Duplicate a composition layer in the timeline, at same time make new comp
Aug 24, 2010 1:59 PM
I know that in the project panel I can do Control D and make a new comp. I know that in the layer panel I can do control D and make a new layer for a different comp, which keeps all the animations I have applied to that comp.
I also know that after I've duplicated that comp in the Project Panel I can Alt drag it to the other comp in the timeline and replace, or swap the comps.
What I want is to remove a step.
I have Comp A
In the timeline I want to duplicate this comp and at the same time create a new Comp B.
What I want is to be able to duplicate the layer in the timeline, and while doing so also create a new composition which would show up in my project panel. Basically I am trying to skip the extra steps of duplicating layer, going to project panel, duplicating comp, then Alt dragging to swap them.
Is there a shortcut for this?
    Aug 24, 2010 7:44 PM   in reply to garek007
    Precompose??? I think that's what you're asking.
    The keyboard shortcut is Ctrl/Cmnd + Shift + C
    Here's the help file page on precomposing layers.
    Aug 25, 2010 12:29 AM   in reply to garek007
    No. Nor should there. Doesn't really make any sense to have it that way...
    Mylenium
    Aug 25, 2010 7:45 AM   in reply to garek007
    As a process, it would be very easy to accomplish with Scripting.  If you ask nicely in the Scripting Forum I'm sure you'll find some assistance.
    Aug 25, 2010 8:09 AM   in reply to garek007
    Mylenium, why would you think there should be no shortcut for this?
    You are forgetting, that pre-comps in themselves can contain any number of pre-comps inside pre-comps inside pre-comps.... You would have to find a way of taking care of those scenarios which is a major logic challenge and effort. that being so and to avoid potentially risky user operations that might ruin entire projects, it is much safer to not allow this. I would agree with Rick that a simple script that mimics the manual steps and tied to a function key is probably as good as it gets, but still, even there the underlying deeper problem still exists, so you have to work very controlled.
    Mylenium
    Feb 26, 2011 5:03 AM   in reply to garek007
    Apologize for resurrecting an old thread, but this was ranked highly on Google and I found a solid working solution at donationware site AEScripts:  http://aescripts.com/true-comp-duplicator/ in case anyone else finds this thread while searching.
