I created a template in FM 9 with all my styles, mapped all my styles in RH 8 and saved them to RHStyleMapping.css. When I linked the book, RH recognized some but not all of the styles. In particular was a bulleted style which I had to create manually afterwards in RH. The problem then became the font. FM uses a font of Agaramond and RH has it mapped to arial. Regardless of what I do it is stuck on garamond when I update the book or topics individually.
I tried using the same css in another project and same result. I've seen corrupt css files before but I wonder if that is the case here because it works fine for other styles.
Is this a bug or is there something else someone can suggest to try to get the correct font (everything else is accurate about the style, spacing, indent, etc)?
When importing, set that your lists styles are mapped to HTML lists.
Did you set the font correctly in the css? Go to the Project manager and open the folder Style Sheets. Select your style sheet and choose the font for the styles you want.
Greet,
Willam
Turns out the .css was corrupt. I don't know how it got that way but i replaced it and functionality is not funky with fonts, etc.
