Jan Klosinski
[bug] TLF, SelectionManager and popup
Nov 10, 2010 8:58 AM
hi,
it seems that Squiggly doesn't work well with TLF SelectionManager.
Steps to reproducs:
1. open popup
2. close popup (don't type anything in the text input)
3. open popup
You should see the following error:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
     at flashx.textLayout.edit::SelectionManager$/computeSelectionIndexInContainer()[C:\Vellum\branches\v1\1.1\dev\output\openSource\textLayout\src\flashx\textLayout\edit\SelectionManager.as:827]
     at flashx.textLayout.edit::SelectionManager$/http://ns.adobe.com/textLayout/internal/2008::computeSelectionIndex()[C:\Vellum\branches\v1\1.1\dev\output\openSource\textLayout\src\flashx\textLayout\edit\SelectionManager.as:1111]
     at com.adobe.linguistics.spelling.ui::SparkHighlighter/getValidFirstWordIndex()[E:\glo_lib\esg\users\ravi\squiggly\0.3\AdobeSpellingUI\src\com\adobe\linguistics\spelling\ui\SparkHighlighter.as:212]
     at com.adobe.linguistics.spelling.ui::SparkHighlighter/doSpelling()[E:\glo_lib\esg\users\ravi\squiggly\0.3\AdobeSpellingUI\src\com\adobe\linguistics\spelling\ui\SparkHighlighter.as:69]
     at com.adobe.linguistics.spelling.ui::SparkHighlighter/handleFocusIn()[E:\glo_lib\esg\users\ravi\squiggly\0.3\AdobeSpellingUI\src\com\adobe\linguistics\spelling\ui\SparkHighlighter.as:94]
     at flash.display::Stage/set focus()
     at mx.core::UIComponent/setFocus()[E:\dev\4.x\frameworks\projects\framework\src\mx\core\UIComponent.as:9544]
     at spark.components::RichEditableText/setFocus()[E:\dev\4.x\frameworks\projects\spark\src\spark\components\RichEditableText.as:2712]
     at spark.components.supportClasses::SkinnableTextBase/setFocus()[E:\dev\4.x\frameworks\projects\spark\src\spark\components\supportClasses\SkinnableTextBase.as:1116]
     at mx.managers::FocusManager/setFocus()[E:\dev\4.x\frameworks\projects\framework\src\mx\managers\FocusManager.as:597]
     at CustomPopup/reset()[C:\Documents and Settings\klosinja\Local Developer\workspaces\flashbuilder\SquigglyBugs\src\CustomPopup.mxml:22]
     at PopupBug/openPopup()[C:\Documents and Settings\klosinja\Local Developer\workspaces\flashbuilder\SquigglyBugs\src\PopupBug.mxml:17]
     at PopupBug/___PopupBug_Button1_click()[C:\Documents and Settings\klosinja\Local Developer\workspaces\flashbuilder\SquigglyBugs\src\PopupBug.mxml:26]
     at flash.events::EventDispatcher/dispatchEventFunction()
     at flash.events::EventDispatcher/dispatchEvent()
     at mx.core::UIComponent/dispatchEvent()[E:\dev\4.x\frameworks\projects\framework\src\mx\core\UIComponent.as:12528]
     at spark.components.supportClasses::ButtonBase/keyUpHandler()[E:\dev\4.x\frameworks\projects\spark\src\spark\components\supportClasses\ButtonBase.as:987]
application
    xmlns:mx="library://ns.adobe.com/flex/mx"
    xmlns:local="*"
    minWidth="955" minHeight="600"
    <fx:Script>
        <![CDATA[
            import mx.core.IFlexDisplayObject;
            import mx.managers.PopUpManager;
            public function openPopup():void
                PopUpManager.addPopUp(popup, this);
                popup.reset()
    </fx:Script>
    <fx:Declarations>
        <local:CustomPopup id="popup" />
    </fx:Declarations>
    <s:Button label="open popup" click="openPopup()" />
</s:Application>
CustomPopup.mxml
<s:Panel xmlns:fx="http://ns.adobe.com/mxml/2009"
    width="400" height="300"
    creationComplete="SpellUI.enableSpelling(txt, 'en_US')"
    <fx:Script>
        <![CDATA[
    </fx:Script>
    <fx:Script>
        <![CDATA[
            import com.adobe.linguistics.spelling.SpellUI;
            public function reset():void
                txt.text = ;
                focusManager.setFocus(txt);
    </fx:Script>
    <s:layout>
        <s:VerticalLayout/>
    </s:layout>
    <s:TextInput id="txt" />
    <s:Button label="close" click="PopUpManager.removePopUp(this)" />
</s:Panel>
Any suggestions?
thanks,
Jan
    Nov 11, 2010 4:58 AM   in reply to Jan Klosinski
    TLF is not supported yet in Squiggly till the 0.4 release. We are working on the TLF integration which should fix issues like this.
    Nov 15, 2010 4:04 PM   in reply to Jan Klosinski
    Thanks for reporting this issue.  We had not yet fully tested Squiggly with TLF, so your findings are very helpful.
    Thanks!
    - Bruce, Adobe
    Feb 28, 2011 4:26 PM   in reply to beimon
    Squiggly 0.5 was recently released with native TLF support.
    Please let us know if this release addresses your issues.
    - Bruce, Adobe
    Nov 15, 2011 2:38 PM   in reply to beimon
    I'm running into the same problem, we're using Squiggly 0.6, however I think the problem most likely lays in the SelectionManager code. The call to tlf.getTextLine(true) can return a null value and the resulting object isn't tested to see if it is null before it's accessed.
