With an email endpoint, is it possible to get values from the e-mail OTHER than the attachments?
i.e. can you get sender, subject, body, addressee as input variables to the process that is being invoked?
Views
Total Likes
It looks like it is possible - although I need to check the full API:
from: http://help.adobe.com/en_US/livecycle/9.0/adminHelp/admin.htm?content=000547.html
Variable: You can map a string from the email subject, body, header, or sender's email address. To do this, use one of the following keywords: %SUBJECT%, %BODY%, %HEADER%, or %SENDER%. For example, if you use %SUBJECT%, the email subject content is used as the input parameter. To pick up attachments, enter a file pattern that the email endpoint can use to select the attached documents. For example, entering
*.pdf selects any attached document that has a .pdf file name extension,
* selects any attached document, and
example.pdf selects any attached document named example.pdf.
Views
Total Likes
Not sure if it is possible to pass the addressee as a variable though...
Views
Total Likes
