Tired of color desat when opening in Bridge/Lightroom. HELP!
Oct 27, 2010 7:34 AM
  Latest reply: Cwithe, Dec 3, 2012 6:47 AM
Replies 1 2 3 4 3 Previous Next
    Jan 28, 2011 10:16 AM   in reply to conniez68
    conniez68 sorry for your trouble with this issue.
    The only point you need to make to a troubleshooter is Photoshop is not displaying the Tagged PDI images correctly in Photoshop. Period.
    It should be routine for him to verify what profile Photoshop is using and for him to rule that profile out (about five minutes).
    Moreover, a person with a working knowledge of Windows Color Management should be able to easily (and quickly) pinpoint the part of your setup that is broken by tracing the workflow back to the point where what should be happening isn't.
    Another poster wrote of similar problems that involves your monitor and profiling package so maybe that's your most helpful post in solving your own issue, too.
    The monitor is easy to rule out by swapping it it out.
    However, the system is not so easy (because so many people have had their fingers on it).
    In your shoes, I would put in a different hard drive, Erase it, install ONLY the OS, Photoshop and updates.
    If it fails at that point (with no more fiddling around), I would send it back to where you bought it and ask them why it doesn't work correctly.
    If it does work at that point, either the profiling package or the monitor you swapped out is the problem, or something is amiss in your old system.
    I've seen my share of PC 'experts" at work, they always seem to fiddle around, uninstall, reinstall, fiddle around, uninstall, reinstall and come back to repeat the process...when they do solve a problem they never seem to understand why or what happened, it always seems to have magically fixed itself during their fiddling.
    People who understand the question generally get right to the issue (unless there are bugs or hardware issues to slow them down).
    I wish you the best luck in solving this.
    Jan 31, 2011 9:43 AM   in reply to gator soup
    Didn't read the entire thread, but connie mentioned she was using a Nikon D70.
    Back when that camera came out the embedded profile as chosen incamera often couldn't be read by Adobe and other color managed apps. This NikonGear thread:
    http://nikongear.com/smf/index.php?topic=26719.0
    alludes that the way Nikon sometimes writes its profile tags incamera and/or in Capture NX can cause this. It appears the way the profile is written/tagged into the image can tell or not tell a color managed app whether to see it or not. There are rules to writing code especially when color is involved.
    I've often dragged and dropped images posted in thread discussions where one piece of software (Apple script "Get Profile Info") says the image has no embedded sRGB profile while Photoshop sees it and sometimes Photoshop doesn't see it and says it's untagged. No way of knowing the cause.
    Not sure if this only applies to Nikon jpegs and/or NEF's. This use to be a real issue in the past, but now I'm guessing has been fixed with newer Nikon cameras.
    Just to test I'ld suggest connie shoot two versions of the same scene with incamera profile chosen, one in jpeg and one NEF and drag them directly to the desktop and open in Photoshop, no Bridge. See if the profile is seen in the jpeg and whether the previews differ between the jpeg and the NEF which should open in Adobe Camera Raw.
    May 13, 2011 9:50 AM   in reply to Tim Lookingbill
    this is a pretty old discussion but it was probably the only resource i found that actually helped with my colour management nightmare!
    i spent weeks and wasted tons of ink and expensive photo paper and seemingly to no avail. all i wanted to do was to stop me and my wife looking sunburnt in my print outs from adobe photoshop. I even bought a new printer before i realised the fault lay elsewhere.
    I have a dell u2410, on win 6 x64. I used lightroom 3.3 x64, photoshop cs5 32 and 64 bit and a host of other colour managed programs and others that were not.
    what i realise now (thanks to the previous posts) was that when i opened my images in photoshop they were desaturating. This meant i over compensated in the adjustments and hence when i printed all the colours were terribly oversaturated. What i couldnt work out was that in windows 7 thumbnails and preview, i.e. not colour managed all the colours looked pretty much like the prints. But open photoshop and they were as i wanted them, neutral skin tones.
    i checked and checked again that i was letting photoshop handle the colour management for prints and am 100% certain had the settings correct.
    i went down the route of various ICC profiles and luckily did not invest in a calibrating device for my monitor.
    to cut a long story short I found that the problem was with the ATI software and specifically the display color options (via DVI) - the color temperature control!! This was set to use EDID when unticked i found that when i opened photoshop my colours no longer desaturated!!! Woo hooo.
    and the other thing was definitely disable the windows color system service mentioned in a previous post - although it sounds like it shouldnt make a difference it definitely does.
    So now I had what I expected, colours look a bit naff in non colour managed software but "fairly" closely resemble what i see in photoshop, and now when i print to my canon mg5250 (using photoshop colour man) my prints "nearly" match what i see in photoshop!!
    Perhaps I would now benefit from true calibration and creation of a custom icc profile but i am pretty happy with the results.
    hopefully this will help anyone else in this situation
    Jun 14, 2011 12:26 PM   in reply to conniez68
    Conny, I feel for you. A dreadful ordeal.
    I seriously suggest you shift over to Mac for the simple reason they have been built for graphics from the moment of birth in 1984. When the Mac O/S9 was found wanting it was completely ditched and a new O/S built on an reliable language, Unix. To the best of my knowledge all Microsoft upgrades are rebuilds on top of primitive DOS underpinnings. I mean primitive. Like a house on weak foundations. What is remarkable to me is that Windows works as well as it does despite this fact. But it remains a 50 year old product with numerous upgrades. It was originally created for business and accounting software, not graphics.
    As a user with experience of both systems, I would say reliability is far greater with Mac and ease of use leaves Microsoft for dead. Where the Mac connects and software automatically, provides free programs and tools, Windows posts dialogue boxes asking you to do this or that, to check this or that, it requires you to buy extra security and cleaning tools and if you need help ask your administrator! Two different worlds. Macs are not perfect but far easier to trouble shoot with an O/S that is packed with useful apps and tools.
    It is no small matter to pay for another Adobe Suite but as you are working commercially a way to fund it can be found. Believe me, after you make the change to Mac, you will wonder why it took you so long.
    Just my experience
    Good Luck
    Dec 7, 2011 4:10 AM   in reply to conniez68
    Hi there,
    I just read your questions and the answers you got fom people all over the world. That's great!
    But none of them provided you with an answer. I think I have it.
    You can read it here: http://forums.dpreview.com/forums/readflat.asp?forum=1006&thread=37521 609&page=2.
    I think it's got to do with the camera raw settings, which you can change in the preferences panel in photoshop.
    I had exactly the same problem on my system (Mac OS 10.6.8) and I was running the latest version of photoshop.
    Only Jpegs and Tiffs showed this problem, when I looked at them in Bridge they turned from nice, warm looking to a cold blue and unsaturated color tone.
    When I fixed my settings in the camera Raw prefs, it all went back to 'normal'.
    Hope this will help.
    B
    May 24, 2012 11:45 AM   in reply to conniez68
    The same exact thing is happening to me. The "domino" effect of saturation going out happened.
    I tried the following for troubleshooting:
    I rebooted the computer.
    I unplugged and replugged in the monitor cable.
    I installed adobe updates
    I deleted all the files, and re-downloaded all the image files.
    I went in to the camera raw settings in photoshop and bridge and made sure they were matching
    I looked at the calibration of the monitor, but i know it’s not the monitor because the image looks fine in “windows picture viewer” application.
    If I minimize bridge and then maximize, the image will look correctly saturated, but when I click my mouse, or move the window, it returns to being desaturated and has a color shift.
    It seems like a bug to me because all the profiles match.  I'm really not sure what to do here.
    --Paige
    May 24, 2012 6:19 PM   in reply to partyonpizza
    Paige,
    You apparently didn't go to the link provided above.  It's the Camera Raw Preferences from the Edit menu.  No rebooting necessary, no unplugging, and not a calibration issue.  Here is the dialog box:
    Just make sure you have jpeg and tiff support disabled as shown.
    May 25, 2012 6:03 AM   in reply to Chris_BC_1
    Chris,
    This did not fix the problem.
    Paige
    May 25, 2012 10:18 AM   in reply to partyonpizza
    Anyway, tell us which OS you use and what monitor profile is configured for the OS
    This sounds like smaller previews where create with the correct colorprofile, while larger are not - either before or after a change must happend. What happens when you delete Bridges cache? Same same, or did it help (they all look okay) or are the smaller previews desaturated as well then?
    Jörg
  • Andrew Rodney
    Apr 16, 2009
    May 25, 2012 10:44 AM   in reply to ablichter
    Windows Picture Viewer isn’t color managed. It is incorrect (even if you prefer the appearance). Camera Raw, Photoshop, Lightroom are color managed. The appearance is correct** even if you don’t like the way they look.
    Assuming the documents have the correct embedded profile and the display profile is correctly defining display behavior.
    May 25, 2012 11:34 PM   in reply to partyonpizza
    Paige,
    Another way of phrasing Andrew Rodney's most authoritative comments would be to say is that if your monitor has not been accurately calibrated and profiled, then your monitor profile is indeed causing your problem.  Note the conditional "if " in the preceding sentence.
    You can never judge the true colors of an image in a non-color managed application, such as Windows Picture Viewer.  You can only evaluate the colors using an accurately calibrated and profiled monitor in a color-managed application like Photoshop.
    May 26, 2012 8:25 AM   in reply to station_two
    I would agree with all that if it wasn't for the fact that Windows Photo Viewer is fully color managed. Not only does it honor the embedded profile, but it also converts to the monitor profile. It has been color managed since Vista, when it was called Windows Photo Gallery. In XP, however, it was not color managed.
    But there could still be a problem with the profile, with Photo Viewer not reading all the properties of the profile.
    Jun 24, 2012 12:28 AM   in reply to twenty_one
    here's what I found through various tests regarding Windows Photo Viewer on Win 7:
    > as D Fosse stated, the general Windows Photo Viewer (open image via WPV) is color managed. If an image is untagged it will be displayed via sRGB (unfortunately not your default system profile, which could be your custom calibration profile)
    > Windows Photo Viewer in SLIDESHOW MODE (open image in WPV and then click the large center Slideshow button) is non-color managed and will display images via your default system profile, the same applies to MS Paint and Windows explorer thumbnails
    So on a wide gamut display, soft proofing an image in PS via your monitor RGB has the same appearance as that image in WPV in Slideshow mode or MS Paint, which is more saturated...
    The above information is valid for  ICC v2 profiles - Windows has issues with ICC v4 profiles...
    Oct 8, 2012 12:32 AM   in reply to Iron_Mike
    I have a similar problem in this conversation http://forums.adobe.com/message/4757046#4757046
    Did you resolve it?
  • Andrew Rodney
    Apr 16, 2009
    Oct 16, 2012 9:45 AM   in reply to Iron_Mike
    That's a problem because assigning or assuming sRGB may or may not be the right assumption for this untagged image. On Mac, several OS app's assume untagged doc's are in display RGB (based on your display profile). Well depending on what version of Mac OS you are running. Apple seems to move all over the map here. Anyway, the best way to be working here is without using untagged documents !
    Which is a process whereby you make PS provided an incorrect preview to match the other incorrect preview. If you look at the soft proof options, you'll see Monitor RGB (use your specific display profile) or Legacy Macintosh or Internet (sRGB).
    The problem with an untagged doc is even a color managed app has to make an assumption of the scale of the RGB numbers (are they sRGB, ProPhoto, display RGB, or any other flavor of RGB). When the assumption is correct, you should get a match.
    If the image is tagged in sRGB and you use your display profile for soft proofing (Monitor RGB), the preview is wrong! It looks way over saturated on a wide gamut display. The image is in sRGB but you're telling Photoshop to show you how those numbers should appear if they were the display RGB which is wide gamut, thus over saturated. And if you opened the same image in a non ICC aware app, it would look very similar. If you assumed display RGB here, instead of the correct assumption (sRGB), again, incorrect preview that is over saturated.
    This is a 'problem' with Wide Gamut displays in an sRGB centric world, non color managed world. We're to believe that sRGB is some standard behavior and to some degree, it is although the beavhior it defines reflects a CRT we haven't had around for years and years. To put it another way, if all sRGB similar displays were replaced with Adobe RGB like displays and all applications treated untagged data as Adobe RGB (1998), the differences in the previews would be much less. Your LCD isn't really an sRGB device. Your wide gamut display is really quite different. Untagged sRGB assumed as such or not on a sRGB like device looks pretty close (there can be differences of course). Untagged sRGB assumed to be Adobe RGB is just the wrong assumption and such, the preview is wrong.
    Bottom line, 9 times out of 10, if an image doesn't match between Photoshop, Lightroom or other ICC aware applications and the one you're comparing to, chances are, the other application is not ICC aware or it is treating the RGB numbers incorrectly due to the lack of an embedded profile.
    Dec 3, 2012 6:47 AM   in reply to conniez68
    Connie,
    i have exactly the same problem, only  i got it straight after the calibration with i1display pro. All colors shifted to some desaturated thing with slightly greenish hue all over the images. It looks **** indeed.
    There's no replies afte Oct. 16th here on, did you manage to fix the problem.
    I'm on win8 64bit (same thing was on win7 64bit).
    Thanks a lot for any update!
Actions
