Home/Support/
Forums
157 Views 4 Replies Latest reply: Sep 12, 2010 10:23 AM by RickInTampa RSS
gnorb.designs Calculating status... 2 posts since
Aug 23, 2010
Aug 23, 2010 7:05 PM
Loading application files outside CF app root (CF+JBoss)
I have CF9 installed as an EAR file in JBoss 5.1.0 ($JBOSS_HOME/server/default/deploy/cfusion.ear -- on local disk).  I would like to place the custom application files on a shared file system (e.g. /apps/mycfapp) outside of the path $JBOSS_HOME/server/default/deploy/cfusion.ear/cfusion.war.  With JRun, you could map to a different resource path by modifying cfusion.ear/cfusion.war/WEB-INF/jrun-web.xml.
Ex:
    <virtual-mapping>
        <resource-path>/*</resource-path>
        <system-path>/apps/mycfapp</system-path>
    </virtual-mapping>
Is there a way to modify/specify the path to the custom application files with other application servers?  Or is this not possible at all and all of the files must be deployed into the $JBOSS_HOME/server/default/deploy/cfusion.ear/cfusion.war directory?
Desired behavior: When I access http://www.mydomain.com/cfusion/index.cfm, ColdFusion would load index.cfm from /apps/mycfapp/index.cfm instead of $JBOSS_HOME/server/default/deploy/cfusion.ear/cfusion.war/index.cfm
  • mack_ Calculating status... 297 posts since
    Apr 6, 2009
    You might get a response here because there are people familiar with
    JBoss but I think you will improve your chances if you ask this
    question on one of the JBoss lists.
    Mack
  • RickInTampa Calculating status... 2 posts since
    Sep 10, 2010
    I need some help with this as well.
    I think that it is a CF configuration issue and has nothing to do with JBoss.
    My presumptions:
    1.  On a linux box, I "should" be able to make a symlink in the cfusion.war directory that points to a external directory that contains .cfm files.
    2.  CF has a "Server Settings -> Mappings" page that I think "should" allow this to work.
    So far, I can't get either of these 2 techniques to work.
    My particular intallation is on RHEL5, using JBoss 5 and CF9.
    I installed CF9 as an EAR in the JBoss deploy directory.
    For me, that is:  /opt/JBoss/server/default/deploy/cfusion.ear
    If I put a "test.cfm" file in /opt/JBoss/server/default/deploy/cfusion.ear/cfusion.war/rick/test.cf m, it works fine.
    But, I need to place the .cfm files on a shared drive that is outside the cfusion.war directory structure.
    I expected that a symbolic link in the cfusion.war directory that pointed to my shared directory would work, but it does not.
    For example if I replace the "rick" directory with a symlink that points to /cfmfiles, I would expect that to work.
    OR, if that doesn't work then I would expect that I could create a mapping from the CF Administrator that points logical path "/rick" to "/cfmfiles" directory path.  That does not work either.
    So, is there any way to configure CF9 on JBoss that allows me to put the .cfm files somewhere other than the cfusion.ear/cfusion.war directory?
    Rick
  • RickInTampa User 2 posts since
    Sep 10, 2010
    <Context cookies="true" crossContext="true" allowLinking="true">
    Works like a champ!
    Thanks a ton,
    Rick
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
