LindyMelendez
Photoshop CS5 MS Visual C + +Runtime Error R6025
Aug 28, 2010 10:06 AM
Im  running a 4 core AMD and just started having this problem today with  Photoshop only when I start it . All the other programs are fine. Can someone come out  with a solution. PS has been running on my system great for 2-3 months.
Any help would be appreciated !
    Aug 28, 2010 10:36 AM   in reply to LindyMelendez
    Did you try reinstall PS?
    Aug 28, 2010 11:54 AM   in reply to LindyMelendez
    Found this by google:
    http://support.microsoft.com/kb/125749/en-us?wa=wsignin1.0
    Try resetting the prefs by reading this: May help may not but it is a easy fix. You have to time it right though.
    http://forums.adobe.com/thread/375776?tstart=0
    To me it sounds like something in photoshop became corrupt. In the software itself or the registry entries somewhere? Hard to say. Best bet, as already mentioned, is to reinstall PS CS5. Make sure you deactivate the software (if you can?).
    Before you do remove the software go to start, search programs and files, and type in cmd. Righty click on cmd.exe and choose run as admin. A black looking box will show up. Type in sfc /scannow and hit enter. This will scan your OS files for errors and attempt to fix them. Have your windows 7 disk ready incase it asks for it. Also you may need to reboot to fix something. If you do reboot make sure once the computer is started and stable, do the command again until it comes up good with no errors.
    Also run a virus scan in the safe mode to ensure nothing has infected your machine. Also to be a little bit more sure: While in the the safe mode type in MRT and hit enter. This is a microsoft tool to detect and remove viruses. Just run a quick scan. If something is found and removed then do a full scan afterwards.
    Now PS CS5 might have a repair option on it when you put the disk in. Choose that first and see if that fixes the problem. If not then deactivate, remove, run the PS CS5 cleaner from the adobe web page, and reinstall. Make sure you run the software as admin. Don't install, explore the disk and look in the PS folder. Look for the .exe file, right click on that and choose run as admin. This will ensure the proper security levels.
    Make sure you turn off any anti-virus software first. Turn off Windows defender if installed and running
  • Noel Carboni
    Dec 23, 2006
    Aug 31, 2010 6:38 AM   in reply to LindyMelendez
    What operating system are you running?
    If it's one of the modern ones, you could use the System Restore feature to roll your system back to a restore point where Photoshop was working.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 31, 2010 6:57 AM   in reply to LindyMelendez
    You restored to a time when you know it was working and it didn't fix the problem?  Did you try going even further back?
    Some basic stuff to cover:
    • Have you updated Photoshop to 12.0.1
    • Have you updated your video and tablet drivers (if any) to the latest release?
    • Have you tried using the Windows SFC tool to see if the operating system is corrupted (e.g., SFC /VERIFYONLY or SFC /SCANNOW)?
    • Have you tried reinstalling Photoshop?
    -Noel
    Aug 31, 2010 10:51 PM   in reply to LindyMelendez
    I'm having this exact same problem as well.  CS5 32-bit works just fine, but when I start 64-bit, I get the Runtime error.   Everything else seems to be working fine.  I'm using Windows 7 ultimate and never had a problem before, but I hadn't tried the 64-bit version in quite some time so I'm not sure when the problem may have actually began.  However, I did have a rather larger Adobe update today with numerous programs getting updated.
    I did a sfc scan and there were no errors.
    Dec 1, 2010 7:09 AM   in reply to LindyMelendez
    Am also having the same problem. Having runtime error on photoshop cs5 64 bit. I've done all of the above suggestions and even ran a registry cleaner. Still the same problem.
    Anyone any advise?
    Jan 22, 2012 2:21 AM   in reply to LindyMelendez
    i've encountered  the same problem.
    in my case, the error happens when i use the copy and paste shortcut (ctrl+x/c and ctrl+v)
    because of the jdownloader app  that detects the copy info, thus causing the crash
    disabling the jdownloader copy detection links function solved the runtime error.
    if this doesn't work. then it probably is a different problem.
    anyway this solution was posted by someone else i came across long ago.
    hope this helps.
    cheers!
