i have being trying to load an external variable from a php file into a actionscript variable.i know how to bind php data from mysql to datagrid but this is not what im looking for,Example say a varaible in php has value =5, this value should be passed to a actionscript variable limit,so now limit will have value 5.
I am using flex 3 and i have tried lot of examples listed on google,i have gone through all the tutorials,codes..etc..all of them were made using cs3 or cs4.And when i ran them i dint get any output at all.Either i got thatproperty loader wasnt defined or nothing in my textarea.
if possible please guide me on the following or kindly give a small sample that works on flex3.i am also not sure of what i shud write in my php file.
i have added the code of my mxml file for this which is not working and shows me a blank textarea.
Any help would be appreciated..thanks in advance
<mx:Application xmlns:mx="httw://www.adobe.com/2006/mxml" xmlns:custom="test.external.*" layout="absolute" initialize="load()">
<mx:Script>
<![CDATA[
private function load() : void {
var loader:URLLoader = new URLLoader();
loader.addEventListener(Event.COMPLETE, onComplete);
loader.load(new URLRequest(https://localhost/external.php));
private function onComplete(e:Event):void {
ext.text = URLLoader(e.target).data;
</mx:Script>
<mx:TextArea id="ext" x="296" y="199" >
</mx:TextArea>
<mx:Button click="load()" x="343.5" y="274">
</mx:Button>
</mx:Application>
You can try this.
<mx:HTTPService url="https://localhost/external.php" method="POST" useProxy="false" id="httpService"
resultFormat="text" result="resultHandler(event)"/>
public function resultHandler(evt:ResultEvent):void
var res:String=evt.result as String
Instead of res you can use your variable to assign the php result.
Jayagopal.
North America
Asia Pacific
