RoboHelp 7, JavaHelp, and Java SDK
Dec 3, 2007 7:19 AM
I have Jave SE Development Kit 6 Update 3 installed on the computer that has RoboHelp 7 installed. The folder for the jdk is at C:\Program Files\JAVA\jdk1.6.0_03. However, when I try to compile my JavaHelp project, I get dialogs that Java 2 SDK is required to build compressed JavaHelp and full-text search. So, I then click "Locate Sun Java 2 SDK Install Folder" twice (once for compressed JavaHelp and once for full-text search) and navigate to the path mentioned above. RoboHelp does accept that path as the path with the JDK. However when I click Finish, RoboHelp 7 does not build the JavaHelp but again prompts me for the jdk path. It is stuck in a loop. RoboHelp X5 had no problems with my Java SE installation. I have set environment variables for "JHHOME", "JAVA_HOME", and added the C:\Program Files\JAVA\jdk1.6.0_03 path to my PATH variable, but it doesn't help.
Does anyone know what RoboHelp 7 is expecting?
    Nov 15, 2013 7:16 AM   in reply to AnnFreeman
    Hi, I am having a similar problem with RH10, could you ever resolve the issue?
    Robert
