Flatten control point handles
Sep 30, 2010 5:19 AM
Hi Adobe experts and charitable types :-)
I am working on some type at the moment and wanted to use the anchor points and control handles as an effect in the final artwork.
I tried using "Show Bounding Box" after flattening the text and did a screen capture to Photoshop.
Using this method the anchor points are visible, but unless you select particular anchor points with the direct selection tool,
the control handles are never visible. I would also have to import it back to Illustrator and use live trace, which I don't think would work very well...
Is there a way to easily convert Illustrator's guide marks and control handles to artwork?
Any suggestions greatefully appreciated!
Many thanks :-) J
    Sep 30, 2010 5:25 AM   in reply to Jonathon P
    ALWAYS state the VERSION of Illustrator you are using. No less than SIX DIFFERENT VERSIONS of Illustrator are daily represented in this forum. The functionality differs in certain areas across all of those versions.
    function(){return A.apply(null,[this].concat($A(arguments)))}
    Yes. Draw them. Use Symbols, Brushes, Custom Arrowheads, and/or Graphic Styles to store the treatment as a one-click setting. Most expedient method DEPENDS ON VERSION.
    JET
    Sep 30, 2010 6:30 AM   in reply to Jonathon P
    What would "flatten" mean, in this context?
    I can write a quick javascript for you, but I'd need to know how would you want the anchor points and control lines and points represented. Blue, rectangles for the anchors, circles for the control points, and a thin line -- how big? How thin?
    I need to know because the script adds them as actual objects to your image. (So you might want them to be created on a new layer as well.)
    Sep 30, 2010 8:08 AM   in reply to Jonathon P
    Okay. I'm running short on time here, but I'll take a look at it to-nite.
    Shouldn't be too hard.
    Sep 30, 2010 11:35 AM   in reply to Jonathon P
    Well I was at work
    The script is a bit too long to comfortably put inside this message, and it seems you still can't attach files, so download it from my site: www.jongware.com/binaries/drawArtHandles.zip
    Select one or more objects, and it'll make a layer called "Visible Art" (or use the existing one) and draw all of the handles, anchors, bounding boxes, and whatnot onto it. It 'supports' (i.e., draws handles) text, groups, and simple paths. Everything else -- bitmaps, symbols, graphic effects ... -- gets the I'm Ignoring You treatment.
    (I noticed a small bug: sometimes Illustrator doesn't want to cooperate, and refuses to set the color for the "bounding box" frame. What's up with that? I don't know -- everything else seems to be in order.)
    Here is what it looks like -- now doesn't that look like you've got all handles selected at the same time?
    Sep 30, 2010 11:56 AM   in reply to [Jongware]
    That is socool!
    Of course I could have written the script as well…I mean if I knew how to write a script that is!
    Sep 30, 2010 12:07 PM   in reply to [Jongware]
    Theun,
    Obvious you never sleep.
    Sep 30, 2010 1:58 PM   in reply to Larry G. Schneider
    The sleep I miss throughout the week, well, I make up for that in the weekends -- actually, I'm already looking forward to the next one. (Yawn..) Four down, one day to go.
