Expand my Community achievements bar.
SOLVED
Problem with Date calc
Avatar
Level 1
I'm trying to get this FormCalc calculation to work:
Date2Num (form1.Page1_SF.EffectDates.endDate, "M/D/YYYY") - Date2Num (form1.Page1_SF.EffectDates.startDate, "M/D/YYYY")
Evently, I will divide it by 7 to get the number of weeks, but the initial calculation does not want to work after entering in the dates.
Can you tell me what is wrong with my forumula?
Thank you.
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
Odd. Something strange about the Date2Num format. I changed them in the calculation to "YYYY-MM-DD" and it works. Note it is calculating the number of elapsed days.
if (HasValue(form1.Page1_SF.EffectDates.endDate) & HasValue(form1.Page1_SF.EffectDates.startDate)) then
$.rawValue = Date2Num(form1.Page1_SF.EffectDates.endDate.rawValue,"YYYY-MM-DD") -Date2Num(form1.Page1_SF.EffectDates.startDate.rawValue,"YYYY-MM-DD")
else
  $.rawValue = null
endif
Steve
View solution in original post
Avatar
Do the date patterns on each date field match the date patterns on your calculation?
Steve
Avatar
Level 1
Yes, here is the date pattern:
date{M/D/YYYY}
I'm looking at your PDF now.
Avatar
If you can forward the form to stwalker.adobe@gmail.com I would be happy to take a look.
Steve
Avatar
Correct answer by
else
  $.rawValue = null
endif
Steve
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
