Hello,
I have submitte a help ticket with the tech support through adobe, however their response lead me to an outdated (website no longer there) response. I was hoping that someone here might have a better response for me.
I just purchased a new computer with Windows 7. I did not realize that I had to deactivate the old computers CS programs before I in
stalled on new computer. After installing CS 2.3 on new computer and it wouldn't open for me, I realized my mistake.
I deactivated on old computer and uninstalled the entire program. I then uninstalled CS on new computer and then reinstalled.
Everytime I open Photoshop up it gives me this error:
Your Photoshop user name, organization, or serial number is missing or invalid. the application can not continue and must now exit. The application then closes right away and doesn't let me do anything to it.
After chatting with a help person, he directed me to this article. http://kb2.adobe.com/cps/331/331799.html I attempted to do #1. The installer gave me this message:
The installer could not start because of the following reasons. Missing or invalid Personalization Information. Missing Resources Library.
I went then to uninstall and try everything again and it gives me the same message. So at this time I am unable to uninstall or try installing (to redo the serial number). I am very hesitant to try manually uninstalling because I am unsure if I am capable of finding everything that needs to be deleted. I continued to read the entire article (link above) and there was a comment in there about applications couldnot find the valid activation information (name, org. serial) because of the stall path was "C:/Program Files (x86)/Adobe" Due to the specal characters, in continued to install to that location even after I changed it to simple "C:/Program Files/ Adobe" It needs to be installed at just "C:/Adobe" and that should fix the problem. The issue with that is that I can no longer uninstall this program to see if installing under a different location will solve the issues with loading the applicat
ions. What do you suggest I try next? I have researched it some (http://forums.adobe.com/thread/314178) and I hope that I can install and get these programs working and that I haven't lost these critical programs.
Browser: Microsoft IE
Operating System: Windows 7
This was the response I received from the tech support:
Solution 1: Update your VCOM software and apply the appropriate patch.
If you use VCOM Fix-It Utilities 6 or VCOM SystemSuite 6, update your
software to the latest version before you download the appropriate patch
from VCOM.
For Fix-It Utilities, update to version 6.0.3.4 before you apply the
patch. Find the patch in article 1507 "How do I keep Registry Cleaner
from removing my Adobe registry settings?" on the VCOM website at:
http://v-com.custhelp.com/cgi-bin/avanquestusa.cfg/php/enduser/std_adp .p
hp?p_faqid=1507
For SystemSuite, update to version 6.0.3.6 before you apply the patch.
Find the patch in article 1506 "How do I keep Registry Cleaner from
hp?p_faqid=1506
Also please follow all the steps which are mentioned in belwo document
http://kb2.adobe.com/cps/331/331741.html
It will open a document which says " Error: "...user name, organization,
or serial number is missing or invalid..." when you start Photoshop (CS2
on Windows) " contain all the steps to resolve your issue.
This should resolve your issue.
I went to the VCOM website and it is no longer there, therefore I cannot reference the article the tech support listed to make sure I understand what a 'registry cleaner' is and to make sure I don't ruin something on my new computer.
Can anyone give me some direction on what I should do? If I am supposed to do a 'registry cleaner' is there an article that I can reference so I don't mess anything up. I understand some stuff about computers, but registry cleaning seems to be out of my realm of understanding. Thanks for your help. Let me know if you need me to provide additional information.
Michelle
Do you realise that Windows 7 doesn't support CS2? There is an XP compatibility mode that works well though apparently, you may find running it in that fixes your other problems? Dunno, but worth a go.
Also, if you were thinking about upgrading, when CS6 comes out you probably won't be able to upgrade from CS2, you'd have to buy a complete new license...
No I did not realize this. Noone said anything about this. I have talked to 3 different 'support' people and not one said a word..... sigh.... I am sure you are correct, but I just wanted to verify that CS2 DOES NOT run on windows 7. Also what is the first verson that does??? I don't need the latest version, maybe I can upgrade to a lesser version. If I do upgrade, will I be albe to with all the problems I am having??
Some people seem to have been able to get it to run,my point was that it isn't supported, i.e. not guaranteed to. The first version that does would be CS5.
If you did upgrade you can only upgrade to the latest version, the older versions aren't sold any longer once the new one comes out, although there is a very slight chance there might be a retailer out there with an older version for sale still. Any ones on sale online for cheap will be pirated copies...
As to your problems, they should go away with a new version, and all you'd need from your old version will be the serial number.
Ok I ran a registry cleaner and this allowed me to uninstall CS2. I then went to reinstall CS directly in the c drive (see above post). This worked!!! If anyone is having problems running CS2 in windows 7 I would recommend installing it directly in c instead of under program files. Thanks for all the help!
If you're not a "tech person" I highly suggest you stay away from the registry. One wrong move and your Windows installation is hosed.
CS2 is not supported under Win 7. You should upgrade to CS5.
You can save $30 with free shipping and no tax at Amazon http://amzn.to/9FrpGY or you can buy from any other authorized retailer.
Bob
I'm having the smae problems as Michelle, so I'll try uninstalling and reinstalling in C:/ ...I hope that works! The other issue I have (for all you "upgrade" people) is that a newer version of Creative Suite is pretty expensive and my CS2.3 was working fine for me (when it functioned as it should). Not everyone has the cash to upgrade. A new computer was a stretch for me, let alone getting all my programs updated too.
North America
Asia Pacific
