How to debug this?
Oct 5, 2010 5:21 PM
Under Flash Player 10.1 on Windows, we are suddenly getting an error that did not occur under player 9 or 10, and does not appear in any version of player on Mac.  The biggest problem is that the entire error stack is inside the Flash framework, initiated by a callLaterDispatcher.  Flash complains that an index is out of bounds, but gives zero information on what the parent or child object is, or what the index number is that is being passed.
I have all bug given up trying to find the source of the problem in our code, which runs for several thousand lines, covering half a dozen internally created classes.  I see a 'hook' at (C:\autobuild\3.2.0\frameworks\...), but cannot even see that folder on my system? (yes, I have 'show invisible' set for my file system -- this is Windoze XP, for what it's worth).
Any suggestions on how to track down a problem like this?
RangeError: Error #2006: The supplied index is out of bounds.
    at flash.display::DisplayObjectContainer/getChildAt()
    at mx.core::Container/getChildAt()[C:\autobuild\3.2.0\frameworks\project s\framework\src\mx\core\Container.as:2334]
    at fl.managers::FocusManager/addFocusables()
    at fl.managers::FocusManager/activate()
    at fl.managers::FocusManager()
    at fl.core::UIComponent/createFocusManager()
    at fl.core::UIComponent/initializeFocusManager()
    at fl.core::UIComponent/addedHandler()
    at flash.display::DisplayObjectContainer/addChild()
    at mx.core::Container/http://www.adobe.com/2006/flex/mx/internal::createContentPane()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx\core\Contai ner.as:4665]
     at  mx.core::Container/createOrDestroyScrollbars()[C:\autobuild\3.2.0\fra   meworks\projects\framework\src\mx\core\Container.as:4410]
    at  mx.core::Container/createScrollbarsIfNeeded()[C:\autobuild\3.2.0\fram   eworks\projects\framework\src\mx\core\Container.as:4359]
    at  mx.core::Container/createContentPaneAndScrollbarsIfNeeded()[C:\autobu   ild\3.2.0\frameworks\projects\framework\src\mx\core\Container.as:4175 ]
    at mx.core::Container/validateDisplayList()[C:\autobuild\3.2.0\framework s\projects\framework\src\mx\core\Container.as:2691]
     at  mx.managers::LayoutManager/validateDisplayList()[C:\autobuild\3.2.0\f   rameworks\projects\framework\src\mx\managers\LayoutManager.as:622]
     at  mx.managers::LayoutManager/doPhasedInstantiation()[C:\autobuild\3.2.0   \frameworks\projects\framework\src\mx\managers\LayoutManager.as:695]
    at Function/http://adobe.com/AS3/2006/builtin::apply()
     at  mx.core::UIComponent/callLaterDispatcher2()[C:\autobuild\3.2.0\framew   orks\projects\framework\src\mx\core\UIComponent.as:8628]
    at  mx.core::UIComponent/callLaterDispatcher()[C:\autobuild\3.2.0\framewo   rks\projects\framework\src\mx\core\UIComponent.as:8568]
    Oct 5, 2010 11:14 PM   in reply to BurtJ
    Not sure why you are having version-specific problems.  This call stack is
    typical of mixing Flash fl.. components with Flex components.  They are
    incompatible.
    Oct 5, 2010 11:53 PM   in reply to BurtJ
    Try launching this from the debugger. When the app breaks you can look into the variables/expressions panel and find which component is throwing this. Then look at what children is that component adding/removing.
    Oct 6, 2010 12:46 AM   in reply to BurtJ
    Yeah, I think I misunderstood.
    Normally when you have a flex app, even if breaks in the flash player code, you can still see the debugger freezing and you can find the causing component. When you have a flash component acting as a flex one I think that might not work anymore.
    Oct 6, 2010 1:04 PM   in reply to BurtJ
    fl.. components and mx.. components cannot co-exist. It works sometimes,
    but often you will hit these issues with the fl FocusManager.
    Oct 6, 2010 5:32 PM   in reply to BurtJ
    flash.. is not fl..
    You can use all the flash.. stuff you want.  Somehow, a fl.. component
    got into your app.  You can use link-reports to find out how if it isn't
    apparent.
    Oct 6, 2010 6:18 PM   in reply to BurtJ
    The fl.. components come with the Flash IDE in the CreativeSuite.  And
    even older versions before that.
    If someone starts using the built-in components from the Flash IDE in a Flex
    app, trouble like this occurs.  The call stack listed an fl.. class which
    is why I am offering this as the root cause of the problem.  I still don't
    see how changing player versions could really cause it unless there was a
    subtle timing issue.
    You can create your own components in Flash and use them in Flex via the
    Flex/Flash Component Kit, but you can't use fl.. components in those
    components.
    If you don't want to wonder all night, you can always load up on caffeine,
    get back in your car and head back to the office.  However, if it helps, the
    call stack is like a fingerprint.  It has implicated the fl.. components.
    They will need to be removed at some point.
    Oct 7, 2010 11:51 AM   in reply to BurtJ
    If looking through the code didn't work try looking over the user interface for elements like: Flash Checkbox, Flash RadioButton, Flash TextInput, Flash TextArea, ColorPicker, etc. Your code breaks because of a UIComponent subclass so you can look here : http://livedocs.adobe.com/flash/9.0/ActionScriptLangRefV3/index.html and go through the list of subclasses, and their subclasses, etc ... and see if your Flash components use any of them.
    Good luck, you're gonna need it .
    Oct 7, 2010 1:57 PM   in reply to BurtJ
    Looking at the original stack dump, it indicates that there is no debug info
    for the fl.. components.  So it could be in one of those Flash SWF files.
    Oct 7, 2010 8:42 PM   in reply to BurtJ
    FlexBuilder won't use fl.. component unless someone has placed them in the
    lib-path.
    Did you verify the exception is the same and has fl.. in the callstack?
    Did you verify from the debugger console that only one SWF got loaded?
    If you have done both, then generate another link-report and post it.
    Oct 8, 2010 10:56 AM   in reply to BurtJ
    It is possible that in 10.1 or due to some other change, something is sizing
    slightly differently than before and causing scrollbars to show up.  The
    fl.managers.FocusManager can't handle the way Flex puts up scrollbars.
    May 9, 2013 3:30 AM   in reply to BurtJ
    RangeError: Error #2006: 提供的索引超出范围。
              at mx.core::Container/getChildAt()[E:\dev\4.y\frameworks\projects\mx\src \mx\core\Container.as:2751]
              at MainApp/getChildAt()[D:\!Source\SrcClient\Main\AppMain\src\MainApp.mx ml:239]
              at fl.managers::FocusManager/addFocusables()[D:\Program Files\Adobe\Adobe Flash CS5.5\Common\Configuration\Component Source\ActionScript 3.0\User Interface\fl\managers\FocusManager.as:272]
              at fl.managers::FocusManager/addFocusables()[D:\Program Files\Adobe\Adobe Flash CS5.5\Common\Configuration\Component Source\ActionScript 3.0\User Interface\fl\managers\FocusManager.as:274]
              at fl.managers::FocusManager/activate()[D:\Program Files\Adobe\Adobe Flash CS5.5\Common\Configuration\Component Source\ActionScript 3.0\User Interface\fl\managers\FocusManager.as:465]
              at fl.managers::FocusManager()[D:\Program Files\Adobe\Adobe Flash CS5.5\Common\Configuration\Component Source\ActionScript 3.0\User Interface\fl\managers\FocusManager.as:178]
              at fl.core::UIComponent/createFocusManager()[D:\Program Files\Adobe\Adobe Flash CS5.5\Common\Configuration\Component Source\ActionScript 3.0\User Interface\fl\core\UIComponent.as:1621]
              at fl.core::UIComponent/initializeFocusManager()[D:\Program Files\Adobe\Adobe Flash CS5.5\Common\Configuration\Component Source\ActionScript 3.0\User Interface\fl\core\UIComponent.as:1532]
              at fl.core::UIComponent/addedHandler()[D:\Program Files\Adobe\Adobe Flash CS5.5\Common\Configuration\Component Source\ActionScript 3.0\User Interface\fl\core\UIComponent.as:1553]
              at mx.core::Container/http://www.adobe.com/2006/flex/mx/internal::createContentPane()[E:\dev\4.y\frameworks\projects\mx\src\mx\core\Container.as:5437]
              at mx.core::Container/createOrDestroyScrollbars()[E:\dev\4.y\frameworks\ projects\mx\src\mx\core\Container.as:5183]
              at mx.core::Container/createScrollbarsIfNeeded()[E:\dev\4.y\frameworks\p rojects\mx\src\mx\core\Container.as:5132]
              at mx.core::Container/createContentPaneAndScrollbarsIfNeeded()[E:\dev\4. y\frameworks\projects\mx\src\mx\core\Container.as:4929]
              at mx.core::Container/validateDisplayList()[E:\dev\4.y\frameworks\projec ts\mx\src\mx\core\Container.as:3312]
              at mx.managers::LayoutManager/validateDisplayList()[E:\dev\4.y\framework s\projects\framework\src\mx\managers\LayoutManager.as:736]
              at mx.managers::LayoutManager/doPhasedInstantiation()[E:\dev\4.y\framewo rks\projects\framework\src\mx\managers\LayoutManager.as:819]
              at mx.managers::LayoutManager/validateNow()[E:\dev\4.y\frameworks\projec ts\framework\src\mx\managers\LayoutManager.as:878]
              at mx.core::Application/resizeHandler()[E:\dev\4.y\frameworks\projects\m x\src\mx\core\Application.as:1734]
              at mx.core::Application/commitProperties()[E:\dev\4.y\frameworks\project s\mx\src\mx\core\Application.as:1086]
              at mx.core::UIComponent/validateProperties()[E:\dev\4.y\frameworks\proje cts\framework\src\mx\core\UIComponent.as:8219]
              at mx.managers::LayoutManager/validateProperties()[E:\dev\4.y\frameworks \projects\framework\src\mx\managers\LayoutManager.as:597]
              at mx.managers::LayoutManager/doPhasedInstantiation()[E:\dev\4.y\framewo rks\projects\framework\src\mx\managers\LayoutManager.as:813]
              at flash.events::EventDispatcher/dispatchEventFunction()
              at flash.events::EventDispatcher/dispatchEvent()
              at mx.managers::SystemManager/Stage_resizeHandler()[E:\dev\4.y\framework s\projects\framework\src\mx\managers\SystemManager.as:3227]
    I got the Same Error
    My application with the layout desc bellow
    [MainApp:mx:Application]
    --[xxxx:mx:UIComponent]
    ---[a_mc_like_dialog:MovieClip]
    -----[ctrl:fl:UIComponent] //type of fl.controls.*
    when MainApp handle stage resize event
    the application crash
    the cause is in function
    Container::createScrollbarsIfNeeded and it change the _firstChildIndex
    the local var
    needContentPane is true
    My solution is set MainApp's properties like this
                    horizontalScrollPolicy="off"
                    verticalScrollPolicy="off"
                    clipContent="false"
    May 9, 2013 9:42 AM   in reply to duzhiwei
    This stack trace indicates that you are mixing components from Flash Pro in your Flex app.  The built-in components from Flash Pro were not written to be compatible with Flex.  You can create your own components that don’t use Flash Pro components and build them up out of low-level shapes and sprites and integrate them in Flex with the Flash-Integration Kit.
    May 9, 2013 7:38 PM   in reply to Flex harUI
    the local var
                    clipContent="false"
