j_wolfe
Adobe Drive 2.0 and SharePoint 2010?
Oct 4, 2010 10:41 AM
Has anyone had any success connecting Adobe Drive 2.0 to SharePoint 2010?  On the SP side, we have installed the admin tool pack and enabled the web parts (both the CMIS producer and consumer parts), but have not been able to successfully connect via Drive 2.0.  I see that a number of people have been working with Alfresco as their CMIS backend, but haven't seen any other CMIS compliant server examples.  Is there any documentation out there for connecting other than the Adobe Drive 2.0 Admin guide?
Thanks ---
    Oct 8, 2010 7:21 PM   in reply to j_wolfe
    We have never tested Drive 2.0+CMIS connector with SharePoint 2010.
    Regards,
    Guo Wei
    Feb 26, 2011 11:01 AM   in reply to weiguo@adobe.com
    Guo Wei,
    I'm trying to do the same here, connecting Adobe Drive 2.1 with Sharepoint 2010.
    This is the URL to my CMIS-enabled SharePoint Library that I use as "Server URL" in Adobe Drive CMIS Connection:
    http://sharepoint_server/_vti_bin/cmis/rest/document_guid_here?getrepo sitoryinfo
    When I try connect I'll get "Authentication failed".
    How do I know when the "Server URL" is right? When I type http://sharepoint_server/ I'll get the same response.
    Is there a log-file for Adobe Drive and the CMIS-connection?
    In this document there is some information and a short preview of the XML-file but nothing about SharePoint: http://help.adobe.com/en_US/creativesuite/cs/adobedrive/CMIS_Connector _Tech_Note.pdf
    This is the xml-file that SharePoint generates: http://dl.dropbox.com/u/2665693/sharepoint_output.xml
    I think there are (or will be) way more customers interested in a connection with SharePoint than Alfresco to be honest.
    Thanks!
    Mar 1, 2011 1:35 AM   in reply to Andreas-PG
    I wanted to know if anybody on this thread was able to connect to a CMS server from Adobe Drive CMIS connector. I am part of a team responsible for making our DAM system CMIS compliant and the client we are targetting is Adobe Drive with its inbuilt CMIS connector. We are also facing difficulities in establishing communication between Adobe Drive and our system.
    As mentioned before on this thread is there any log file, events log for Adobe Drive that can give more information about attempts to establish connection?
    Also, I wanted to know how Adobe Drive client gets authenticated with  any CMS/DAM using its CMIS connector. What is the mode of authentication  used - is it HTTP basic, digest authentication or something custom. So I  am not sure what would Adobe Drive send to get authenticated and what  would it expect in the response. How do we pass back the session token  that we will create.
    Mar 1, 2011 2:01 AM   in reply to mandarpkulkarni@gmail.com
    Drive CMIS connector uses HTTP basic authentication. Actually, for HTTP level communication, we use Apache HTTP client library. Drive CMIS connector acts as normal HTTP client. Maybe you can use a network sniffer tool to capture the HTTP packages between client and server.
    For SharePoint 2010, we are working with Microsoft to resolve interoperability issues. Hope to have better support in next Drive release.
    Feb 25, 2013 1:10 PM   in reply to weiguo@adobe.com
    have the interoperability issues been resolved?
    Mar 1, 2013 3:05 AM   in reply to whothennow
    unfortunately not
    Mar 14, 2013 12:11 PM   in reply to whothennow
    As noted earlier, we’ve been working with Microsoft to resolve the interoperability issues. Users are now able to connect to MS SharePoint 2013 via the Adobe Drive CMIS connector that’s included with the Adobe Drive 4.2 update. MS SharePoint 2013 also includes key fixes to make the integration work.
    Aug 15, 2013 10:30 AM   in reply to Laurel Zimmer
    Does this have any effect on integrating with Sharepoint Server 2010?
    Aug 15, 2013 10:51 AM   in reply to stock50nm
    No
