lolNoJoke
Layer Effects and Brush not working
Aug 30, 2010 12:57 AM
Everything was working well, but then, the layer effects stopped working.
Nothing happes when i shut them on and off...
Then the brush started acting wierdly and when i drew somthing, it drew a line from the beggining of where i started to draw to the end.
I wasn't holding shift and it didn't look like what shift does.
I tried reinstalling photoshop and deleting the prefrences file, but nothing worked.
Thanks..
  • Noel Carboni
    Dec 23, 2006
    Aug 30, 2010 7:19 AM   in reply to lolNoJoke
    Good standard advice when things are acting up is to check to ensure all your drivers - e.g., video and tablet drivers - are fully up to date, and that you've updated Photoshop to the latest patch (CS5 has a 12.0.1 update, accessible via the Help - Updates... menu).
    Did this happen once during an edit session, or has it become persistent - i.e., it happens even when you restart Photoshop?
    If it is persistent, beyond the above advice, some things to try:
    1.  Clear your Photoshop preferences by pressing Ctrl-Shift-Alt immediately after starting Photoshop from it's shortcut or menu item.
    2.  Temporarily disable the OpenGL setting in Edit - Preferences - Performance to see if that affects the issue.
    3.  Check your Windows event logs for errors or failures.
    Hope this helps!
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Sep 3, 2010 8:34 AM   in reply to lolNoJoke
    You didn't say whether your video drivers are up to date.  You need to check and update them if they are not.
    I'm afraid you may have to get smarter about maintaining your computer to fix this one.
    function(){return A.apply(null,[this].concat($A(arguments)))}
    lolNoJoke wrote:
    idk where to find errors...
    Assuming you're running a modern operating system...
    1.  Click the Start button, right-click Computer, choose Manage.
    2.  Expand Event Viewer - Windows Logs and click on System.  Give it a few moments to fill in.
    3.  Look for Error entries.
    -Noel
    Sep 14, 2010 10:48 AM   in reply to lolNoJoke
    You might want to check with the tablet maker about updated drivers.
