converting a pdf to jpg
Oct 31, 2010 4:59 AM
I scanned some pictures and for some reason they loaded as
pdf instead of jpg. Is there any way to convert the file to jpg format
? Does anyone know why the pictures would scan as pdf rather than jpg or bitmap?
    Nov 1, 2010 9:20 AM   in reply to syd1962
    Hello there,
    I'm sorry you're having trouble. If you find that images are scanning as one format rather than another (preferred) format, you may want to use the software that came with your scanner to determine the format to which scanned images will be saved; that's something you should be able to control. Unfortunately, I can't offer much more assistance than that; if you need to convert the existing PDF files to JPEG files, you'll have to use software like Adobe Acrobat. Here is a link to the product page:
    www.adobe.com/products/acrobat
    I hope this helps!
    Best,
    Rebecca
    Nov 4, 2010 6:26 AM   in reply to syd1962
    If you have Adobe Photoshop installed, it will convert the PDF files to JPG.
    May 21, 2011 2:24 PM   in reply to syd1962
    For such one-time task, if you don't have Acrobat, I suggest you to use a PDF to JPG online converter. All you have to do is upload your PDF and download the generated JPG. Of course, it will be simpler to make your scanner generate JPG...
    Feb 11, 2012 4:40 AM   in reply to syd1962
    Its possible to do it online, for example at http://pdfjpg.net
