How to frameserve from Premiere CS5?
Sep 23, 2010 9:54 AM
  Latest reply: nitrobg, Oct 20, 2013 9:29 AM
Replies 1 2 3 4 5 4 Previous Next
    Sep 13, 2011 9:35 AM   in reply to Jeff Bellune
    Hi Jeff,
    O.k i got it!
    Plus, if the target app only works with one color space, for example if it imports any footage but converts everything to RGB24, then you would be introducing an unnecessary color space conversion by sending it YUY2 footage.
    So now the 10k $ question is how to figure out what color space app X works with. I have not yet found any information about it regarding Sorensson or ProCoder. They don't really print those thing with large letters. (Or, i have not found the right place yet..)
    /Roger
    Sep 13, 2011 10:57 AM   in reply to Averdahl
    Well, Squeeze just accepted a YUV 4:2:0 source file and output a YUV 4:2:0 MOV file.  So it seems you can feed Squeeze whatever you want from Pr.  The only caveat is that I don't know if Squeeze is internally converting the YUV video to RGB before encoding it as YUV again.  I don't see any logic in doing it that way, but I'm not a software engineer.
    -Jeff
    Sep 13, 2011 11:28 AM   in reply to Averdahl
    at me with ProCoder works very well
    Nov 1, 2011 6:04 PM   in reply to Jeff Bellune
    hello,
    trying to get this afs workflow up and running
    does anyone know if handbrake accepts watchfolders?
    i keep setting the 'source' to my watchfolder
    and AME begins to generate the avi intermediate file
    but then just shows a green check mark for completed
    and handbrake never gets started...
    (the reason for this is to be able do 2pas vbr high 4.1 bluray exports
    to see if they load up into encore without needing to transcode...)
    thanks for any help,
    jeffrey
    Nov 1, 2011 7:18 PM   in reply to Stile35_DJ
    hello,
    up and running with afs and squeeze 7
    however, i am only getting 1.80 fps video transfer rate
    some scenes are heavily effected some are just straight footage
    all of which are avchd 1920x1080 22mbit interlaced
    on win7 cs5.03, quadro4000, 24gbram,many hdd's, i7 930 at 2.8ghz
    does the fps transfer rate seem too slow
    (i read somewhere that squeeze is not that good at multi threading
    and it kinda shows: cpu is nowhere near 100percent usage
    like when exporting out of media encoder...)
    any help is appreciated...
    jeffrey
    Jun 21, 2013 4:23 AM   in reply to tfi productions 44
    There is glitches in exported video using advanced frameserver.
    Oct 17, 2013 7:02 AM   in reply to muzflowers
    I confirm this, I'm getting major headaches to get a proper frameserver for CC. The only workarounds are to export it as Lagarith or any other lossless codec and then compress it with third-party program.
    For the record, I use AVCHD 1080i50 workflow and the output video has major glitches due to wrong frame ordering. I've tried all kind of settings in Premiere and AFS, nothing seems to help.
    Oct 17, 2013 7:54 AM   in reply to nitrobg
    I have glitches only in audio, not in video.
    Oct 17, 2013 8:07 AM   in reply to muzflowers
    I use AFS in CC to TMPG5 and it works just fine.
    If you got issues you need to tweak the 3rd party software.
    Oct 20, 2013 9:29 AM   in reply to Ann Bens
    Turned out that the After Effects' multithreading option caused the glitches. I turned off Render multiple frames simultaneously in After Effects and the problem seems to be solved.
    For the record, I use MeGUI with x264.
    However, I'm getting weird cracking noises on the audio that don't appear in the project itself. The workaround is to export the audio as uncompressed PCM and then encode it to AC3, but what can I do to avoid the issue?
Actions
Bookmarked By (2)
