beatduck
Timing goes out and audio cuts off at end of published slide sequence
Oct 7, 2010 1:03 AM
Hi
I am experiencing a problem with timing and the sound cutting off at the end of a slide sequence.
Here is my work flow:
I record what I want my slide show to say, add my music and sound effects in Soundbooth. I then create a mp3 file for my slide show.
I adjust my slide show timing to match my voice over, ensuring that the total number of minutes and seconds the slide show equates to matches the length of my audio. I then import my audio into my project while maintaining the slide timing.
If I preview the individual slides to match the timing of the arrival of words or pointers in my presentation by pressing the play button in Captivate, everything is great.... until I publish to a .swf file.
On a 2m:50sec slide show of 22 slides it cuts off approximately 5 seconds before the end. My timing which I have bent my brain on getting right, is out and appears to worsen the longer the slide show is or if it is not on the latest and greatest Mac powered computer.
I have gone so far as to increase the length of time on the last slide 5 seconds beyond the length of time that the audio occupies as well as adding another 5 seccond blank slide and still have the same cut off problem. No ideas how to help the poor souls who might not have an amazing computer to watch the demonstration on?
Interestingly if I publish and look only at the last 3 slides or if I look at a short sequence of slides or at a slide in isolation, my audio is there as it should be along with the timing. It would appear that the time "lost" or a lag between the presentation and the audio is the culprit.
Kindly advise if there is a solution to this or whether the problem lies with something I am doing.
Thank you in advance
    Oct 7, 2010 1:47 AM   in reply to beatduck
    Hi there,
    Please follow the steps mentioned in this blog post : http://blogs.adobe.com/captivate/2010/08/audiovideosync_in_captivate_s wf.html
    Even after following the steps mentioned, if it does not solve the problem let us know.
    -Ashwin Bharghav B
    Oct 27, 2010 7:13 AM   in reply to beatduck
    Hi all,
    We are investigating this issue and need your help. We need your projects for us to investigate and know the issue better. Please send them to ashwin at adobe dot com ASAP. Please do not zip the project as the spam filters may block them.
    Ashwin Bharghav B
    Captivate Team
    Oct 29, 2010 12:13 PM   in reply to AshwinBharghavB
    We have the same issue with the Neospeech voices, and have had to insert the vtml pause time tag to correct it. However, with the trial versions of the IVONA Brian and Kendra voices we have been testing with, the issue does not occur--the speech does not get cut off at all.
    Mar 4, 2011 10:30 AM   in reply to beatduck
    Has there been any new developments on this problem?
    I've been having to do some crazy work arounds to avoid audio cutting off at the end of slides when using CP5 for development.
    Then this week I had to review an old training which was published a long time ago only to discover that the same issue of audio cutting off is happening there.
    These materials were developed using CP4 and some even with CP3.  This means that the problem/change is not CP5 but probably something to do with the Flash player version because at the time of publshing the older files did not have this issue.
    This has me really worried.  There is no way I can go back and update all the old files and it means that previously perfect materials are now being viewed with audio cutting off.
    Have the Adobe Captivate developers considered the possiblity that this may be a flash player issue?  Have you discussed this with the Adobe Flash developers?  Will there be a fix for this anytime soon?
    Aimee
    Mar 8, 2011 4:11 AM   in reply to beatduck
    There is a Captivate patch and set of instructions (basically just set all your slides' "On Exit" actions to No Action) to overcome the issue. However, it has not worked for us on all of our projects. The larger projects (around 60-80 slides or more) still have the audio cut-off issue, although it isn't as bad as it was. I've also found that using the "Force re-publish of all the slides" option when you publish seems to help, although I haven't done any real testing of it.
    Mar 8, 2011 4:15 AM   in reply to joebor1776
    Thanks to you both for your feedback.
    I've installed the patch but I was not aware of the 'on exit > no action' bit.  I'll try that for new files but it is really not feasible to go back and republish training modules which were created two or three years ago in another version of Captivate.  Has anyone else found this issue also in old - previously okay files like I have?
    I'm convinced the issue has something  to do with the Flash player version since it is also happening to old files which previously did not cut off.
    Aimee
