ilya_k
Flex events: when to use capture phase
Sep 1, 2010 4:48 PM
Greetings!
I seem to understand Event flow (maybe I do not) but  have difficulties to figure out
why should I use capture phase event in adddEventListener? Anyone can think of use case?
Why would I create custom event with capture not bubbling as default?
Regards
    Sep 1, 2010 5:13 PM   in reply to ilya_k
    Bubbling events is generally a bad practice.  Bubbling should be reserved
    for events that can be dispatched my more than one children of varying types
    within a container.  That's why only things like adding/removing children,
    mouse and keyboard activity and focus bubble.
    Capture is used by a container to react to an event and possibly prevent the
    actual target's listeners from seeing it.  It's primary use is in handling
    mouse dragging, similar to the MouseCapture() API in Windows.
    Sep 1, 2010 9:49 PM   in reply to Flex harUI
    Alex, why is bubbling events considered bad practice?  I am really curious because I make heavy use of bubbling to send information to the systemManager to act as a controller.
    Also seems useful to me as a way to more loosely couple components.  But, I am not trying to be combative or defensive, just explaining why I use bubbling.
    Sep 1, 2010 10:17 PM   in reply to supersonicecho
    Because every level of the display tree gets to see the event, and it
    requires that you come up with unique event names.  It essentially breaks
    encapsulation and takes longer to process.
    You might want to look at how other application frameworks set up their
    controllers.
    Sep 1, 2010 10:43 PM   in reply to Flex harUI
    Thanks for the explanation.
    Sep 2, 2010 1:49 PM   in reply to ilya_k
    APPLICATION_COMPLETE is only dispatched from the Application and
    SystemManager.  If you are not listening there you won't see it.
    Note that, if you had a sub-app that bubbled APPLICATION_COMPLETE, the
    main-app would see it and potentially run its APPLICATION_COMPLETE handlers
    again, which is probably not desirable.
    Sep 2, 2010 10:41 PM   in reply to ilya_k
    There is no capture phase at the target.  It makes more sense to listen to
    the sub-app than one of its parents.
    Sep 3, 2010 9:54 AM   in reply to ilya_k
    It matters, as there is no capture phase at the target.  If you are
    listening to the systemManager, you must use false.  Using true will work in
    this case because the child application also dispatches the event, but it
    would not work in the general case
