Photoshop CS5 Clipboard Issue (Win 7)
Jan 3, 2012 12:13 PM
  Latest reply: nothgirl, Aug 27, 2013 9:27 AM
Replies 1 2 3 4 5 6 ... 8 Previous Next
    Dec 23, 2010 10:05 PM   in reply to JanGeloen
    Hi Josh,
    The file you posted fixed the issue for me.
    However I did have to install it both the "Program Files" and "Program Files (x86)" directory path you posted. I'm Woking on a Win 7 64x sytem and have both PS CS5 32x and 64x version installed.
    Belay my last. I rebooted and the clipboard in PS CS5 64X no longer works. No problem with CS5 32x or CS4 64x.
    Jan 4, 2011 9:51 AM   in reply to JanGeloen
    I had the exact same problem on my one year old Acer Aspire 5738-6745 laptop running Windows 7 Home Premium 64-bit and Adobe Photoshop CS5 Extended 64-bit.
    The weird thing is, it only happened to me after I reinstalled windows. It never occurred before.
    Anyways, I found a solution. You just have to open Notepad and type in the following:
    Windows Registry Editor Version 5.00
    [HKEY_CURRENT_USER\Software\Adobe\Photoshop\12.0]
    “AlwaysImportClipboard”=dword:00000001
    Then save it as AlwaysImportClipbd_ON.reg, close Photoshop if it is opened, and install the registry file.
    Doing this worked for me!
    Hope it helps!
    -Jordan
    Jan 5, 2011 2:51 PM   in reply to JanGeloen
    You should try to uninstall the plugin then.
    All I know is that the plugin is not the initial problem, because I have never had it installed.
    But seriously, using the registry thingy solved the problem for me.
    Sorry I can't help more
    -Jordan
    Jan 6, 2011 8:13 AM   in reply to jordancameron
    I've been following this thread with interest. It seems every time I upgrade Photoshop I have to go find this registry hack again. CS2, CS3, CS4 and now CS5. But this time it doesn't do the trick for me either. I'm on Win 7 64 bit, no add ins. I hope Adobe keeps looking because there is a problem that is not related to plug - ins, even though it seems plug - ins seem to help push the problem into the forefront.
    Jan 6, 2011 1:47 PM   in reply to Mr.benttop
    Then I should count myself as lucky! Sorry I can't help further.
    I hope this gets solved for all you folks who are still struggling!
    Jan 6, 2011 11:06 PM   in reply to JanGeloen
    The config file suplied by Josh H. at Nik should only impact Nik plug-ins, afaik. We have a bug report open and are still investigating the general plug-in SDK documentation. From Nik's findings, one case that can cause problems is triggered by calls made by 3rd party plug-ins, following a sample plug-in from Adobe.
    I'm not aware where Alien Skin is at invetigating a fix on their side, but will update here when I hear something.
    It also still isn't clear from the follow-up messages if we might have 2 or more bugs with the same end result of a broken clipboard. From what I've read here, there are 1) users with 3rd party plug-ins that have a problem, which goes away when the plug-ins are disabled, and 2) users without 3rd party plug-ins that have had to result to reg key changes. Is that how others see it? Can those reporting the reg key change as a fix confirm that they aren't running any 3rd party or non-default plug-ins?
    regards,
    steve
    Jan 7, 2011 6:55 AM   in reply to SG...
    function(){return A.apply(null,[this].concat($A(arguments)))}
    I can report that I'm not running any plug-ins, have tried the registry fix, and still have the problem.
    Jan 7, 2011 8:48 AM   in reply to Mr.benttop
    Well I should know better than this, but what I just posted is incorrect. It seems that after running the registry fix, you MUST reboot! I apparently had forgotten to do this, and once I rebooted this morning my Photoshop CS5 clipboard is working correctly! My apologies to those who may have scurried off to look at things that did not need looking at.
    Jan 7, 2011 10:56 AM   in reply to JanGeloen
    For what it's worth, when I did the registry hack, I first used notepad to create a .reg file. When it was apparent that it did not work, I used regedit to go look, and Windows 7's security configuration here had apparently prevented the .reg file from causing the entry to be recorded. So I created the entry manually in regedit. You might have a peek - maybe your security settings are like mine.
    Jan 20, 2011 8:30 AM   in reply to SG...
    I am running Photoshop CS5 with no plugins. I have the problem intermittently. The clipboard works several times, then does not, retaining the previous clipboard entry. Purging does not help. Restarting Photoshop works. I have not tried the registry hack.
    Jan 25, 2011 4:49 PM   in reply to JanGeloen
    I was definitely having this problem on my machine, and the above registry hack fixed it.
    Windows XP 32-bit
    Core 2 Duo
    Photoshop CS5 12.0 x32
    I have also had the same problem on my Win 7 / i7 / 64 machine. I haven't had a chance to see if the hack works on that environment, but I suspect it isn't environment-specific.
  • Noel Carboni
    Dec 23, 2006
    Jan 26, 2011 8:43 AM   in reply to Andrew Ochtinsky, Art.com
    As far as I can tell, using Windows 7 x64 and Photoshop CS5, there is no limit to the size of the clipboard it will import, whether or not the AlwaysImportClipboard registry value is set or not.
    -Noel
    Jan 27, 2011 8:56 AM   in reply to xxyynmop
    Everybody is just discussing here but anyone found any solution or not yet?
  • Noel Carboni
    Dec 23, 2006
    Jan 27, 2011 9:07 AM   in reply to umarmughal
    Read through the thread:
    For newer versions of Photoshop (e.g., CS5) some plug-ins by a particular company were identified as interfering with the clipboard.
    For older versions of Photoshop there's a built-in limit to the size of the clipboard it will import, unless a particular registry value is added.
    -Noel
    Jan 27, 2011 12:22 PM   in reply to Noel Carboni
    I am using Z800 Workstation, 8 Core machine, with 12GB Ram and everything on top with windows 7 64 bit, i dont feel any built-in limit here, about plugin i am not sure, is there anyway i can fix the issue as you said by adding registyr value, btw i am using CS5 and specilly i cant copy paste from illustrator which i could a week back, this is really weird.
    Feb 16, 2011 2:31 AM   in reply to jordancameron
    Hope it helps!
    -Jordan
    I'm running CS5 64 on a clean Win 7 64 system. Had problems with the clipboard just as described in this thread. No funky plugins or processes running. Adding the registry entry solved it - however I had to add the registry entry as a QWORD insted of a DWORD, or PS would hang when I attempted pasting.
    Cheers.
    Mar 29, 2011 10:05 PM   in reply to JanGeloen
    I had the clipboard paste problem with CS5 64-Bit while using Color Efex Pro. Removing the filter restored normal clipboard function. Same filter with PSE 9 did not cause the problem as it's 32-bit.
    Download of the config file fix posted by NIK Software wasn't successful at first, though I was successful after getting a tip from Dropbox support to add the ?dl=1 parameter to the url as follows:
    http://dl.dropbox.com/u/794472/SelToolInst.cfg?dl=1
    Copying the cfg file to the Selective Tool folder as described in the NIK Software post 88 solved the problem.
  • Noel Carboni
    Dec 23, 2006
    Mar 12, 2011 6:43 AM   in reply to JanGeloen
    That's great news!  Enjoy it while it works.
    One caution though:  An old software developer's adage:  If a problem seems to go away for no reason, it will usually come back by itself.
    I hope your situation proves this adage wrong.
    -Noel
    Mar 20, 2011 10:46 AM   in reply to JanGeloen
    I'm having the same problem on 64-bit Win7. No plug-ins installed, tried the registry hack -- no luck. However, the type of seleciton makes a difference.
    • If I simply select a layer (bounding box appears with handles) and click the Edit menu, the Copy commands are disabled
    • If I make a selection within the layer (marching ants appear) the Copy commands are enabled
    • If I CTRL+Click the thumbnail in the Layers panel (marching ants appear) the Copy commands are enabled
    Is anyone else noticing these different behaviors? This issue basically renders Photoshop unusable for serious production work, and it's clear this issue is affecting a large number of users. Adobe needs to get on this issue.
    Mar 20, 2011 12:36 PM   in reply to sob59
    I think this is normal behavior. To copy the contents of a layer you need to Select All (Ctrl-A) and then the Copy command will be available.
    Mar 20, 2011 1:04 PM   in reply to xxyynmop
    Doh, you're right. I'm confusing my frustration with the intermittent system clipboard, and been using Fireworks too much recently.
    CTRL+A selects all, but to copy a layer press CTRL+J or click Layer > New > Layer via Copy.
    Mar 20, 2011 9:14 PM   in reply to JanGeloen
    THREE PAGES OF POSTS OVER MANY MONTHS.  Imagine if this were a Toyota Prius with an accelerator issue.  Can you think of an industry where this is tolerated?  Dishwashers mayb?  ABOBE, get on it!  Put some resources to fix fundamental problems!
    Mar 21, 2011 12:39 AM   in reply to diveares
    Please read the topic before posting.
    We've spent a lot of time on this, and found that the causes were third party plugins and external applications (especially JDownloader).
    We've forwarded all our findings to Microsoft, but there's currently nothing we can do about it.
    Mar 21, 2011 5:35 AM   in reply to Chris Cox
    Chris - Thanks very much for the update. From all the work done to the present, do you have any guidance for Win7/64-bit CS5 users? For example, it seems prudent to check for normal clipboard function after installing any new plugin.
    Mar 21, 2011 6:56 AM   in reply to Chris Cox
    Also note that the issue appears even without any extra Photoshop plugins or out-of-the-ordinary programs installed; my clipboard issues existed on a completely clean install. I only had PS+BridgeCS5, 3dsmax2011, Autocad2011, Lotus Notes and MS Office installed. Clipboarding between the other applications worked flawlessly. Sure, Notes is a possible culprit... it's a weird piece of software. But what makes CS5 clipboard access different from that of the other applications?
    Hope you solve it til CS6.
    Mar 21, 2011 11:49 AM   in reply to mats_h
    We, and Microsoft, have no idea.  We're doing things by the book, and it should all be working.  But in the failing cases we've seen one of the OS APIs returns bogus information - as if something external was patching the API and got it wrong.
    Mar 29, 2011 2:30 PM   in reply to Chris Cox
    Adobe Team: READ THIS!
    Even if I remove all plug-ins from the Plug-ins folder, the problem is still there.
    Removing the Plug-ins folder solves the problem. So I guessed that this is
    something Photoshop is doing, and after a lot of trial and error, I found this:
    If I change the Permissions for CREATOR OWNER on the Plug-ins forlder
    to DENY, the problem goes away. But, I do not know if this makes any
    problems for any of the plug-ins. So I have tried to find out which entrys that
    has to be denied to minimize any side-effects. I found that changing any of
    the ones mentiond below, will create a error message whe applied.
    This solution also removes the problem with not being able to do more
    than one COPY - PASTE or making several PrintScreens without restarting Photoshop.
    How to do this:
    Right-click on Plug-ins folder (Make shure you are in the 64bit folder)
    Choose Properties
    Go to the Security tab
    Click on CREATOR OWNER
    Click on Advanced
    Click on CREATOR OWNER ( Inherited from C:\Program Files\ )
    Click on Change Permissions
    Click on Edit...
    In Permissions, tick the "Deny"-box for these entry`s:
    List folder / read data
    Read attributes
    Read extended attributes
    Create files / read data
    Create forlders / append data
    Write attributes
    Allow the rest in the list.
    Click OK
    There should now be a new Permission entry at the top saying Deny
    for CREATOR OWNER ( <not inherited> )
    Click OK on the to next windows and you are done.
    Start Photoshop and be happy until you find out that something is wrong, and post it here.
    I guess that it would be enough to tick only one of the boxes to make this problem go away,
    but I`ll leave that to others to find out...
    Mar 29, 2011 2:35 PM   in reply to Eagleizer
    Are you sure about that?
    Removing all the plugins, or disabling them, is the same as removing the plugins folder.
    And as far as we, Microsoft, and other users can determine:  the plugins have nothing to do with clipboard problems.
    Mar 29, 2011 2:52 PM   in reply to Chris Cox
    I tried to edit my post, but have no permission??...
    Yes ofcoarse I`m shure! I have been testing this all day ant tried to find
    out which permissions to Allow/Deny. If you give me permission to
    post mor pics, Ill show you the whole prosess.
    - Copy/Paste works fine with the solution I presented in my last post.
    - Any other settings that allows any of the settings I have listed to be
    - denied, will result in a error message.
    And so on.. no need to write it all over agein..
    Mar 29, 2011 3:06 PM   in reply to Chris Cox
    Quote:
    " Microsoft, and other users can determine:  the plugins have nothing to do with clipboard problems."
    Have they tried to completly remove the Plug-ins folder and see what happens?
    (Photoshop needs to be closed/restarted.)
    That`s what I did. And everything worked fine. I then used the elimination method to
    recreate the problem. I even made a new forlder on my desktop called Plugins and
    added it to the Photoshop folder. Without adding any plugins and as soon as I had
    startet Photoshop, the problem was back. Explain that!
    I have very little experience making permission, but as I knew that there was
    happening something to this folder, I tried every thing I could think of, and this
    is what I found. Now I expect you to explain WHY
    Could anyone with this problem please confirm that removing the Plug-ins folder
    removes the problem?
    Mar 29, 2011 4:14 PM   in reply to Eagleizer
    Without the source code to the application, and a complete knowledge of all the APIs involved -- you can't be sure.
    I have that knowledge, and am pretty sure that tweaking the plugins folder has absolutely nothing to do with the clipboard problems.
    All we know about are the JDownloader bugs (where they patch the clipboard incorrectly), and a likely bug in Microsoft clipboard APIs (which Microsoft is investigating).  The clipboard API problem does seem to be fairly random, and could easily hide for a while due to small changes in the memory layout of the app or uninitialized variables in the application memory space.
    Mar 29, 2011 4:15 PM   in reply to Eagleizer
    Yes, that is one of our earliest troubleshooting steps to rule out Adobe's plugins, and any third party plugins, as the cause.
    Mar 29, 2011 6:34 PM   in reply to Chris Cox
    I can duplicate Eagleizer's solution. The clipboard on my computer does work after the changes listed.  However....
    All of my add on Filters, except Topaz, disappeared from the interface
    And
    the Delete key no longer worked.
    Filters that disappeared after the permission change included; Digimarc; Nik Vivieza 2, HDR Effex Pro; and Imagenomic (all 3).
    Note: My Topaz filters are not in a seperate folder in the Plug-ins folder but are shortcuts.
    Win7 x64, PS CS5 x64
    Mar 29, 2011 7:24 PM   in reply to Chris Cox
    I ment that I was sure about what I found out.   I have no clue about codes  LOL
    I never said I knew what is causing the problem, I also said that it might
    have some sideeffects and others have to figure out that part. I was hoping
    that this might give you another clue to find out what is going on. It is not
    a good solution to remove the permissions as I have done, as it also
    stops many of the plug-ins from loading. But if you need to do a lot of
    printscreen - pasting, it is easy to apply and even easyer to remove
    again later. Better than restarting Photoshop for every printscreen you`re
    going to make. And it`s the only solution I have found so far. Helps me,
    hope it helps someone else..
    Mar 29, 2011 7:44 PM   in reply to ClintSteed
    Clint - then try disabling groups of plugins until you narrow down the one that is causing your clipboard problem.
    Mar 29, 2011 7:51 PM   in reply to JanGeloen
    What a waste of time among the passionate.  Adobe could fix this but doesn't.  Keep going.  All  of you. Praise management!
Actions
