Authentic Sols
Unknown Publisher issue in Native Installer
Sep 3, 2010 9:38 AM
There is one issue I'm facing. I have a verified certificate with which I have produced a native installer for Windows. The problem is when I download this installer file from my web server, it gives me a prompt with Publisher: UNKNOWN. Can anyone please let me know where I'm wrong? Please see the attached image
    Sep 15, 2010 2:02 AM   in reply to Authentic Sols
    Is the certificate being used from a Certification Authority recognised by Adobe? You can self sign an AIR app for use with the installer which will ensure that the AIR archive is not tampered with before install, but a self sign cert will always be an Unknown Publisher to Adobe.
    You need to use a Cert from a 3rd party authority that Adobe trusts such as Verisign to be a recogised publisher during install, these are commercial certs that Adobe will verify during install/upgrade of AIR app and display your publisher details registered against this cert when purchased.
    Cheers
    Mark
    Sep 15, 2010 2:29 AM   in reply to Authentic Sols
    The Comodo Cert is a social web trust mechanism used as a sort of 'recommendation of trust' for users / customers of an ecommerce web presence.
    The cert you would need would have to come from one of the organisations in Adobe Approved Trust List (AATL)
    http://www.adobe.com/security/approved-trust-list.html
    aa) If your app is going out to thousands++ of users in the public domain, who expect future releases you should investigate obtaining a cert from one of the AATL members.
    bb) If your app is internal to an organisation, you could make yourself a trusted authority, have a look at http://biosocket.com/tag/trusted-certificate-authority
    I can't vouch for bb) as all my development is on Mac OS X and Linux
    Hope this helps
    Cheers
    Mark
    Sep 21, 2010 3:53 PM   in reply to Authentic Sols
    You need to use a code signing certificate to pakcage an AIR application.
    Sep 28, 2010 11:40 AM   in reply to Authentic Sols
    How you generate your certificate?
    Could you try to enter your password in command line: -storepass yourpassword
    to try again?
    -ted
    Sep 28, 2010 3:09 PM   in reply to Authentic Sols
    I haven't seen this situation. One thing you can try is using the signtool.exe to sign an Windows app. with your cert to see if it works.
    http://www.tech-pro.net/code-signing-for-developers.html
    Or ask the certificate vendor if the certificate is good for code signing a Windows app.
    Sep 28, 2010 10:54 PM   in reply to Authentic Sols
    You can change the file extension to .pfx.
    -ted
    Oct 20, 2010 10:29 AM   in reply to Authentic Sols
    Hi, we're seeing the same error. Just curious if changing the extension from .p12 to .pfx worked for you? Doesn't seem to be working for us...thnx in advance. Seth
    Oct 21, 2010 7:52 AM   in reply to Authentic Sols
    K. We got it working by signing the exe with Signtool (the wizard is easy) and using the pfx file to sign it.
    Oct 21, 2010 11:25 AM   in reply to sethrd11
    Hi Seth,
    Do you use Comodo cert also?
    So ADT could not sign the native installer but the signtool could after you pakcage the native installer?
    -ted
    Oct 21, 2010 12:59 PM   in reply to tzeng
    Hi Ted,
    We have a Thawte certificate. It seemed like ADT was signing it correctly but when the app was installed on Windows it was displaying Publisher: Unknown. Signtool fixed it after we packaged it.
    hope that helps...let me know if you need more details. We build the exe in Hudson.
    Seth
    Oct 21, 2010 1:46 PM   in reply to sethrd11
    Hi Seth,
    " It seemed like ADT was signing it correctly " - Could you see the native installer is signed after ADT packaging command is run?
    "when the app was installed on Windows it was displaying Publisher: Unknown." - After the native installer installation, you look at the installed app.'s digital signature?
    -ted
