Shurkhovetsky
Two Code Split View
Nov 23, 2010 4:15 AM
In Dreamweaver there is a possibility to view code with design in parallel, view desing or code only, or switch to split code view, which allows user to see the same document and move to it's different parts. However, as far as I understood there is no possibility to view two different source codes in the same time. What if I am building the page and need to get some ideas or some parts of the codefrom another one? I believe that would be very nice if there was a chance to see one code and edit another one simultaneously.
Hope I'm mistaken and DW CS5 allows that.
    Nov 23, 2010 4:29 AM   in reply to Shurkhovetsky
    You mean like this?
    In CS4 that's under the Window menu which give you the option to cascade or tile your documents.
    Martin
    Nov 23, 2010 5:31 AM   in reply to Shurkhovetsky
    No.  You can suggest this as an enhancement to the product at this location though -
    http://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Aug 12, 2012 10:07 AM   in reply to Shurkhovetsky
    Actually it is possible. (CS 6 on Mac)
    Drag the tab and drop it on the left border of code window like you do with other GUI Elements. So you get a split view. Quite hidden but absolutely usefull!
