Deactivate file formats in Save As menu
Nov 12, 2010 1:56 AM
Hello,
where can I find the adobe program files e.g. for the Targa format (*.tga, ...)?
I want to deactivate/hide these formats from the Save As menu.
Carlos
  • JJMack
    Jan 9, 2006
    Nov 12, 2010 5:44 AM   in reply to cmeira
    You may be able to turn off Targa in some version of Photoshop like in CS2  its support seems to be in a plugin" C:\Program Files\Adobe\Adobe Photoshop CS2\Plug-Ins\File Formats\Targa.8BI".  However in newer releases like CS5 the plug-in is gone so  Targa support must have been moved into Photoshop itself.
    Nov 12, 2010 12:59 PM   in reply to JJMack
    Just go through and remove all the plugins that you copied from previous versions of Photoshop, and never try to copy the plugins between versions again (because they WILL cause problems).
    The Targa support in CS5 is in the Standard Multiplugin.
  • JJMack
    Jan 9, 2006
    Mar 28, 2011 11:47 AM   in reply to cmeira
    Then you have to use an older version of photoshop like CS2 where it support is in a plug-in which you can remove from the file extention folder.  That is not an option in newer version of Photoshop where that file type support has been moved into Photoshop proper.  Adobe does not offer an option to turn off this photoshop support of that file type.
    Chris's appen was bogus he did not read the thread correctly some how he got the idea that you were copying plug-ins frome an old release to a newer release of Photoshop. When actually you want to do is remove a file type support from Photoshop.
    Mar 28, 2011 11:27 PM   in reply to JJMack
    I remember at least one other thread where someone also wanted to remove file-foremats they never expected to use from the save as-dialog.
    So the OP might consider posting a Feature Request or looking to see if one has been made before and lend their support.
    Photoshop Feature Requests
  • Noel Carboni
    Dec 23, 2006
    Mar 29, 2011 9:18 AM   in reply to cmeira
    cmeira wrote:
    Once again, it is not possible to deactivate specific file formats as it was possible in former versions?
    That is correct.  As Chris Cox has pointed out, all the formats live in one plug-in now.
    Are you looking for a simpler list, higher performance, or are you trying to protect your users from something?  Just curious, because having an extra option in a list that you don't normally choose isn't really a big deal for most folks...
    -Noel
    Mar 29, 2011 9:55 AM   in reply to c.pfaffenbichler
    Actually, I think I just responded to the wrong thread.
  • Noel Carboni
    Dec 23, 2006
    Mar 29, 2011 12:05 PM   in reply to Chris Cox
    You're allowed one mistake every 3 years, Chris.
    -Noel
