012 5:11 AM   in reply to Bob Levine
    For additional information on specifying measurements, see Rulers & Measurement Units help article. The article also contains a table with examples on how to specify values using non-default units.
    Apr 7, 2013 2:27 PM   in reply to djliefer
    Please run the InDesign application and do not create any new document and go to Preferences>>>Units & Increments and set the  unit as inches  in Horizontal and  Vertical fields and press ok , from now onward you will get inches by default in the new document set up window
