Hello.
I've been using Pixel Bender for over a month now.
Implementing some Image Processing Algorithms into it (Advanced Sharpening, Blurring, NR etc...).
I have some notes regarding it to my special usage - Implementing Algorithms for Photoshop / After Effects.
I'm not a programmer so I thought this would be the right tool for me, just taking care of the Algorithm.
I don't have a deep knowledge of what is possible using GPU's and what's not, All written here is in the spirit of the limitations you made clear in the PDF's of PB. Anyhow, Looking on the supported GPU's by you it seems you support pretty old GPU's. Since it's an experimental project for now and the big changes GPU had in the last 2 years you might want to reconsider dropping support for anything below DX10 to give PB all the features and flexibility it should have.
The Notes:
1. Hidden Codes - I know it is possible (Oil Painting Plug In). This should be a first priority. If I got is write, PB Kernels for Flash are compiled into some kind of a binary form. Let's use that, Let the Photoshop / AE Plug In read those files.
2. CPU Precomputing - There are some computations which suit the CPU much better than the GPU. Could the "Calculate Dependencies" concept be expanded? Let's say compute some (Small) data which later be used by Pixel Bender. A simple case would be Face Recognition. Let's say I could create a Gray Mask (Faces would be brighter grays the rest black...) on the CPU and then this mask would be passed as a source image to pixel bender. The CPU procedure could be created using AS3 or something. I know it is easy to do in Flash, yet what about Photoshop / After Effects?
3. Static Node / Loop of Nodes- Let's say I convert the image into LAB Colorspace. Now I apply an Algorithm, Convert it back into RGB and that's it. Let's say the user have 3 sliders controlling some parameters of the Algorithm applied on the LAB image. Now each time the user moves a slider the whole process is being calculated. The solution should be letting us define "Static Nodes", Which means they are calculated only once. Their result is saved for later use. They won't be regenerated. In the example above, The node which Convert the image into LAB would calculated once and that's it. This is a simple example, but there are decompositions of images which are very demanding and needed to be calculated only once. A generalization of this would be Looping over nodes. Which means do this node till something happens. This would make iterative algorithms possible in PB.
4. Changing Graphs Connections on The Fly - In a later note I'll ask for an UI improvements - Radio Buttons. Let's say I built a Graph with 2 different Local Contrast Algorithms. I allow the user to chose one of them (Radio Buttons). I want to change the graph connections according to his choice. The way things now I have to calculate both and use a boolean variable to chose one of them.
5. Performance Measure - We need some way to measure if the optimizations we do really improves performances. I know there's an option to see the FPS. I don't how accurate this is. Could be other way?
6. Image Data - I'm pretty sure it would be easy to pass from Photoshop / AE into PB some basic information about the Image. Dimensions, Min Value, Max Value, Mean Value, etc...
7. Built In Functions - Colorspace Conversions (LAB / HSL).
8. Radio Buttons.
9. Vector Casting - Casting from Bool / Int / Float Vectors into Bool / Int / Float in one line. Sometimes it is needed to cast each item in the vector individually.
10. Defining DOD() - Sometimes Auxiliary images are needed. Let us create a DOD(). Define an array of RGBA in the size we want. This would make Resizing algorithms possible in PB. This could be even some kind of Auxiliary matrix for various calculations. Moreover, it's needed for many other uses (Building Matrices for other calculations such as Least Squares methods etc...).
11. Sample Nearest Mode B - In the current method ("Sample Nearest Mode A") if the Kernel access out of the DOD() pixel it gets (0, 0, 0, 0) as a result. In Mode B I would like it to actually return the value of the nearest pixel (Euclidean Distance), Basically "Padding" the image with its border. This would result in a much better Convolutions results.
That's it for now.
Would love to hear your opinions.
Kevin / Bob, I would really be happy to hear your opinions.
Anyhow, got one more thing to add:
12. Advanced Math Tools - Many advanced algorithms requires advanced Math Tools. Could you create the flexibility needed to run them. Today there are many ways to run highly parrarlized algorithms of Matrix Algebra and Optimizations problems on the GPU:
http://http.developer.nvidia.com/GPUGems2/gpugems2_chapter44.html
http://docs.google.com/viewer?url=www.cs.columbia.edu/cg/pdfs/28_GPUSi m.pdf
Just give us the basic flexibility to run those kind of algorithms.
Hello Kevin.
Thank for the detailed response.
1. For now, even a Binary Format is better than nothing. If it is doable at the near future (Month or so) It would be great till you get the "Optimal Solution".
3. Caching or "Calculate Only Once" flag would be great. Looping would be awesome. I don't have any knowledge in GPU's but since I can do it manually (Create few nodes which refer to the same kernel) couldn't it be done naively - I write the number of loops and the program which translates my code into the GPU code just create "On The Fly" nodes of the same kernel. I guess I'm missing something.
5. If people wanna do "Heavy Filtering" Performance Measurement" is a must. A tool for that would be great. If it makes it easier it doesn't have to be in the IDE.
6. The Image size is important for any "Generalized Convolution" Kernel. Just to know when you pick something outside. There's a Bypass, a Symmetric Continuation of the Image is easily done. As long as the number is consistent with the XY plane you created in PB that's great (Means if I have a Width of 2048 I know that (2047.5, y) is the right most pixel). Any other info on the image is great. (Min Max for every Channel, Mean etc...).
10. There are many Algorithms for Calculations on the GPU (Least Squares, Conjugate Gradients etc). I saw some Cg code which creates a Texture or something like that (I guess that's just an Image) of arbitrary size. Then you use it as it was a Matrix and calculate whatever you want. Since dod() is the native way to store data in PB (and only thing which could be changed in the EvaluatePixel phase) it would be great to be able to create arbitrary one for auxiliary computations. Unless there are other ways you may hint of.
This is what I meant.
They create arbitrary sized Textures (Each is a dod() or something, isn't it?).
They loop over it.
They mention DirectX 9.0C compliance. You support older hardware I think. Might be that the reason?
11. I'm not familiar with Clamping. I meant Padding as in Matlab notation. Basically, Let's say we have image of 2048 x 2048. I use a Convolution mask of 9 x 9. Let's say the current Pixel is (0.5, 0.5) . I try to access (-3.5, 0.5). In regular "sampleNearest" I get (0, 0, 0, 0). What I would like to have back is the value of pixel (0.5, 0.5). Think of it as padding the image with the values of the pixels at the borders of the image. Look at this:
http://www.mathworks.com/help/toolbox/images/ref/padarray.html
Something like "Replicate" mode.
I don't know if it's possible, yet it is useful.
I posted a request on the Lightroom forum about PB filter.
Thank You!!!
North America
Asia Pacific
