gyro22222
how to remove list of available actions in cs5
Oct 8, 2010 5:15 PM
I installed actions in 2 places and now i have duplicates in the available action list (click the arrow to the right of the action tab to see the menu for add, remove, options etc and a list of all available actions and sets).
I removed the actions from
C:\Users\Hal\AppData\Roaming\Adobe\Adobe Photoshop CS5\Presets\Actions
and from
C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\Presets\Actions
and yet i still have the huge list of available actions in duplicate.
How do I eliminate these?
Hal
    Oct 8, 2010 11:40 PM   in reply to gyro22222
    When you moved then out you only removed them from the fly-out menu (assuming of course that you then restarted Photoshop). The actions that are already open in the Actions panel are stored in the preferences so to clear them out either reset the preferences (why bother?) or just remove them the old fashioned way by dragging them to the trash can icon.
  • Noel Carboni
    Dec 23, 2006
    Oct 9, 2010 10:17 AM   in reply to gyro22222
    Make the Actions panel visible via Window - Actions.
    Drag actions or set titles to the trash can, or click once to highlight the action or set and use the little menu at the upper-right of the panel to select Delete or even Clear All Actions.
    -Noel
    Oct 9, 2010 10:41 AM   in reply to gyro22222
    Hello every body,
    I found a great tip to remove the unnecessary from a image at http://vietsolutions.org/photoshop-elements-9-content-aware-healing.ht ml
    But i dont know what is the tool use here. Anyone know it?
  • Noel Carboni
    Dec 23, 2006
    Oct 9, 2010 10:45 AM   in reply to gyro22222
    Ah, my mistake.  I didn't understand you fully.
    I believe the actions that show up in that menu are in one of these folders:
    Photoshop 64 bit:
    Photoshop 32 bit on a 64 bit system:
    C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Presets\Actions
    Photoshop on a 32 bit system:
    C:\Program Files\Adobe\Adobe Photoshop CS5\Presets\Actions
    You would need to move/remove the .atn files from the above folder(s) to get them to stop appearing in that list.
    -Noel
    Oct 9, 2010 10:47 AM   in reply to gyro22222
    All those should be in the two folders that you mentioned in your first post. The ones above the line between Video Actions and 3D Product Box are found in the Program Files folder tree while those beneath that line are in the Users folder tree. All you have to do is delete the duplicate .ATN files from those folders.
    Oct 9, 2010 2:53 PM   in reply to gyro22222
    Actions files could be anywhere in the presets folders and still be picked up.
    The actions/color swatches/etc. sub folders are just there for your organization -- Photoshop just searches everything under presets.
    Mar 13, 2011 8:04 PM   in reply to gyro22222
    Thanks for the final solution to this post. It worked for me after removing all ATN files (except default) from the Preset folder.  I was getting duplicates even triplicates of actions I already had installed.and forgotten.  I hadn't encountered this before in earlier versions.  Thanks again.
    Message was edited by: kathykid
