christinett
Flyer/poster generator?
Oct 1, 2010 10:23 AM
I'd like to have a simple flyer generator on my site but don't know where to start.  Are there any pre-created generators out there that I can download, customize and incorporate into my site?  Or tutorials on how to create my own?  Or... ?
    Oct 1, 2010 11:59 AM   in reply to christinett
    Are you trying to create a print design object? It's not clear what you are asking. If it is print design, you're in the wrong domain.
    Oct 1, 2010 1:01 PM   in reply to christinett
    OK. That's a little clearer. Thanks. Those are great links, by the way.
    The first link (http://www.petbond.com/flyerentry.php) uses a script written in PHP called flyermaker.php. You could do a google on this. It might be a free script or at least readily available. The second (http://www.bestfriends.org/nomorehomelesspets/resourcelibrary/flyermak er/flyermaker.cfm) uses what probably is a proprietary script to Best Friends. At least it is a script hosted on their site.
    You could try google'ing "pdf scripts". This is not a simple undertaking. You would be better off finding a package designed for this.
    Hope this helps. Sorry I couldn't be of more help.
    Barry
    Oct 1, 2010 1:16 PM   in reply to christinett
    Glad to hear it. If you encounter further problems - with PHP or whatever - do come back.
    Oct 6, 2010 12:00 PM   in reply to christinett
    Well, I just did a Google on "flyermaker.php" and it came back with a lot of results, including
    Best Flyer Maker Free Download: EVH Flyer Creator, Easy Flyer ...
    Flyer Maker Shareware and Freeware Downloads by EVH Software Solutions Inc., ... PHP Report Maker 1.0 PHP Report Maker is a powerful reporting tool that can ...
    www.softwaregeek.com/flyer-maker/p1.html
    also www.petbond.com/flyerentry.php
    did you find these? Were they useful.
    Did you check with websites you referenced to see if they would allow you use of their scripts?
    How are you with  PHP?
    Barry
    Oct 8, 2010 3:13 PM   in reply to christinett
    If you are a non-profit, you might be in a good position to ask.... I looked a little more at those links, and your interpretation was correct. I will try some other searches, but am not very hopeful.
    In the meantime, have you thought about alternatives?
    If your visitor creates a flyer from your site, s/he will probably want to download and print it. Most people can not print anything larger than 8 1/2 x 11 or 8 1/2 x 14. It would be a lot easier to create a web page that the visitor could then print. Not the easiest task, especially if you keep the number of options relatively restricted (i.e., do you need 20 styles of borders?). You could do this as if it were an email. Actually doing it that way would save the user from having to download the flyer. There are many scripts and options for doing email like this.
    What do you think?
    Barry
    Oct 10, 2010 2:50 PM   in reply to christinett
    The .doc is definitely a dead end. As you said, many do not have MS Word.
    Can you supply a link to that site that generates flyers but whose output is distorted? That shouldn't happen. There might be a pretty easy way to keep from doing so. Sounds like it might be a graphic gone awry.
    I think what is making this hard is that you are trying to do a print job in a non-print medium. It's difficult enough to get webpages to print nicely. Not many designers ever think that someone might want to do that to their page(s).
    Whether email or webpage, you are still dealing with the same html, with one big difference: email programs do not allow the use of css style sheets, so all coding has to be done in-line. Among others http://www.webassist.com offers an email generator. It is easy to use. As I recall, it is relatively inexpensive. With what you describe as your formatting needs, it should work quite well.
    Hope this helps.
    Barry
    Oct 10, 2010 4:05 PM   in reply to christinett
    Do post that link when you find it. Just curious.
    I'm a little surprised at not being able to insert an image in a .pdf file. And I should think that 's a pretty important part of the flyer. Do you have Acrobat Pro 9? I saw something in the forum about the Pro's SDK. Look at this http://forums.adobe.com/message/1921432#1921432.
    It sounds like you're pretty much all set. Let us know if you run into any problems along the way.
    Jun 13, 2012 9:54 AM   in reply to christinett
    Hello!
    I realize this is an old thread, but I'm trying to do *exactly* the same thing as the OP—even looking at the same script (flyermaker.php).
    Have you found a solution to this? What I'd like to do is to create my own free "lost dog" flyer generator, but with a different design. I can manage to tinker with the CSS to change the appearance, but I have no idea how to make my own flyermaker.php.
    Thank you so much for any input!
    Jan 16, 2013 3:28 AM   in reply to christinett
    dear you may get the help of freelancer at http://www.solutioninn.com. visit the site and hire a freelance to get your work done I'm also running website and I on & off get help of freelancers to make such changes and advancements.
    thanks & Regards,
    Bill.
