How can I include/exclude certain files in the flexPMD ant task? the task doesn't support a nested fileset attribute. Essentially I want to exclude any files with "test" in the name.
Not currently possible...
As a workaround you have two options:
If your tests and code are in separate dirs... just point flexpmd at your source folders and not your test folders
Or
If your tests are mixed in with your code...
- use ants copy task to copy the code you want to run flexpmd on to a diff dir
- run flexpmd on that dir
- delete that new dir when flexpmd completes
Incidentally you can still achieve package level access by putting your test code in a diff folder than your source folder... that way you can still have your test code in the same package
src/com/company/project/Code.as
test/com/company/project/CodeTest.as
hth
North America
Asia Pacific
