Hi
I have an xdp form which I use to produce a PDF from XML data. This form has text fields which have a Field Format of "Rich Text" and the source XML has XHTML tags to render this. When I preview the form in LiveCycle Designer this all works perfectly.
When I run this as part of a process that uses generatePDF Output however, none of the formatted text appears. When I look in the log file I get multiple occurrences of the folowing warning:
ALC-XTG-029-280: [11188] exData is unable to support the specified content. Hint(span)
2010-09-07 11:47:00,155 WARN [com.adobe.document.XMLFormService]
"span" is one of the tags that I am using in the XHTML and it works well in the preview from the designer.
Any help would be appreciated.
Dan
North America
Asia Pacific
