Photoshop CS5 Clipboard Issue (Win 7)
Jan 3, 2012 12:13 PM
  Latest reply: G Briney, May 1, 2013 7:56 AM
Replies 1 ... 3 4 5 6 7 8 Previous Next
    Apr 21, 2011 4:41 PM   in reply to JanGeloen
    After several months of working correctly, I now have the clipboard problem again.
    The first clip will paste and never again.
    I have no new plugins.
    I tried the rename, rename Plugins folder to no avail.
    Apr 25, 2011 1:13 PM   in reply to LittleLew
    I have had this problem for some time. PS CS5 64-bit, Windows 7.  I tried renaming the plug in dir and starting PS and the clipboard works fine.  I put back the original dir name, started PS and the clipboard is broken again.  The only plug in I have purchased is Viveza 2 by Nik.
  • Noel Carboni
    Dec 23, 2006
    Apr 25, 2011 1:47 PM   in reply to haguea
    Just to be absolutely sure...  Find the Nik plug-in itself, and rename it by putting a tilde (~) in front of the name to disable it.  Make sure the problem follows just the presence/absence of that plug-in.
    Assuming that specific plug-in is at fault, It seems pretty clear, then... You need to contact Nik and demand an updated version to fix this problem.
    Breaking the clipboard is an absolutely unacceptable side effect, and th
    ey can't very well refute that it's their problem if you present them with this kind of evidence.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Apr 25, 2011 1:46 PM   in reply to LittleLew
    By the way, renaming the plug-ins subfolder then renaming it back seems VERY unlikely to solve any problem.  To the person or persons who did this and found it to make a difference, I would ask whether it was possible that any other factors changed at the same time.  It seems to me it must be a coincidence.
    -Noel
    Apr 25, 2011 2:06 PM   in reply to Noel Carboni
    Hi Noel. Being a software developer and architect for over 20 years, I would be one of the first to say that renaming the plug-ins folder and changing it back wouldn't do anything.
    But, it did.
    I have no freaking idea why it worked, but it did. I can ALT+PRT SCRN all day long and Photoshop works perfectly now. Before it was a productivity nightmare.
    Cheers...
    Apr 25, 2011 2:12 PM   in reply to Noel Carboni
    I added ~ to the names of the Viveza plug in and its selective tool plugin and the clipboard works great.
    I restored the name of just the selective tool and the clipboard is broken again.
    More experiments:
    only put ~ in front of only the selective tool, not the main plug in and the clipboard works fine.
    only put ~ in front of plug ins folder name and clipboard works fine.
    These experiments are repeatable.
    It appears, in my case, to be the selective tool that comes with the Nik Viveza plug in.  I will update my case with them.
    Alan
  • Noel Carboni
    Dec 23, 2006
    Apr 25, 2011 2:21 PM   in reply to Keith@Intergraph
    You and I seem to share the same background, Keith.  I wasn't disputing that you saw what you saw; I believe you.
    And if you're like me, you HATE it when the computer does something you can't explain.
    I can only guess that starting Photoshop without the offending plug-in present (or some other coincidental factor that occurred when you did that) caused a setting to be changed, where it would not have done that (for some reason) as long as the plug-in was present.  It's also just hard to imagine such a setting, that would unclog the clipboard.  Lots of stuff that seems unlikely all together in one theory.
    Unfortunately your particular sequence doesn't seem to be working for all others.
    -Noel
    Apr 25, 2011 2:58 PM   in reply to haguea
    reference. posts 88 and 118
    My guess is that the Nik Software fix for their Color Efex Pro 3.0, which works for me, .will also fix your problem with Viveza 2.
    Download this file as described in NIK post 88 and my 118 post
    http://dl.dropbox.com/u/794472/SelToolInst.cfg?dl=1
    and copy it to the Selective Tool folder.
    Restart CS5 and things should be good again.
    Good luck!
    Gary
    Apr 25, 2011 4:04 PM   in reply to gbriney
    It does!
    Thanks!
    Alan
    Apr 25, 2011 4:59 PM   in reply to haguea
    You're welcome Alan -- glad something works now and then!
    Gary
    Apr 26, 2011 6:44 AM   in reply to gbriney
    I wish I could say mine is working. Despite having reported here that my problem had disappeared, it appears I was a bit hasty. There are times when it works fine. However, there are many times when it does not work at all. I have not managed to find any specific pattern to the clipboard behavior, but I do know that I have no third party Plug-ins running - this is a plain vanilla Photoshop CS5 install here. To complicate my life even more, I just upgraded Acrobat to version X and I find that Acrobat now seems to have a similar problem - at least when I copy to the Acrobat clipboard, its contents are not available to any other programs.
    The Plug-in manufacturers have been taking a beating over this, but my theory is that there are a number of ways to stimulate this problem, Plug-ins being one. Otherwise, how could we have such wide-ranging reports here?
    Steve Cavanaugh :: Technical Writer:: Coinstar, Inc.
    Apr 26, 2011 7:19 AM   in reply to JanGeloen
    I've just been reading on a bit, since my latest post. I've spotted only one new post, where the name - rename didn't work. Correct? Also I see most of the people have fresh installs of CS5 (vanilla ---- @Mr. Benttop --- lol, cool expression), without other 3rd party plugins.
    So I'm going to give it a go again. Wouldn't it be possible that one (or more) of the factory plugins are messing things up for the Windows 7, 64 bit users. Reading all posts, I strongly believe this is the case. If we track down, which one, we're one step closer, right?
    Anyone out here who knows the default Plug-ins directory this well, that he or she could make an educated guess on which plug could get unstable, bearing "Windows 7" "64 bit" and "clipboard" in mind. The "victims" could try renaming that specific plugin and report their findings here.
    This should work narrowing things down for the people @ MS and Adobe. What do you reckon?
    Cheers to all,
    Yves
    Apr 26, 2011 8:03 AM   in reply to Yves Horsmans
    There are quite a lot of possibilities in the Plug-Ins folder even on a vanilla setup:
    3D Engines
      Photoshop3DEngine.8BI
    ADM
      ADMPlugin.apl
    Automate
      CropPhotosAuto.8LI
      HDRMergeUI.8BF
      WIASupport.8LI
    Digimarc
        Win64
          DigiRead.8bf
          DigiSign.8bf
      Digiread
          cs.lproj
            Localizable.strings
          da.lproj
            Localizable.strings
          de.lproj
            Localizable.strings
          en_US.lproj
            Localizable.strings
          es.lproj
            Localizable.strings
          fi.lproj
            Localizable.strings
          fr.lproj
            Localizable.strings
          hu.lproj
            Localizable.strings
          it.lproj
            Localizable.strings
          ja.lproj
            Localizable.strings
          ko.lproj
            Localizable.strings
          nb.lproj
            Localizable.strings
          nl.lproj
            Localizable.strings
          pl.lproj
            Localizable.strings
          pt_BR.lproj
            Localizable.strings
          ro.lproj
            Localizable.strings
          ru.lproj
            Localizable.strings
          sv.lproj
            Localizable.strings
          tr.lproj
            Localizable.strings
          uk.lproj
            Localizable.strings
          zh_CN.lproj
            Localizable.strings
          zh_TW.lproj
            Localizable.strings
            Digisign
          cs.lproj
            Localizable.strings
          da.lproj
            Localizable.strings
          de.lproj
            Localizable.strings
          en_US.lproj
            Localizable.strings
          es.lproj
            Localizable.strings
          fi.lproj
            Localizable.strings
          fr.lproj
            Localizable.strings
          hu.lproj
            Localizable.strings
          it.lproj
            Localizable.strings
          ja.lproj
            Localizable.strings
          ko.lproj
            Localizable.strings
          nb.lproj
            Localizable.strings
          nl.lproj
            Localizable.strings
          pl.lproj
            Localizable.strings
          pt_BR.lproj
            Localizable.strings
          ro.lproj
            Localizable.strings
          ru.lproj
            Localizable.strings
          sv.lproj
            Localizable.strings
          tr.lproj
            Localizable.strings
          uk.lproj
            Localizable.strings
          zh_CN.lproj
            Localizable.strings
                zh_TW.lproj
                  Localizable.strings
    Effects
      Filter Gallery.8BF
    Extensions
      FastCore.8BX
      MMXCore.8BX
      MultiProcessor Support.8BX
      ScriptingSupport.8li
      ScriptUIFlexPhotoshop.swf
      ScriptUIFlexServer-app.xml
      ScriptUIFlexServer.swf
    File Formats
      Cineon.8BI
      Dicom.8BI
      JPEG2000.8BI
      PBM.8BI
      PCX.8BI
      Pixar.8BI
      Radiance.8BI
      U3D.8BI
      WBMP.8BI
    Filters
      Average.8BF
      ChannelPort.8BF
      Clouds.8BF
      Lens Blur.8BF
      Lens Correction.8BF
      LightingEffects.8BF
      Liquify.8BF
      NTSC Colors.8BF
      Solarize.8BF
      Standard MultiPlugin.8BF
      VanishingPoint.8BF
      Variations.8BF
        Lighting Styles
          2 O'clock Spotlight
          Blue Omni
          Circle of Light
          Crossing
          Crossing Down
          Default
          Five Lights Down
          Five Lights Up
          Flashlight
          Flood Light
          Parallel Directional
          RGB Lights
          Soft Direct Lights
          Soft Omni
          Soft Spotlight
          Three Down
          Triple Spotlight
    Image Stacks
      statistics.8BA
    Import-Export
      Save for Web.8BE
    Measurements
      MeasurementCore.8ME
    Panels
    It might take a bit of time trying each of those for long enough to really "know" that you've found it.
  • Noel Carboni
    Dec 23, 2006
    Apr 26, 2011 8:42 AM   in reply to Mr.benttop
    If it's helpful at all, here are lists of the actual files installed by Adobe in the Photoshop area in a new Photoshop CS5 installation, and what they look like after having been updated to 12.0.3...
    http://Noel.ProDigitalSoftware.com/temp/OriginalPSCS5Files.zip
    http://Noel.ProDigitalSoftware.com/temp/UpdatedPSCS51203Files.zip
    -Noel
    Apr 27, 2011 1:09 PM   in reply to Nik Software, Inc.
    About a month ago, I bought a Wacom tablet. Up until that point, everything had been going perfectly fine in my 8GB/3Hz dual core laptop Windows Professional 64bit and Photoshop CS5 64bit world (well, except for Machine Wash filters, but that's another story).
    So, I thought I was going out of my mind when, the week after installing the tablet, every time I tried to copy and paste something from Illustrator to Photoshop (which I've done tens thousands of times over my professional life), it wouldn't work. The first one would, but after copying and pasting in Photoshop, I could only paste what I had copied in Photoshop, nothing else from an external program would paste in... unless I quit Photoshop and restarted.
    http://dl.dropbox.com/u/794472/SelToolInst.cfg completely fixed the problem. I've put copies of it in my software updates folder, with the instructions on where to put it for the next time I have to install Photoshop/Wacom on to an otherwise clean system.
    Thank you for posting this, I'd probably still be ripping my hair out in frustration without it!
    May 2, 2011 5:04 PM   in reply to C Towsley
    I have all the Nik plugins installed on a WIN7 64bits with Photoshop CS5 64bits.
    When I rename the "Silver Efex Pro 2" and "Selective tools" folders, the copy-paste function is back.
    I need to rename both of them (else it won't solve my problem).
    Very annoying. Is there an other way around to solve this issue ?
    Fred
    May 2, 2011 5:31 PM   in reply to gueho_fred
    Hi Fred,
    Did you try the .cfg file from post #88 yet? (http://forums.adobe.com/message/3353707#3353707)
    It has seem to do the trick specific to NIK's selective tool. We still don't have solutions for other 3rd party plug-ins, or cases where no 3rd party plug-ins are loaded.
    regards,
    steve
    May 5, 2011 12:42 AM   in reply to SG...
    Did you guys try this registry edit? It worked for me.
    1. In Windows, go to Start and then Run.
    2. Type in “Regedit” without the quotes
    3. Once in the registry editor, go to HKEY_CURRENT_USER > Software > Adobe > Photoshop > 12.0
    4. Right-click in the 12.0 folder and select New > QWORD (64-bit Value) and name it “AlwaysImportClipboard” without the quotes
    5. Double click the name and change the Value Data field from 0 to 1
    6. Restart Photoshop and paste away!
    Disclaimer: Modifying the  registry can cause serious problems that may require you to reinstall  your operating system. We cannot guarantee that problems resulting from  modifications to the registry can be solved. Use the information  provided at your own risk.
    BTW, I got this from http://www.atlanticbt.com/blog/adobe-photoshop-clipboard-copypaste-bug -fix/ and modified just slightly.
  • Noel Carboni
    Dec 23, 2006
    May 22, 2011 8:56 AM   in reply to FrankNuberry
    That patch is bogus.
    It's already been shown that even the 64 bit Photoshop doesn't read a QWORD from the registry for that value.
    Do you know anything about programmatically accessing the registry?
    -Noel
    May 21, 2011 7:13 AM   in reply to JanGeloen
    I have been pulling my hair out on this one for a long, long time.  Very aggravating.  Slows productivity down tremendously.
    I moved Viveza 2 (by Nik Software) out of my plugins folder.
    Now, finally, clipboard pasting seems to work OK in Photoshop CS5 64-bit.
    At least so far.
    I guess I need to move Viveza back into my plugins folder when I need to use it.
    Pain in the butt!!!
    May 21, 2011 9:55 PM   in reply to mediaman54
    The NIK configuation file for the Selective Tool (post 88) worked for me with NIKs Color Efex Pro 3 for several weeks as I mentioned in posts 118 and 157. Then I installed NIK Silver Efex Pro 2, which caused the clipboard paste problem all over again. I contacted NIK, who assured me that SEP2 did work under Win7/64, and sent me another cfg file to copy to the Selective Tool folder. SEP2 worked OK for a few days, then the ciipboard paste problem came back. I uninstalled SEP2, and the clipboard worked OK with NIK CEP3 still installed.
    Now the clipboard problem is back again with no changes to the system except for a rash of Win7 updates in the meantime. I'm waiting for a response from NIK who still assure me that SEP2 does work with Win7/64. Maybe I'll only connect one machine to the internet and stop getting Win updates on the other if things ever work right again...
    It seems to me nothing gets fixed until there's a threat to the bottom line... Clearly this problem has no effect whatsoever on Win7/64 sales, and probably virtually none on CS5. Well, maybe it's momentarily positive for Adobe -- I use PSE9 which is 32bit to run the NIK software when I need it. Maybe some other folks are doing this too. Of course there's the PIA message that I have PSE installed on more than two computers. I only use two computers for goodness sake -- unfortunately I have had a couple of HD problems lately, and so now I need to call PSE9 support yet again.
    Anyway NIK is the place to complain, because they realize the pinch on sales may be actually be felt when word of mouth gets out about this problem -- and once out, it takes a long time to recover when customers figure out how to do things differently...
    Message was edited by: gbriney - grammatical errors corrected
  • Noel Carboni
    Dec 23, 2006
    May 22, 2011 6:32 AM   in reply to gbriney
    Windows Updates are virtually always a good thing.  It's not a reasonable strategy to block Windows Updates.  You have thousands of people at Microsoft working to improve the software you have already purchased, and believe me they put a LOT of effort into making sure it doesn't break things unexpectedly.
    I suspect you have a latent problem on your system having to do with clipboard access, that came up coincidentally.  Most folks don't see it.  I have not had a single problem with the clipboard myself, having never installed any Nik software, but I keep 100% up to date with Windows updates.
    Have you ferreted out all the files Nik installed into Photoshop?  You may need to compare file lists and modification dates to do this.
    If it can help, here's a list of the files normally installed by Adobe:
    http://Noel.ProDigitalSoftware.com/temp/Photoshop_CS5_Standard_Install ation_Files.zip
    -Noel
    May 22, 2011 12:36 PM   in reply to Noel Carboni
    I thought it was apparent that I was being facetious about the Win updates, hence the wink smiley -- but hey I wouldn't want to mislead anyone to do something that's not in their best interest.
    Since you haven't had any problems, and would like to help, how about installing the free NIK Silver demo on your system, and let us know what happens?
  • Noel Carboni
    Dec 23, 2006
    May 22, 2011 1:32 PM   in reply to gbriney
    Sorry I misinterpreted that, but the wink smiley wasn't quite enough to know you weren't serious.  A lot of people think it IS a good idea to cut their systems off from Internet access and updates.
    I assume you're talking about Nik Software's "Silver Efex Pro 2", right?
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 22, 2011 2:19 PM   in reply to Noel Carboni
    Okay, I've downloaded the trial version of the Nik Silver Efex Pro 2 plug-in on a very clean virtual machine running Windows 7 x64, which I use for testing.
    Test 1:  Try running Photoshop CS5.1 prior to installing the Nik plug-in.
    • I copied several images both large and small from another application (IrfanView)
    • I was able to successfully paste them into a document in Photoshop.
    Test 2:  Installed Nik Silver Efex Pro 2
    • Noted an extension panel when Photoshop was first started.
    • Copied several images, both large and small from IrfanView.
    • Was able to paste them into documents in Photoshop.
    • Ran the Nik Silver Efex Pro 2 plug-in, got the trial dialog.
    • When the Silver Efex Pro 2 dialog came up, the display was corrupted.  Wasn't able to do anything but close the dialog.
    • Was able to copy and paste more images into Photoshop.
    • Ran the Silver Efex Pro 2 plug-in again, saw a corrupted dialog again.
    • Tried hitting Return in the hopes it would take it as OK.  It did and I got a new grayscale layer.
    • Was able to copy and paste successfully into Photoshop thereafter.
    I don't appear to be seeing an issue with the clipboard here with this system, though Silver Efex Pro 2 itself isn't working properly.
    I'm guessing the Silver Efex Pro 2 plug-in just isn't compatible with the OpenGL driver VMware provides, but I'm not about to install this turkey of a plug-in on my main workstation.  It looks as though it gets pretty intimate with Photoshop, by the appearance of the extension panel, and also by the fact that it created a new layer - something a filter plug-in is not legally able to do.
    I made a note of the files before and after the install.  These are the ones the Nik installer added:
    c:\Program Files (x86)\Adobe\Adobe Photoshop CS5.1\Plug-ins\Nik Software\Selective Tool\Dfine2.config
    c:\Program Files (x86)\Adobe\Adobe Photoshop CS5.1\Plug-ins\Nik Software\Selective Tool\SelectivePalette.8li
    c:\Program Files (x86)\Adobe\Adobe Photoshop CS5.1\Plug-ins\Nik Software\Silver Efex Pro 2\Silver Efex Pro 2.8bf.lnk
    c:\Program Files (x86)\Adobe\Adobe Photoshop CS5.1\Plug-ins\Nik Software\Silver Efex Pro 2\SilverEfexPro2.config
    c:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Plug-ins\Nik Software\Selective Tool\Dfine2.config
    c:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Plug-ins\Nik Software\Selective Tool\SelectivePalette.8li
    c:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Plug-ins\Nik Software\Silver Efex Pro 2\Silver Efex Pro 2.8bf.lnk
    c:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Plug-ins\Nik Software\Silver Efex Pro 2\SilverEfexPro2.config
    Anything else in particular you'd like me to test?
    -Noel
    May 22, 2011 6:39 PM   in reply to Noel Carboni
    yep that's the one!
    May 22, 2011 6:59 PM   in reply to Noel Carboni
    Noel,
    Thanks for doing the quick test and sharing the results -- you're a prince. For what it's worth, the 32-bit NIK applications seem to have many dedicated fans who appreciate having a new layer created labeled with the filter used -- I don't have a dog in that fight being new to SEP2.
    I think it would be great if you could leave NIK SEP2 installed for a while, because the problem doesn't always show up immediately. I strongly suspect that the clipboard issue is much more likely to happen when CS5 (and the OS) are stressed by CS5 with many large files open, after being open for many hours, and with many other windows open competing for memory.
    I realize the OS contribution may make it arguable about where responsibility lies, but my feeling is that applications getting low on resources should give an explicit warning rather than just becoming erratic and eventually crashing. Graceful decline to allow saving work is always better IMO.
    Best regards,
    Gary
    May 29, 2011 1:36 AM   in reply to JanGeloen
    Update.
    I just got an entirely new machine. Again Windows 7, 64 Photoshop and 12 GB of RAM. The only difference. This is photoshop 5.5 and a clean install (No new plugins added). And yes. The clipboard issue is back. Renaming the Plug-ins folder and renaming it back will help, but this time it will not last.After a few restarts you need to the trick again. I've read a bit on since last time, but the plugins mentioned and solutions were 3rd party plugins, right? I suspect there's at least one factory plugin causing the same problem, that gets resolved by fixing the 3rd party plugin. I'm quite convinced it's a factory plugin, since renaming the plugin folder will make the clipboard work. If so. I'm planning to rename my subfolders sequentally and log on what Plugin subdirectory the issue gets fixed and narrow down from there to pinpoint the "bad" one. Has someone got a clue which factory plugin might be causing it? If so I'll start there.
    Cheers,
    Yves
    May 29, 2011 10:28 AM   in reply to Yves Horsmans
    And yet the problem doesn't happen for everyone - so the default plugins aren't a likely cause.
    There might be some other factor involved (system locale, drive or folder names, who knows).
    May 29, 2011 11:12 AM   in reply to Chris Cox
    To me, this is now more probably a RAM problem. When you can't paste in Photoshop, try to paste it in an other application. If you can, this is Photoshop. If you can't or the image is altered (for example, in two colors), this is your system. When you can't, try a smaller selection.
    Personally, I've encounter years ago problems with Photoshop not pasting while other application still did.
    Actually, when I snapshot my entire double screen, I'm can't always paste, whatever the application, but I can still copy-paste small windows.
    People should test further and try to paste there "clipboarded" image somewhere else.
    May 29, 2011 2:06 PM   in reply to Lacrymocephale
    You're coming into this a little late -- several months in fact, look at the preceding 4 pages or so of comments. The obvious stuff was done long ago.
    May 29, 2011 2:20 PM   in reply to Chris Cox
    It's quite clear that 3rd party plugins can break the normal clipboard function, and removing it (them) will restore normal function if it was normal before. However, fixing the 3rd party plugin doesn't guarantee normal function will last. So I'm sure it's correct to say there are multiple ways for the external clipboard paste function to fail. There are so many variations on the problem that it's necessary to characterize experience with lots of qualification, because it may change tomorrow.
    Internally, that is within CS5, the clipboard continues to function as always (in my experience to date) -- the connection to external applications which put images on the clipboard is lost. I believe that text may still be copied to CS5, but I'm not sure if that's always true, and even if it is, it's of little value to the user.
    May 29, 2011 2:26 PM   in reply to gbriney
    I already posted in this forum: http://forums.adobe.com/message/3204129#3204129
    You're just a troll.
    ...And I won't feed you more.
    May 29, 2011 2:27 PM   in reply to Lacrymocephale
    sorry I don't go in for name calling...
    May 29, 2011 5:20 PM   in reply to JanGeloen
    I narrowed down the problem on my machine to the Viveza 2 plugin from Nik.
    Nik sent me a "SelToolInst.cfg" file, (one for Win, one for Mac)
    Instructions were to replace the .cfg file in a certain folder.
    C:\Program Files\Adobe\Photoshop CS5\Plug-Ins\Nik Software\Selective Tool
    My folder of that name did not have this file, but I put the new one in there anyway.
    Seems to have solved the problem for me, so far.
    But judging by some of the comments in this thread, it could recur any time.
    Sigh.
    Jul 11, 2011 7:33 AM   in reply to mediaman54
    Hello
    I run PS CS5 in Windows 7 x64 and (in a laptop) in Win 7 x32.
    My problem isn't pasting into Photoshop CS5, but copying and pasting from CS5 into other programs. I can paste into CS5, but can't copy/paste from it, except by using a third-party screenshot app. (True in CS5 x64 and x32, in both machines.)
    I have worked through each of the relevant fixes suggested in this thread and its companion thread, 'Clipboard still not working? Darn you'.  I've disabled plug-ins (though I don't have any Nik plug-ins, and only 1 third-party plug-in: Mask Pro 4). I run CS5 as an Administrator. I've added AlwaysImportClipboard to the Registry as a Qword and a Dword. I've unloaded /disabled all possible startup apps.
    I've used Photoshop since v.7, and never had this problem before, though I understand from the posts that others have had it in earlier PS versions.
    I can copy and paste to/from the same files, if I open them in any other graphics app, from MS Paint to Acrobat to Omnipage.  If it's a Windows problem, not a Photoshop problem, I find it strange that it only happens in Photoshop--and for me, at least, only in CS5. I formerly used CS4 on my current computers, with all other apps/startups the same as they are now, and I could copy and paste freely.
    In the posts to date I haven't seen any info about Microsoft's response (if any) about the problem. Is there one?
    Mary
  • Noel Carboni
    Dec 23, 2006
    Jul 11, 2011 9:43 AM   in reply to Mary Bernard
    In Photoshop, go into Edit - Preferences - General.
    Do you have [ ] Export Clipboard checked?
    -Noel
    Jul 11, 2011 9:58 AM   in reply to Noel Carboni
    Noel
    Aha! No I didn't, but I do now. Can't imagine how it got turned off!
    Many thanks for your spot-on help -
    Mary
    Sep 29, 2011 2:07 PM   in reply to JanGeloen
    I have the same problem and I'm totally aggravated. My PS install is totally vanilla and it's 32 bit. All I can do is save the file and then open it in PS, copy it, and then paste it.
    Totally aggravating and I don't see any good solutions here.
    My clipboard is working fine outside of PS (or at least out of Adobe CS), so I can paste away into every other app.
    I can copy/paste from Adobe to Adobe...but not from anything else (Word, Web, screenshots) to PS.
    Help??
    I tried the registry hack and it worked for a short while but it stopped working almost immediately. It's hard for me to believe this is a Microsoft problem when every other app is respecting my clipboard, but for those made by Adobe.
    I don't have NIK or any other third party plugins installed.
    Copy/Paste is a critical function. And from what I've seen online, this problem has been floating around since 2009. Sucks that there aren't any reasonable competitors and I'm stuck with broken software or need to keep spinning my wheels to try to make it go.
    Sep 30, 2011 7:23 AM   in reply to JanGeloen
    Hey,
    I found a solution to workaround this issue, if you have Nik Software installed, just disable the auto lunch palette tool when PS start.
    windows 7 x64, master collection cs5.5
    Sorry for my bad english
Actions
