Aug 18, 2010 6:16 AM
PFI Conversion Error
Like (0)
Any help would be much appreciated. I received this error while trying to convert an air 2.0 app via command line:
Exception in thread "main" java.lang.Error: Unable to find named traits: mx.collections.errors::ItemPendingError
at adobe.abc.Domain.resolveTypeName(Domain.java:195)
at adobe.abc.Domain.resolveTypeName(Domain.java:112)
at adobe.abc.GlobalOptimizer$InputAbc.resolveTypeName(GlobalOptimizer.ja va:274)
at adobe.abc.GlobalOptimizer$InputAbc.readCode(GlobalOptimizer.java:983)
at adobe.abc.GlobalOptimizer$InputAbc.readBody(GlobalOptimizer.java:531)
at adobe.abc.GlobalOptimizer$InputAbc.readAbc(GlobalOptimizer.java:404)
at adobe.abc.GlobalOptimizer$InputAbc.readAbc(GlobalOptimizer.java:280)
at adobe.abc.LLVMEmitter.generateBitcode(LLVMEmitter.java:160)
at com.adobe.air.ipa.AOTCompiler.convertAbcToLlvmBitcode(AOTCompiler.jav a:329)
at com.adobe.air.ipa.AOTCompiler.GenerateMacBinary(AOTCompiler.java:600)
at com.adobe.air.ipa.IPAOutputStream.compileRootSwf(IPAOutputStream.java :196)
at com.adobe.air.ipa.IPAOutputStream.finalizeSig(IPAOutputStream.java:35 5)
at com.adobe.air.ADTPackager.createPackage(ADTPackager.java:65)
at com.adobe.air.ipa.IPAPackager.createPackage(IPAPackager.java:165)
at com.adobe.air.ADTEntrypoint.parseArgsAndGo(ADTEntrypoint.java:132)
at com.adobe.air.ipa.PFI.parseArgsAndGo(PFI.java:152)
at com.adobe.air.ADTEntrypoint.run(ADTEntrypoint.java:68)
at com.adobe.air.ipa.PFI.main(PFI.java:112)
These errors usually mean that you are either converting an app that is referencing a swc via RSL instead of linking it into the codebase. Or it could be a flex app built in debug mode, which If I remember correctly was an issue in the last release of the packager.
Thanks for your help, it worked, I had an swc via RSL. I never would have figured this one out, thanks again.
Can you be more specific, where do I see "RSL" and if I have swc's there?
I opened my project properties are set to merged into code. I do not have a debug perspective open - flash perspective only. I also added to project properties - flex compiler: -compiler.include-libraries
How do I get rid of this error?
Hi
May you please give me more details about RSL ?? as i have the same problem and i couldn't able to compile my project
I did finally resolve this - in my case it was not due to the RSL.
The key was how I was compiling. I was compiling using flash builder, but the secret is to compile using command line.
From this thread: http://forums.adobe.com/thread/731171
Basically you use amxmlc to compile your mxml file created in flash builder. That creates an swf you can then use PFI builder to create an ipa.
I use the batch files from this page to create the ipa: http://iphoneflashdev.blogspot.com/2010/09/i-promise-this-is-last-post -about-this.html
any issues, more info in this thread: http://forums.adobe.com/thread/617244
So I create a flex project, AIR, then I add in the required files - icons directory, app.xml, Default.png. Make sure the application tags are "<s:Application".
From there, use amxmlc to create my swf, then use the batch files via Run->External Tools->... to create my ipa.
At least in my copy, the RSL settings are correct.
Thanks Scott Szretter,
I had the same problem and it got resolved by compiling it through amxmlc in command prompt.
However, in my case even "<s:WindowedApplication>" worked.
Tanu
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
