Dreamweaver CS5 on Windows 7 64 bit. I tried using the builtin updater and manually downloading the update using Chrome, but the result is always:
Dreamweaver CS5 HTML5 Update
Installation failed
Suggestions?
I renamed C:\Users\MyUserName\AppData\Local\Adobe\AAMUpdater\1.0 to 1.0- (effectively deleting it) and reran the installer (AdobePatchInstaller.exe) manually. The 1.0 directory was recreated, and aamu.log contains the following:
2010-09-12T21:30:34: >>> Adobe Updater Log Begin >>>
2010-09-12T21:30:34: UpdaterCoreImpl::InitLogFile : Application Version 1.0.0.67
2010-09-12T21:30:34: UpdaterCoreImpl::InitLogFile : cmdline option --> -logFile = C:\Users\MyUserName\AppData\Local\Adobe\AAMUpdater\1.0\aamu.log
2010-09-12T21:30:34: UpdaterCoreImpl::InitLogFile : cmdline option --> -logLevel = 2
2010-09-12T21:30:34: UpdaterCore : Returning from << UCInitialize >> Returning with outErr Value => = 0
2010-09-12T21:30:34: UCProcessPatchProgress : Receive Packet ID = . = 0
2010-09-12T21:30:35: UCProcessPatchProgress : Receive Packet ID = . = 9
2010-09-12T21:30:43: UCProcessPatchProgress : Receive Packet ID = . = 9
2010-09-12T21:30:44: UCProcessPatchProgress : Receive Packet ID = . = 9
2010-09-12T21:30:44: UCProcessPatchProgress : Receive Packet ID = . = 15
2010-09-12T21:30:45: UCProcessPatchProgress : Receive Packet ID = . = 16
2010-09-12T21:30:46: UCProcessPatchProgress : Receive Packet ID = . = 17
2010-09-12T21:30:46: UCProcessPatchProgress : Receive Packet ID = . = 13
2010-09-12T21:30:46: UCProcessPatchProgress : Received Done from patch installer along with exit code value7
2010-09-12T21:30:46: UCGetprogress : Updates install returning state for reffId = AdobeDreamweaverCS5-11.0/11.0.3
2010-09-12T21:30:46: UCGetprogress : Updates install returning state = 44
2010-09-12T21:30:46: UCGetprogress : Updates install returning outError = 7
2010-09-12T21:30:46: UCGetprogress : Updates install returning percent = 0
2010-09-12T21:30:51: Returning from << UCTerminate >> call with value = 1
2010-09-12T21:30:51: UpdaterCoreImpl::ShutdownLogFile : Going to call ShutdownESDLogFile()
2010-09-12T21:30:51: <<< Adobe Updater Log End <<<
BTW, this machine boots from an SSD (C:), and CS5 is installed on E:. Not sure if that is significant or not. Previous updates installed fine.
Even if the uninstall-restart-reinstall-update "solution" worked (it didn't for me) it would be impractical here. I manage a volume license in labs and can't imagine doing this on 200 Macs (10.6.4, CS5 DP). To say Adobe's installers and updaters are Byzantine is a huge understatement. At least twice a year I wrestle with something like this with Adobe software. Last summer it was trying to get the Deployment Toolkit to work (it never did. I used Iceberg and trial and failure to finally get a deployable package built) now it's what SHOULD be a simple extension installer but appears to be obfuscated beyond belief. I don't really want to read all those xml files but it looks like that's where I'm headed.
Adobe, why can't you just use standardized installation methods? On Macs that means .pkg files! So easy yet you refuse to do it! Why? Sheesh.
I'll post back if I find a solution...
This is another example of Adobe's updaters simply not working (search also for Acrobat Pro 9.3x > 9.4x issues).
See also http://blogs.adobe.com/csupdates/2010/08/31/dreamweaver-cs5-11-0-3-upd ater/
I run into this constantly (I work in higher ed IT).
today I updated my DW CS5 and running into the same problem that you guys already had. After spending hours figuring out the issue, I found sth really interesting. That is when you click on Help -> About DW , it still says 11.0 but when right click on the file dreamweaver.exe itself -> properties -> detail tab, it says 11.0.4.4993 . I dont know if this is correctly updated or not, can someone who successfully updated confirm this ?
North America
Asia Pacific
