Align center-sometimes it doesn't work
Oct 7, 2010 6:57 AM
I have a weird thing that happens in Illustrator, and it's more prevelant when I'm working in very small scale. It's kind of hard to explain, so bear with me. Sometimes the align center feature doesn't do anything at all -- I'll have two objects selected and they are very close to being center aligned but I can tell they are not. The align setting is set up to align to objects, not key object or artboard. I think it might have something to do with the cursor increments. When I use the arrow keys to go left or right it moves in a larger increment than I need it to, so maybe that's why it won't align properly. Although I have changed this in Preferences to be as small as .005mm and it seems to have no effect at all. The workaround I've found is that if I move the objects far enough apart and then align to center it usually works. Has anyone else experienced this?
    Oct 7, 2010 8:00 AM   in reply to metonda
    Sounds like it is some hard-coded threshold/ value clipping. If so, you can't circumvent it otehr than the method you are already using. Anyway, you might simply consider working at a larger size to scale later and not 1:1...
    Mylenium
    Oct 7, 2010 11:25 AM   in reply to metonda
    Can you provide a definite breadboard model to reproduce the issue? Include information about what kind of objects you are using. Describe it as detailed as possible.
    Also, which version of Illustrator are you using?
    Oct 7, 2010 1:19 PM   in reply to Kurt Gold
    Check to see if your selection has hollow or solid points.If they are hollow then align functions will not work. At smaller sizes might be easier for you to have hollow selected points without knowing.
    Oct 7, 2010 1:43 PM   in reply to Mike Gondek
    Mike Gondek2 wrote:
    Check to see if your selection has hollow or solid points. If they are hollow then align functions will not work.
    Since when?
    Oct 7, 2010 11:12 PM   in reply to Kurt Gold
    I vote a huh as well…
    Jul 6, 2012 11:18 AM   in reply to Wade_Zimmerman
    I was going to make a new thread, as I have this problem all the time. If I click "align center", with an object that is almost perfectly centered but not quite, it will throw it to the left edge of the artboard, and then if I hit it again and again, it just keeps moving it left??? Anyone know how to fix this glitch? Other things align fine in the same file.
    Jul 6, 2012 11:43 AM   in reply to PTEGolf
    In your Align panel do you have the Options shown. What is the Align to set to? Align to Selection or Align to Artboard?Screen shot 2012-07-06 at 11.40.56 AM.png
    Jul 6, 2012 12:09 PM   in reply to Larry G. Schneider
    Align to artboard. It works 9 times out of 10, but when it doesn't, I have no idea what to do. If I had some kind of a screen recording program I would love to show you a result, but I do not. I will see if I can get a video from my phone, but the codecs have been really giving me problems with the video.
    Jul 6, 2012 1:09 PM   in reply to PTEGolf
    Here is a video, sorry it's so shakey, had to 1 hand the camera and my hands shake really bad.
    Link to video: http://www.ptegolf.com/adobe/Center.wmv 6mb
    Jul 6, 2012 1:39 PM   in reply to PTEGolf
    What's the proxy set to?
    Is it on the center as above?
    Jul 9, 2012 8:09 AM   in reply to Larry G. Schneider
    Yes, I went back and double checked on the video.
    Jul 26, 2012 8:36 AM   in reply to PTEGolf
    I think I have the exact same problem as PTEGolf. The DVD logo does have a "hollow" section in it. Is this what was meant earlier by hollow points?
    https://docs.google.com/open?id=0B6lPXGp9Trg0aTZhVDJpdUxFUXc
    Sep 20, 2012 7:03 AM   in reply to willcsummers
    I am having this problem again today. When I select everything in the artwork, the outside points are hollow. When I center, it goes off the canvas to the right, and each time I press it after that, it keeps moving that direction. SO FRUSTRATING!
    The one workaround I did find is if I select everything and choose "Edit Contents" on the far top left next to the word "Group". It was selected to "Edit clipping path".
