is anybody else missing the button to enable the event propagation in the script editor?
I know it has been there once, but seems to be disappeared since I installed the SP2 (9.0.0.2.20101008.2.720808) for Designer.
It will only become active when you click on a subform that has child nodes. So if you add a script that changes the bordercolor on the enter event of a subform, then that checkbox becomes active and allows you to propogate the command to all objects contained within the subform.
Note that it has been removed for SP2 because it was causing too much confusion for users. The advanced users that use that facility are expected to make the changes in the xml source that the button provided.
Paul
Aha, it has been removed.
Even more confusing, don't you think?!
Wasn't mentioned in the release notes, right? ![]()
http://help.adobe.com/en_US/livecycle/9.0/lcdesigner_releasenotes.htm
Thanks for this post!
I know this is an old post, but it really helped me out. I was trying to get a propogated event whenever exiting a field to work and was finally able to do it by editing the xml. The change I had to make was the following.
ORIGINAL LINE OF CODE
event activity="exit" name="event__exit
NEW LINE OF CODE
event activity="exit" listen="refAndDescendents" name="event__exit
North America
Asia Pacific
