could not save because write access was not granted (Mac OS)
Jan 3, 2012 12:49 PM
  Latest reply: thysonsacclaim, Mar 24, 2014 6:25 AM
Replies 1 2 3 4 5 ... 10 Previous Next
    Feb 3, 2011 4:14 PM   in reply to C-S-S
    Two machines trying to open or save at the same time is how we normally expect this to happen.
    Other applications sometimes have a bug that holds the file open too long.
    Seeing it that often probably means an issue on the server, or with the network protocol code in the OS.
    Another error that often appears before this one; makes refernce to the disk image beig changed since the file was opened, although nobody else has worked on the file.. Very random!
    If it hasn't been touched, then that means it was modified on the server, or that something is returning the wrong date/time stamp for the file (server or OS code).
    Sorry for all the questions, essentially im on Adobe's side, but my IT department are saying photoshop is the problem not the network..
    Lol. Your IT department needs a bit more experience.
    Feb 4, 2011 1:34 AM   in reply to C-S-S
    Our IT department have no idea how to solve it or create a workaround. Other than to say we'll be switching to a mac server and connecting via AFP at some point soon which will solve the problem?
    AFP & Mac server won't help.
    As you can see in the other posts the issue even happens when a single Mac user accesses a Mac sharing volume.
    Feb 4, 2011 1:47 AM   in reply to Chris Cox
    Copying the file to your local machine, then copying it back is much, much safer.
    I can hardly believe you are saying this.
    I'm sure you're aware of the fact that these days people work on thousands of pictures a day in a collaborative environment.
    No matter who's fault this is, the fact is that no  other program I use exhibits this issue.
    The fact that you've had the same problem with Cocoa and Carbon versions would indicate that the fault is more likely in the server protocol or OS.
    You're probably right that something is wrong with my server. Still, no other program I use ever exhibits this problem.
    The fact that numerous other users in various different environments suffer from this issue makes me wonder if your approach is adequate.
    If there are tons of customers out there in a world with imperfect server structures - wouldn't it make sense to use a file handling procedure that deals with these imperfections?
    Obviously most other programs can deal with it, Photoshop can't.
    Feb 4, 2011 10:14 AM   in reply to j. scriba
    Most other applications don't do as much error checking and reporting as Photoshop.   Photoshop is telling you about errors that most other applications would simply ignore.
    It's not a huge number of customers with server problems -- many people are using network servers without any such problems.
    And our file handling is supposed to deal with this sort of problem, but somehow an OS or server API is not doing the right thing.
    Yet when we test it on our huge mix of systems, everything works fine.
    Feb 4, 2011 10:34 AM   in reply to j. scriba
    I have to agree with j. scriba and others who point out that this problem or similar errors occur across different versions of photoshop and different kinds of servers, but not at all with any other programs. I've worked in multiple shops over the last 20 years and it's always been gospel that "you can't work off the server" with Photoshop, but somehow this is never a problem with any other program saving files.
    It seems exceedingly odd that no one at Adobe has ever been able to reproduce this problem, and yet the official recommendation is to not work off servers and to only work locally. Obviously this has been going on for years and Adobe has probably heard thousands of complaints, and yet never able to reproduce it. That's just some kind of amazing luck. I'm sure it must have occurred to someone at some point to go out into the field and see if they could figure out why it happens to so many users in so many different environments, right?
    Let's think: why does this never happen with InDesign or Illustrator files? Why can't Photoshop emulate these other widely used Adobe products in the way it saves files? Clearly it is doing something different, but why? What is so special about Photoshop's save protocol? Sure, it may very well be a "bug" in all these server configurations, but the fact that it keeps recurring over the years would indicate that there is SOMETHING about how Photoshop saves files that's, well, a little weird. Right? And why exactly can't Adobe change it?
    Here's an analogy. We release jobs to printers for our clients all the time, typically InDesign packages. We spend a lot of time preflighting and checking to make sure everything is in order. Sometimes things don't print correctly, and sometimes it is our fault and sometimes it is the printer's fault. Either way the client isn't happy. Even when it is clearly not our fault, we examine our workflow to see if we could make changes that would reduce the chances of errors. We change our "product" to accommodate other vendors' "bugs". I guess if we were basically the only prepress vendor in the world (or at least the dominant one), we could just say "it's the other guy's fault, deal with it". But even then, we'd rather have happy clients. Wouldn't Adobe rather have happy customers?
    Feb 4, 2011 11:04 AM   in reply to Todd Shirley
    We know that server problems exist.
    We've seen customer having problems, and how long it takes them to find the cause and fix the network or server issues.
    So we should say: "In a perfect world you can work on a network server, but your world probably isn't perfect, so don't do it or you'll end up regretting it."
    And yes, we've only been able to reproduce similar issues with servers that had a known bug in them (mostly third party).
    Yeah, we've gone out in the field, visited customers -- and found servers with known problems (old versions, misconfigured, faulty hardware, etc.).  Once we found a new bug in AppleShare (and Apple got a patch out pretty quickly).  Once those problems were removed, everything worked reliably.
    ID and AI don't do as much error checking.  We know that.  Many other applications don't even try to do a safe save.
    What does Photoshop do differently: check for errors, tell the user about errors, and do a safe save to minimize file loss.
    Oh, and we have changed our saving code several times over the years -- yet the errors persist on some servers (but never ours).
    Many, many times we have worked around OS and server bugs.  But we have to know about the bug, and it has to be something we can work around.  You can't always work around the OS bugs (like low level memory and file IO code).  In this case we can't work around what we don't know about and can't reproduce.
    We are trying to do the right thing for our customers, otherwise we would have given up on this issue a long time ago.
    Think about it: you keep reporting a problem that looks like a bad server config, we keep testing and never finding a problem -- shouldn't we have concluded that it's all in your server and given up?
    Again: we are working hard to do the right thing for customers.
    As of right now, we have no evidence whatsoever of a bug in Photoshop.
    But we are continuing to investigate.
    Feb 4, 2011 11:15 AM   in reply to Chris Cox
    I think the correct way to put it is"not a huge number of customers REPORT server problems". Like many in this list, I've been doing this for a long time, and every environment I've worked in and every peer or IT person I've ever spoke to about this has encountered similar problems "working off the server" with Photoshop. Most companies just do what we do and what Adobe recommends: copy files local to work on them and then copy them back to the server when done. We don't waste time reporting known bugs to Adobe. (or writing lengthy rants in forums )
    OK, why don't these other Adobe products do much error checking? And you call it a "safe save", but many in this thread report LOSING data. How is it that doing MORE error checking and doing SAFE saves results in data loss, but ID and AI do neither and users experience no data loss or problems?
    Message was edited by: Todd Shirley
    Feb 4, 2011 11:15 AM   in reply to Todd Shirley
    it seems like Adobe should send an engineer out into the real world to one of the thousands of businesses who experience this problem on a regular basis and try to figure out what they are doing wrong.
    We have, repeatedly.  See my previous post.
    We've even brought a few servers in house to analyze - same results: server issue.
    Which is why we ask customers how they work, and if they have experienced any problems.  Many do work directly off the server, without problems.
    Others have problems with the server, then solve the server issue and continue to work without problems.
    considering how this server issue has been a known problem for at least 10 years
    That's just it:  this is not a known bug in Photoshop.
    The only known problem is "networks and servers are difficult to setup, maintain and troubleshoot".
    If there is a bug, we'd love to find it and solve it.  But we've been chasing this sort of problem for years, and always finding the problem is external to Photoshop.
    Feb 4, 2011 11:40 AM   in reply to Chris Cox
    Chris, it would be helpful to me if you could explain exactly how the Photoshop Save works.
    I cannot understand how any application would end up reporting that it couldn't write a temporary file -- when it already has.
    Or how, if it can't write the temporary file, it still manages to allow or cause the original file to be deleted?
    Photoshop *is* exhibiting peculiar behaviour here no matter what the underlying cause of the problem is...
    Feb 4, 2011 12:09 PM   in reply to Martin Orpen
    Safe save:
    write to a temporary file
    swap/replace the temporary with the original
    The error seems to occur when moving the temporary to replace the original file.
    The only way the original could be deleted is if the OS or server mangles the swap/replace operation.
    Feb 4, 2011 2:55 PM   in reply to Chris Cox
    May I suggest that you simply add an option in Photoshop file handling settings like:
    a) use safe saving (may block saving with faulty servers)
    b) use standard saving (may lead to file loss with faulty servers)
    This way, you can still tell users that whatever problem they encounter will be their server's problem and you strongly suggest working off local drives.
    And many users will opt for a mechanism that so far has worked great for them in ID, AI and other software.
    After all, you let users even chose tile sizes, cache levels and other fancy stuff under Photoshop's hood. Why not such a fundamental setting?
    You won't get any more complaints from people who can't take proper care of their systems, and we get a less elegant solution that simply works. Everybody wins, right?
    Feb 4, 2011 3:37 PM   in reply to j. scriba
    Without reproduceable cases to test - we have no idea if that would work.
    It all depends on what is wrong with the APIs or servers.
    ID and AI probably aren't working - they just aren't reporting the error (and loss of your files) to you.
    Feb 5, 2011 1:30 AM   in reply to Chris Cox
    Em.... Chris, somehow this discussion is turning weird.
    I was suggesting you implemented (as an option for Photohop users) the exact same file handling that InDesign and others of your applications are using.
    I suggest that you test it to the same level of confidence that you are using in those other products and give users the choice of whether they want Photoshop to run the extra mile of super-safe saving (that may cause their faulty systems to prevent saving at all) or do like the others do (at their own risk).
    Are you saying that InDesign is a faulty product that keeps losing files?
    Are you saying that everybody who is reporting this Photoshop-problem is probably losing files with their other software?
    Are you saying that I'm too (insert a nicer word for "stupid") to realize that I'm constantly losing files, even though I'm pretty sure I've never lost  a file in my setup?
    I'm actually pretty paranoid about my data. That's the whole point of saving to a remote raid system.
    I feel that the process of Photoshop forcing me to copy workfiles to local drives and keep track of which version is replaced by which introduces an element of human error that much more prone to accidentally losing an edited file.
    Why do you insist of forcing an extra level of file handling security on Photoshop users if they are content with how all of their other applications are handling this?
    If I had the choice of disabling "safe saving" (which might be on by default) and then lose a file it's my choice and my system that screws up.
    Why can't I make this choice?
    Why do you feel the need to tell your users that what they normally do with their other software (and Adobe's other products) is a wrong way of doing things and that some of us are driven crazy by Photoshop's file handling only for their own good?
    Feb 5, 2011 11:08 AM   in reply to j. scriba
    How would it help to change our code from "safe and telling you about problems" to "unsafe and not reporting errors"?
    Then people would lose their documents and never know that a problem happened.
    That's not something we would even consider!
    If there is a problem in Photoshop, we'll fix it.
    If there is a bug in an OS routine, we'll file a bug and try to get it fixed.
    But we will not intentionally damage our software just to let you unknowingly lose work!
    Feb 5, 2011 2:12 PM   in reply to Chris Cox
    To summarize:  1.Two of Adobe's flagship products, InDesign and Illustrator, save files in a way that is "unsafe and not reporting errors" which leads to a situation where "people would lose their documents and never know that a problem happened."   2. As far as we can tell, Illustrator & InDesign users are completely unaware of this major fault in these products and are somehow ignorant of the fact that they are losing data on faulty servers. These users live in a state of ignorant bliss where they never notice data loss or report saving errors to Adobe.  3. Photoshop saves files in a way that is "safe and telling you about problems" which is superior to the way InDesign and Illustrator save files.  4. For years, Photoshop users have been complaining about difficulty saving files to servers and occasional data loss and corruption, even though Photoshop saves files in a way that is safer and better.  5. For some reason, Adobe doesn't want to implement the safe and superior file saving method with InDesign or Illustrator, nor give Photoshop users the option to use the inferior (but widely used and well liked) saving method used by InDesign and Illustrator.  Is that about it? What am I missing here?
    Feb 5, 2011 2:25 PM   in reply to Chris Cox
    I see, so InDesign, Illustrator etc. are broken products.
    Amazing that Adobe is very happy charging substantial amounts of money
    for them and a large number of customers are happy buying and using
    them.
    Suppose there was car that ran 200mph  smoothly but would
    automatically perform a screaming emergency brake maneuver once its
    radar detected a pothole in the street.
    You would like to drive through potholes just like all the other cars
    on the road do and ask the car maker to fit that radar with a switch
    so you can disable it on the less-than-perfect roads you need to drive
    on.
    The car designer would say: There's nothing wrong with the car and
    potholes are nothing we can fix. We can't let you go without the
    radar, you might have an accident. We suggest you drive on perfect
    roads only.
    Would you appreciate that attitude?
    Feb 5, 2011 3:29 PM   in reply to Chris Cox
    So the .afpDeleted* file that is all that remains your cherished image on the remote disk is what exactly?
    If it is the temporary file, then it *has* been written -- so the dialogue box is incorrect.
    If it is the deleted original then why does the dialogue box show the temporary file name and not the original file name?
    If you can't recreate this issue in-house then perhaps it might be worthwhile giving customers who are suffering a modified version of PS which dumps more information to the dialogue box or console during the Save operation?
    Feb 5, 2011 6:13 PM   in reply to Todd Shirley
    Each product is a separate team.
    And no matter how many times we request something, suggest something, write bugs against other products, etc. - we cannot make those other teams do anything (no matter how badly they mess up).
    Feb 5, 2011 6:15 PM   in reply to Martin Orpen
    We don't know.
    Again, we've never been able to reproduce the problem.
    We are already trying to connect with some customers experiencing this problem to get them an instrumented copy of Photoshop.
    Feb 8, 2011 7:06 AM   in reply to Chris Cox
    The problem has occurred again today so I can now confirm that the .afpDeleted* file is the original image.
    I can also confirm that Time Machine wasn't involved as this happened around 40 minutes after the last backup.
    Again, I don't get how this error can be blamed entirely on the OS?
    There are no other hidden or temporary files at this location so it appears that Photoshop is NOT safe saving *anything* (or is both saving AND the deleting the new data) before flagging the original file for deletion.
    And how on earth does the new name of the original file, now flagged for deletion, end up in the warning dialogue in PS?
    Confusing
    Feb 8, 2011 10:30 AM   in reply to Martin Orpen
    That tells us something.  That means that the OS API to replace the original file failed partway through.
    (otherwise the original would still be in place)
    Again: if the OS and server were working correctly, this should be impossible.
    Photoshop wrote to a temporary, called the OS to replace the original with the temporary, and the OS failed partway through that operation.
    If the save failed at points where Photoshop has control then the original would be intact, both files would be there, or the newly saved file would be there.
    OK, now we have more information for our investigation - thank you.
    Feb 21, 2011 10:04 AM   in reply to sean-gloss
    Yep...
    Getting the exact same thing here at my office...
    Just had one of the production guys in my office ******** about it.
    OS 10.5.8
    Photoshop CS 5
    Working off desktop, not the servers... also if working off the server its windows 2003, extremezip IP 7XX (latest)
    One of the interesting things is that when he gets the error... it does it for every file.. even a new one he creates.
    Fun fun fun fun... NOT
    Feb 21, 2011 10:11 AM   in reply to JohnKGibson
    If you get that error saving to the desktop, then you have a very different problem from the server issue being discussed here.
    Working locally, that would indicate a permissions problem or something has corrupted the state of the OS or memory.
    As usual: try disabling all third party plugins, all haxies and utilities that might interfere with Photoshop (especially file system utilities).
    Feb 23, 2011 4:22 PM   in reply to brunerd
    I too am experiencing this with Xinet.
    Are you serving Xinet of a MAC server, I cannot remember...
    My current theory has to do with POSIX permissions. If you are managing server access using ACLS from other apps, inheritance is like CRAP on OSX for directories, even with a mask. File inheritance works great, which causes an issue with who owns a file once a new directory is added with incorrect permissions.
    This is a theory that I am testing against right now.
    Feb 23, 2011 5:31 PM   in reply to augur165
    Actually we are using IBM servers running Linux for Xinet and before that SGI Irix
    Feb 23, 2011 6:33 PM   in reply to brunerd
    Do you have this problem with servers that aren't running Xinet?
    Mar 1, 2011 9:48 AM   in reply to sean-gloss
    On our setup, we think (tentatively) that we have found the culprit.
    We turned off the DFS service on the server (which I believe is an SBS 2003... I'm just the Mac guy, so I don't deal with the PC servers directly).
    We were only using the replication feature of DFS.
    We also use ExtremeZ-IP and we had this save issue with both the older and the newest ExtremeZ-IP.
    As soon as we turned off DFS/Replication, the server was more responsive and these errors stopped appearing.
    The issue originally appeared for us as soon as we upgraded to Snow Leopard and Adobe CS5.
    It's been about 4 weeks since we made that change, and so far so good (we hope!).
    Hope that helps someone...
    -Rob Steward
    Mar 8, 2011 4:35 PM   in reply to sean-gloss
    Problem has recently surfaced for us with upgrade to CS5.
    OSX10.6.5 iMac and Xenon clients with Xserve 10.5.8 and Xsans.
    Active directory with about 7 acls in use (and sometimes many more due to 10.6.4/6 Finder bug that duplicates acls on folder copy).
    Managed preferences for OS clients.
    get access error with name of temp file and original psd or eps on server is gone.
    multiple save attempts fail. save-as works.
    Chris, really appreciate your commitment and comments on the design philosophy behind PSD's saves.
    Moving to Cocoa APIs is brave but needed as Carbon's days are doubtless numbered.
    If I can offer any further info to help get to the root of this issue in CS5 or if you would be interested in us testing with a special version of PS, let me know.
    Mar 16, 2011 10:02 AM   in reply to Chris Cox
    okay... just wrote a lengthy reply and Adobe forums responded with "Page not found" and pressing back in browser history returned me to a blank reply slate... What an awful way to handle forms... Now I shall to remember to Cmd+A -> Cmd+C before submitting.
    Anyways... a short summary:
    We've started seeing this on one workstation this week. To me it looks like it may have something to do with permissions on the PS executable folder vs user system rights vs user share rights. In short ACL conflicts.
    I'll be digging into the ACLs in the morning.
    Do you want us to run a debug logging PS CS5? It would also be possible for you to get a peak via remote if you'd like some real world hands on with the error
    Mar 18, 2011 8:56 AM   in reply to Martin Orpen
    Like Martin, I too have a team of designers and production staff who would be willing to try a version of Photoshop with additional debug code in hopes it might help understand this issue.  We're seeing it on CS5, running on OS X.6.5 and X.6.6 on MacBookPros and Quad core Xenons, writing to an Xserve running 10.5.8, via Apple native AFP.
    One thing that caught my eye in this coversation is the idea that backup software could have the file open and cause a conflict (#46).  I use CrashPlanPro for backups, which will be backing up changed files multiple times/day.
    To others seeing this: what backup software are you using, and could it potentially have a file marked as open while the backup occurs?  Might NOT having backup software intalled on Adobe's test servers be part of why they've not been able to reproduce this?
    Apr 5, 2011 7:04 AM   in reply to sean-gloss
    We started to encounter this exact error message after upgrading 3 workstations to OSX 10.6 and Photoshop CS5. The error appears on a random basis on all CS5 stations, roughly once in 3 days. Other Photoshop installations like CS4 or older are not effected.
    All data being worked on is located on our SUN server running HELIOS EtherShare.
    FYI we never had problems working network-based with PhotoShop since the days of MacOS 8.
    Our tech guys found a way to force this CS5 error to occure by setting a write-lock onto the edited files resource path.
    After provoking the error by hitting "Save" there were now two write-locks present on the resource path: the one set by ourselfs and a new one set by the CS5 client while the data path of the file still had no write-locks.
    We then opened support case 0182160238 to adress this problem on March 14th.
    Today we got an automated answer which directed us to info note http://kb2.adobe.com/cps/406/kb406793.html
    Long story short: Adobe will not support any network-related CS5 issues. WTF?!
    Apr 5, 2011 11:37 PM   in reply to Foli_RM
    Hello,
    we are the "tech guys" of which Foli_RM speaks;-)
    You must set a write-lock (DENY_WR) onto the edited files _resource fork_ . Then save the edited file in PS5 and the error occurs.
    Greetings
    Apr 21, 2011 11:43 AM   in reply to sean-gloss
    Well, the answer in my case was simple, after reading some of this I tried saving to a different drive...no problem, good luck all
    Apr 27, 2011 2:58 AM   in reply to sean-gloss
    Hello
    I have the same problem as reported above at one of my costumers.
    Server used: Helios EtherShare (latest patches)
    Clients: 10.6.4 - 10.6.7
    This problem started with CS5 (no problem with CS3 and CS1)
    It only occurs with .PSD files. Never with .TIF, .JPG or any other filetypes in Photoshop CS5
    It also only occurs with Photoshop. No problem with InDesign, Illustrator or any other third party applications.
    I am also intrested in why Photoshop should save in a diffent matter than InDesign or Illustrator. Suggesting that files get lost in these other applications saves because of not using "safe save" is just absurd. You and I would have heard about this a million times from the users by now. A lost file is ALWAYS reported - we all know that. Why not try to implement the same "unsafe save" mechanism as the other applications use with great success?
    Apr 27, 2011 9:20 AM   in reply to Holger Netterby
    Photoshop does a safe save, and uses newer APIs in some cases because Photoshop already moved to Cocoa and the other apps have not.
    Photoshop saves PSD files just the same as it saves other files - there is no difference in the APIs used.
    Yes, we know that files do get lost in other apps because they don't do a safe save.  We aren't going to intentionally change our code to make you lose data.
    But so far this still looks like a major bug in an OS API causing problems on *some* file servers.
    And yet we can never reproduce the problem here with any of our file servers.
    Apr 27, 2011 12:09 PM   in reply to sean-gloss
    I´m sorry to play the devils advocate but I still find it strange that the only applications that have ever failed a server save for my customers are the three listed below.
    I support around about 75 companies with between 2 - 150 users each, most of them in graphic production. I have during 20 years only ever heard of 3 applications causing a save failure (to a server or locally) on a regular basis. Two of them fatal (IE the files is gone after save attempt) and the third just gives an error.
    Microsoft Power Point 2004 - Working on large files sometimes caused the file to vanish from the server (or the local disc) when saved. Was fixed by Microsoft after some updates. Not completely shure but I think this only happend on non-US versions of Office. (sometime between 2004 SP2 - SP3 if I remember right)
    Adobe Photoshop - I (my customers) have only encountered this error with CS5 and Helios EtherShare up until now.
    Apple Final Cut Pro - Saving gives error -50 unknown file. Workaround - save file locally and then transfer the file to the server. This does not ever cause the file on the server to vanish! (Most FCP versions)
    What I want to point out with this is that I can guarantee that I would have heard about files getting corrupted during save. If files is un-openable after a save customers tend to throw themselves on the phone to get support and demand that a backup get retrived. This is just natural behavior. The point being that when I heard this CS5 save error I assume an error in Photoshop CS5 because all other applications work as expected.
    Who do you think I should report this error to? Apple or Helios or both?
    Apr 27, 2011 3:43 PM   in reply to Holger Netterby
    They're not the only ones to fail.
    They are the only ones that TOLD you that they failed.
    Again, many applications fail to complete the save and don't do enough error checking to tell you about it.
    And we do hear about files being corrupted or lost when saving to a server, all the time. (and I don't mean just from Photoshop)
    We've investigated the problem many times. In the past, it was mostly server bugs, bad networks, and once a bad OS API (that got fixed).
    This time, it looks like another bad OS API that can fail in a way that it is not supposed to ever fail (losing documents).  Since the whole point of that API is to do a safe save and not lose documents, that is particularly bad.  But we can't do much about that.  If we use other APIs, we have other problems.  If we use this API, it is supposed to work, but may require an OS update before it works correctly.
    This is one of many reasons why we say to save and open files locally and not off the server -- there's too many things involved that are outside of our control, and that we know go wrong in some situations.
    Apr 28, 2011 2:10 AM   in reply to Chris Cox
    If there would be no difference in API's people won't keep reporting this CS5 save error on a broad basis of file servers. Just check back in this thread on how many and different server OSes the error appears.
    We did not pay attention to it first but we can confirm what Holger Netterby just reported: the CS5 save error occures only when working with .PSD files. It never happens with .TIF or other formats. Still a network or file server issue?
    We contacted HELIOS about this problem and they found a way how to reproduce this specific CS5 error.
    The important point is: it's not limited to HELIOS EtherShare servers as long as you can access file resource fork information. For example HELIOS used their method successfully on a plain OSX Server's share  - no HELIOS EtherShare involved - to force the error. Read prom-sup's post how it's done.
    btw:
    We opened a Adobe Support Case about this problem and were told that the usage of CS4 and CS5 is not supported on network shares. All files to be worked on should be copied to the local drive first, then worked on, then copied back.
    Don't you think Adobe's graphical industry customers have better things to do then shuffling Terabytes of .PSD files between servers and clients only to work fine with Photoshop?
    Apr 28, 2011 9:34 AM   in reply to Foli_RM
    I'm the one looking at the code, and telling you that there is no difference.
    You are guessing that there is a difference because you see people mostly reporting a similar problem on PSD files.
    Yes.
    Apr 28, 2011 12:29 PM   in reply to sean-gloss
    Having the exact same problem, UNACCEPTABLE adobe!!! If photo shop doesn't delete the file and is "safe" why does the file disapper, and say it was deleted in the servers access logs. Figure it out, and stop trying to blame the problem on users servers. Copying the file to your desktop to work on it is a big load of crap!
Actions
Bookmarked By (4)
